Old 12-19-2007, 12:15 PM   #226
sconniescoob
Member#: 161488
2002 '14 CRV
Originally Posted by sachilles View Post
OK, yesterday I started the install. I have it in and working(sort of). I installed in the space of the cupholder. Being a fool, rather using the wires from the clock for connecting the gauge I used the hazard light switch. They seemed to test fine with my electrical tester. What I failed to realize is the ground I used, grounded through the blinker mechanism.. So if I turn on the hazards or the left blinker, it interrupts the ground reseting the device. .
I'm going to just hook it up to the clock wiring.
In order for it to fit in the space for the cupholder, you obviously need to remove the cupholder which has two screws holding it in place.
I'd suggest removing the clock pod. Once the cupholder is out. Pull of the piece with vents and hazard switch. It uses the cupholder screws to keep it in place on the passenger side, the other side is clipped into place, and that needs to be gently pried out. To make that easier(you'll have to do this anyway) remove the face plate that surrounds the radio and hvac controls. It is clipped in 4 places. It should pry out easy with a flat blade screw driver.
Both the the vent piece and radio face plate will have to be dremeled(but not in a spot that you can see. So if you don't like how the gauge looks in the spot, you can put it back to stock, and you wouldn't see any of the cuts.
What is important is the need to reuse the screws from the cupholder. You use them to adjust the "depth" of the gauge, otherwise it will not fit flush.
I should have some pics later today
Sounds great, looking foreward to the pics. Question - is the gauge too big to fit into the blank beside the cupholder? Despit its uselessness, I do use my cupholder on rare occasion. I was thinking either spot was great, so I'm glad to see you took the plunge first.
sconniescoob is offline   Reply With Quote
Old 12-19-2007, 12:17 PM   #227
sconniescoob
Member#: 161488
2002 '14 CRV
Originally Posted by hella_sti View Post
maybe mount it where everyone puts their useless turbo timer, right in the blank spot tot he left of the cupholder like this!
Exactly what I want to do. Just need to find a unit that fits.
Old 12-19-2007, 10:50 PM   #228
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
I am definitely doing this once i get a stereo with a clock on it.
pDubs is offline   Reply With Quote
Old 12-20-2007, 01:11 PM   #229
sachilles
Member#: 115107
02 wrx wagon
61 Morris Mini
The unit is too big to fit in the space beside the cupholder...sorry. It barely fits in the cupholder spot width wise(requires cutting to make it fit).
I need find a photo host, so I can post up the pics.
sachilles is offline   Reply With Quote
Old 12-20-2007, 02:56 PM   #230
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Mine was posted in Post #11 of this thread. The unit is still ticking strong on its original batteries (close to three years now) and the outside temp readings are always within one degree of all the tempertaure readings around town. Forget about the inside temp readings during the summer though
Hank3 is offline   Reply With Quote
Old 10-11-2009, 11:15 PM   #231
Porabowl8
Member#: 197956
Default Guage pod?
I was wondering if anyone has seen a round style temp guage that would fit inside the OEM triple guage pod that replaces the normal clock. OEM guage pod has the useless oil temp sensor that i want to get rid of...
Porabowl8 is offline   Reply With Quote
Old 10-12-2009, 12:29 AM   #232
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
When did oil temp become useless?
And no, I've never seen an external air temperature gauge that would fit a gauge pod.
Old 10-14-2009, 09:13 AM   #233
Porabowl8
Member#: 197956
I guess it's not useless, but there is one on the dash & I'd rather have a clock & inside/outside temp guage than two oil temp guages.
Old 10-14-2009, 09:27 AM   #234
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
where is there already an oil temp gauge on the dash?
ekw is offline   Reply With Quote
Old 10-26-2009, 08:15 PM   #235
Jackie
Member#: 81608
Good to see this thread is still going! Can't believe it's been 4.5 years!
I'll see if I can fix the original pictures and get them back up to help people out with their installs.
For anyone interested, my thermometer worked great until about a week ago when I pulled it out because I broke the wire to the sensor
I had actually moved it to under the radio for a while, as I recently installed a center 3 gauge pod.
