#51 |
Member#: 82873
Vehicle:2004 WRX Wagon WRB |
Just finished. Total time, including prep, work, and clean up, took 2 hours and 37 minutes. Not bad. I want to again say thank you for sharing this mod with us. I absolutley love it. I did make one variation however, and i would like to make a suggestion, if i may. Instead of mounting the temp sensor in the grill, directly out of the firewall, i followed the water line for the wiper sprayer onto the hood, across to the passanger side and mounted it in the hood scoop. I'm not sure if the heat from the engine will effect the accuracy or not. If it does then i might find another route. I just thought it went a little easier through the scoop, but whatever works best for ya'll is just fine. Anyways, thanks again, killer mod for under 10 bucks! Good lookin out.
Peace, nick.
#52 |
Member#: 66611
Vehicle:2007 Trailblazer AWD 3LT Sandstone Metallic |
I dont really have any "brighter" pics of my install, but the lines on the side of the opening are fairly smooth, like i said when i first installed mine, i took my time doing the dremeling part cause i dont have an extra. During the daytime, the only time youll notice a less than perfect dremel job would be under direct sunlight, and at night its pretty much impossible to notice that its not "stock"
I would say to just take as much time as possible on the dremel part to make sure its a perfect fit. You can always take off a little more if you need to, but you cant put it back on if you take too much off.... |
#53 |
Member#: 82873
Anyone else having problems with the internal temperature misreading when the heater is on? Driving home last night, the thermometer was reading 127 deg. inside the vehicle. My guess is that it's misreading due to the proximity of the thermometer and the heater vents (inside dash).
I wonder if there's a material i could line the interior of the dash with to deflect, or absorb some of the heat disipated by the heater. Any thoughts? |
#54 |
Member#: 1983
RMIC
Vehicle:2008 STi Dark Grey Metallic |
The green light doesn't seem to go with the rest of my dash set-up (blue and red gauges, stereo and HVAC). Has anyone tried changing the color yet? I popped the unit open, but couldn't see that it used traditional bulbs. I doubt that using stained glass paint would be very useful as it would probably block out the numbers during the day! Hmmm....
#55 |
Member#: 67669
Vehicle:2005 2.5 Hybrid WRX evoIII 16G |
just a word of caution to anyone who is about to dremel their dash and/or go through all types of extensive modifications to integrate this unit into their interior. I purchased one of these units when I first purchased my WRX in July 2004. Since then I have replaced the outside temperature sensor twice because of obvious inaccuracies (50 deg F when the snow is flying). I tried wiring the unit to the existing Subaru outside temperature sensor but the sensors must be different impedances - all I got on the display was "LLL".
Just noticed this morning that the unit was reading 40 deg F when all the trees are coated with ice so I guess the search for a decent unit continues. |
#56 |
Member#: 82225
Vehicle:2006 VW Jetta GLI Reflex Silver |
I just picked up one of these units from the 'Shack last night, hopefully I'll have time to install this weekend on my RS... Thanks for posting this cheap (and useful) mod.
#57 |
Member#: 1983
RMIC
I tried a couple of paint options, including stained glass paint to the clock/temp face and to the square bulb inside and it doesn't really do a good job - either you can't see the numbers or the bulb's light is blocked out. Maybe a very thin coat of stained glass paint on the bulb might work - fortunately my wife has nail polish remover!
#58 |
Member#: 70074
Vehicle:2005 WRX CGM |
nice man, i think i will do this mod as well... i miss my thermo gauge from my previous car
#59 |
Member#: 44623
International
I did this mod a couple of weeks ago and now for some reason my battery keeps on dying and leaving me stranded.....The way i wired it was the "hot line" (wire with white stripe on it) to the #4 wire (yellow/red wire) accessory and other ground wire to #2 (ground). Now when i leave my car overnight it has just enough juice to start up and then when i get to my destination (only a couple of miles away, not enough time for the alternator to charge the bat up) im left stranded. I dont think its my alt b/c when the car is running the voltmeter reads 12.4V (iirc) and the battery icon is full. THe only other thing i can think of is that my battery is going, but i just replaced it last winter (with a non oem spec)! ANy help?
#60 |
Member#: 27620
Vehicle:2009 Subaru WRX DGM |
I have an issue as well. I took out the stock clock, and before cutting the dash i wanted to just hook up the temp guage to the clock wires to make sure how it worked. When i first plugged it in I had the wrong wires and the light was on regardless of the key position.
