Old 03-10-2005, 05:03 PM   #1
elhalisf
Member#: 56332
2005 STI Cobb Stg 2
Default 01 LGT Tranny into WRX. Figured out the basics, need help with the rest.
Alright well I have an 04 WRX. I just purchased a 01 LGT Tranny with the 4.11 final drive and planning to swap some RA gears in there then swap it into my WRX. I have the rear diff from an 00 RS and the 1:1 center. So that part thus far is figured out and compatible.
Now I was told I can use WRX clutch and flywheel but not 100% sure. Also what do I need to do about the pull type/push type difference? What parts do I need to interchange that so my LGT tranny works in my WRX?
I am about to go drop off my LGT tranny and gears to subaru in less than an hour, so a quick informative reply would be greatly appreciated.
elhalisf is offline   Reply With Quote
Old 03-10-2005, 07:50 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
To my limited knowledge, I think you are ready to go. A quick call to Kingpin or Rallispec should get you a better answer though. Sounds like a nice tranny upgrade though, congrats.
Need help with the correct heat shield for my TurboXS DP on a '06 wrx SubbieAndCoop Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 06-17-2007 02:38 PM
I need help with the Boostmonkey ChrisV-FL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-14-2002 12:04 AM
Need help with the exhaust! Elliot Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-25-2002 06:22 AM
Need help with the Crank pulley The Wraith Normally Aspirated Powertrain 1 07-12-2001 06:43 PM
need help with the J&S knock sensor ChAi Normally Aspirated Powertrain 7 10-20-2000 10:32 PM