The Radio Shack thermometer I used fit perfectly into one of these little OEM Forester DIN thingies.
So the thermometer was completely hidden when the door was closed.
I just drilled a hole in the back to run the sensor through. I can take pictures if anyone wants them.
Now that I broke that thermometer though I need to figure something new out. I will post it in this thread if I do anything cool.
Jackie is offline   Reply With Quote
Old 10-26-2009, 10:46 PM   #236
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
Just stumbled accross this thread. Seems like a really cool idea. I searched around for a good quality thermometer and voltmeter, maybe even a digital compass built in there too but couldn't find anything that wasn't some cheap chinese POS or that would fit in the clock pod. Anyone have any suggestions?
bcWRX-02 is offline   Reply With Quote
Old 04-29-2010, 12:32 PM   #237
Subey03
Member#: 159909
2004 STI on AIR
me to update if some one no's where to get a current version of a newer thermometer i went to radio shack and all they had were wireless
Subey03 is offline   Reply With Quote
Old 09-15-2010, 02:15 PM   #238
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Too bad this thread died, I was looking forward to having outside temp AND a clock.
Superorb is offline   Reply With Quote
Old 09-16-2010, 01:49 AM   #239
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
Fat Black Pig Sac is offline   Reply With Quote
Old 09-16-2010, 02:49 AM   #240
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
^ thank you very much sir
bbun is offline   Reply With Quote
Old 09-16-2010, 11:05 AM   #241
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
What I REALLY want is a setup where it's off when car is off, on when car is on and backlit when lights are on while retaining time/settings when the car is off. Kind of like the 08+ with their thermometer
Old 09-16-2010, 08:07 PM   #242
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
easy to DIY
Old 09-16-2010, 11:51 PM   #243
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by Fat Black Pig Sac View Post
easy to DIY
First I have to find a suitable thermometer that will display clock and outside temp at the same time AND fit into the stock clock area.
Old 02-25-2011, 02:06 PM   #244
mattyg
Member#: 32258
2003 WRX Wagon
Anyone find one yet?
mattyg is offline   Reply With Quote
Old 12-20-2011, 08:58 PM   #245
Skoobaru05
Member#: 296923
2005 Impreza WRX
Subaru Blue
Default Bumpity Bump Bump Bump
This was such a great idea and I would love to do this to my car. I am going to look around and see if I can't find or make a similar apparatus. I've made some pretty inventive **** in my day. I'll post more once I come up with something.
Skoobaru05 is offline   Reply With Quote
Old 12-21-2011, 01:37 AM   #246
Skoobaru05
Member#: 296923
2005 Impreza WRX
Subaru Blue
well I just ordered what looks to be a clock, in/out thermo, and battery gauge that should work. I ordered it from over seas so in 10-21 days i'll post pics after i'm done chopping up my stock clock
Old 05-28-2014, 07:15 PM   #247
Willrors
Member#: 391936
Is anyone else having trouble seeing the images or is it just me?
Willrors is offline   Reply With Quote
Old 05-28-2014, 07:39 PM   #248
Nairb4
Member#: 384931
2008 WRX STi hatch
The links are broken. This is from 2005 so it's expected.
Nairb4 is offline   Reply With Quote
Would replacing my helper spring with a stiffer tender spring make my car ride better vision.dynamix Brakes, Steering & Suspension 1 02-07-2010 03:44 PM
what did you replace your stock speakers with. gindobuck Car Audio, Video & Security 42 03-29-2009 10:06 PM
WTB '04 STI Trunk With Wing or Swap 4 My Stock Trunk With Stock Spolier jester5 Tri-State Area Forum 26 12-23-2004 10:57 PM
Finally replaced my stock hu skyhawk Car Audio, Video & Security 15 02-13-2004 03:37 PM
Should I replace my broken tranny with another stocker or upgrade to Sti Gears? agent007kimball Transmission (AT/MT) & Driveline 0 06-15-2003 04:44 PM