Now, when i have it just with batteries installed, the backlight no longer works. Also, the battery light on the top left stays off. I put in new batteries, and the battery light is on dimly as it resets, then once it has turned on, the battery light turns off and the backlight still doesn't work. Could something have happened to the temp guage when i hooked it up wrong? |
#61 | |
Member#: 82873
#62 | |
Member#: 66611
My only suggestion is to unplug the thermo unit and run a few days without it to be sure its not the thermo unit thats causing your battery to drain. Ive had mine plugged in since i installed it, and my car still starts just fine. I leave mine on exterior temp and voltage since i dont really need the time. But i do leave the batteries in it so the car doesnt have to be on to see the exterior temp. So far temp has been fairly accurate, onyl fluctuating slightly +/- .3 degrees which is well within the acceptable operating function spec'd in the instruction sheet. |
#63 |
Member#: 73197
International
anyone have the problem where the thermo unit just resets itself? mine just rests every now and then! its a pain in the ass taking it off and adjusting the time and i dont want to resort to drilling holes so i could adjust witout taking it apart
#64 |
Member#: 27620
so i know someone already warned me about this, but i was taking out the rubber plug, and accidentally pushed it into the engine bay somewhere. where is it? i can't find where it goes anywhere. and i also need to know where that hole is for when i feed the temp probe through.
#65 |
Member#: 51588
SCIC
Vehicle:2006 WRX TR 1997 Supra Turbo |
Did you check under the car?
#66 |
Member#: 27620
hehe, yes. i can't see it anywhere
#67 |
Member#: 34067
NESIC
Vehicle:1995 240SX Black |
Great mod!
I just stopped by my local Rat Shack and picked up 2 of them (I plan on ripping one apart and swapping out the light with some Red or Blue LEDs to match my dash or CD player) I have my CD player up in the location of the factory clock so I was thinking about placing it down under the ash tray instead. as for the probe, has anyone found a really good location for it yet? I have a replica STi grill with no emblem so that location is out. Thanks again for the great idea! |
#68 |
Member#: 27620
i fed mine up to just next to where the driver side wiper is. it is an excelent place, sheltered under the top corner of the hood. does anyone know if the temp sensor can get wet?
#69 | |
Member#: 19674
TXIC
Vehicle:2006 Baja Turbo 4EAT Brilliant Silver Metallic |
Good idea... I may steal that... thanks. And yes the external temp sensor is water proof... at least that is what the instructions claim. ![]() |
#70 |
Member#: 1983
RMIC
I fed mine to the driver's side mirror and placed it on the side of the mirror base (the black part). It's been raining and snowing here and no problems with the temp readings.
#71 |
Member#: 34661
I put my temp sensor behind the oval "i" badge, because this is close to where the factory temp sensor sits. But after driving and parking, it gets major heat soak and gives way high readings. I need to move it somewhere out of the engine bay but not in direct sunlight.
The sensor is apparently weatherproof, according to the manual. |
#72 |
Member#: 27620
mine reads high after sitting as well, but after a few min of driving it's fine
#73 |
Member#: 51588
SCIC
It probably reads high from the heat of your engine venting out the front of the grille.
I wish I could do this with my car. I've already taken up the space with my iPod mount, so no dice. I've been considering moving it to the retractible cupholder, however. |
#74 |
Member#: 82873
i ran my sensor up through the hood scoop. Works great. My biggest misreadings seem to be the internal temp. Other than that, i like the mod.
peace. |
#75 |
Member#: 82536
Vehicle:2002 Impreza WRX Blue |
I don't want to have to go through removing my stock clock pod so I just want to mount it above my rear-view mirror, is there still a way to get the power hooked into the system up there somehow? I am already using the auto-dimming mirror so maybe I could tie into that somehow? Also if there isn't how long do the batteries last if I just run it off of them?
| Thread Tools | |
| Display Modes | |
| Would replacing my helper spring with a stiffer tender spring make my car ride better | vision.dynamix | Brakes, Steering & Suspension | 1 | 02-07-2010 03:44 PM |
| what did you replace your stock speakers with. | gindobuck | Car Audio, Video & Security | 42 | 03-29-2009 10:06 PM |
| WTB '04 STI Trunk With Wing or Swap 4 My Stock Trunk With Stock Spolier | jester5 | Tri-State Area Forum | 26 | 12-23-2004 10:57 PM |
| Finally replaced my stock hu | skyhawk | Car Audio, Video & Security | 15 | 02-13-2004 03:37 PM |
| Should I replace my broken tranny with another stocker or upgrade to Sti Gears? | agent007kimball | Transmission (AT/MT) & Driveline | 0 | 06-15-2003 04:44 PM |
