Old 03-30-2005, 07:58 PM   #76
Capazo7205
Member#: 83893
2002 WRX Wagon
I wonder if there is a way to make the thermometer display red or if there is one that comes with red display so it will match all my other lights when i change them
Capazo7205 is offline   Reply With Quote
Old 04-01-2005, 07:44 PM   #77
Soyelflaco
Member#: 46336
2013 BRZ
Soyelflaco is offline   Reply With Quote
Old 04-01-2005, 10:07 PM   #78
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Originally Posted by paultg
I located the sensor behind the fog lamp (in the lower fender area, it sticks upside down to the frame that supports the battery tray).
Paul G.
I don't have any issues with wind or with engine heat while I am moving. If I am stuck in traffic the location seems to pick up the higher heat levels down by the pavement (via exhaust and probably my engine bay).
To access the area I am talking about you can either remove the fog lamp and/or pop out the part of the fenderliner near the bottom of the bumper.
Paul G.
paultg is offline   Reply With Quote
Old 04-02-2005, 03:06 PM   #79
jjimpreza
Member#: 1269
2000 RS to WRX
to Forester to LGT to GF8
Question
Awesome Mod!!! Just as good as the Mechanical CEL fix! Off to Radio Shack I go, now I need to buy a Dremel any suggestions? (I know nothing about Dremels)
Also just curious does anyone know where they mount the temp. sensor on cars that come with one stock??
UPDATE: Another thing I wonder after picking this up is how are you going to be able to update the clock once it's installed in the car? The clock adjustment is on top of the unit and seems that once it's installed you won't be able to adjust it.
Thanks for the mod!
jjimpreza is offline   Reply With Quote
Old 04-02-2005, 09:20 PM   #80
npreston
Member#: 82873
2004 WRX Wagon
Thanks for the mod!
i used L brackets, that i mounted underneath the unit, rather on top, which is where the clock adjustment buttons are located.
npreston is offline   Reply With Quote
Old 04-02-2005, 10:12 PM   #81
jjimpreza
Member#: 1269
2000 RS to WRX
Do you have a pic, I don't quite understand does it slide out for adjustment
Old 04-03-2005, 01:27 AM   #82
npreston
Member#: 82873
2004 WRX Wagon
i don't, sorry. I've had batteries in the thermometer for a while, and i haven't had to reset the clock feature, so i'm really not that concerned about it. It wouldn't be that hard to take it off the L bracket and access the time buttons if i really needed to. I think it's a great mod for 10 bucks and some dremel work!
peace.
Old 04-03-2005, 03:38 AM   #83
jjimpreza
Member#: 1269
2000 RS to WRX
Yeah I hear ya. I am not knocking the mod just looking at all aspects. Thanks
Old 04-03-2005, 11:11 AM   #84
npreston
Member#: 82873
2004 WRX Wagon
No problem bro. Good luck and have a great day!
Old 04-03-2005, 11:14 AM   #85
DJ_STI
Member#: 56826
2006 Subaru Evo IX
Cute & FABULOUS Miata
I believe on my parents mercury Mountaineer(ford explorer) it is between the door jam on the drivers side.
DJ_STI is offline   Reply With Quote
Old 04-03-2005, 12:05 PM   #86
jjimpreza
Member#: 1269
2000 RS to WRX
Wink
Originally Posted by twistedsymphony
Great mod!
I just stopped by my local Rat Shack and picked up 2 of them (I plan on ripping one apart and swapping out the light with some Red or Blue LEDs to match my dash or CD player)
I have my CD player up in the location of the factory clock so I was thinking about placing it down under the ash tray instead.
as for the probe, has anyone found a really good location for it yet? I have a replica STi grill with no emblem so that location is out.
Thanks again for the great idea!
Yeah I thought about this idea too because I want to put a gauge pod up where the factory clock is. I haven't measured it yet but I bet it will fit below the ashtray, looks to be perfect . Then I figure you'll still be able to adjust the clock without having to take it back out. Also I am not a smoker (and I don't use the ashtray) so I plan to use the wiring from the ashtray light to wire up this device. I'll post some pics when I get this in.
Old 04-04-2005, 02:20 AM   #87
Soyelflaco
Member#: 46336
2013 BRZ
I finally got it all set up just perfect yesterday...with double stick tape and duck tape. Got it perfectly straight.
I decided to install the outside temp sensor inside the right fender, since there is where the car breathes.. I just wanted to know how hot it really is in there. (It gets pretty hot in Miami's traffic.) So I call it my "air intake temp meter" and my inside one my "dash board temp meter".
It looks very nice and very stock. The green ligth is just perfectly dim and yet you can read it.
I don't know if I can get used to the constant green battery light. I think I'm going to have to cover it or dim it somehow.
I also got the batteries so I didn't have worry about the time, you know, now that it is just right.
My wife couldn't understand why I got so mad when she reminded me this morning to "move forward one hour" all the clocks in the house.
I missed the memo.
Old 04-04-2005, 08:44 PM   #88
npreston
Member#: 82873
2004 WRX Wagon
I missed the memo.
Now, let's talk about those TPS reports..........
Old 04-04-2005, 10:31 PM   #89
AWDBat
Member#: 1983
2008 STi
Dark Grey Metallic
Ha, ha.... Office Space.....
AWDBat is offline   Reply With Quote
Old 04-05-2005, 10:11 AM   #90
npreston
Member#: 82873
2004 WRX Wagon
You know, the nazi's had pieces of flare they made the jews wear!
Old 04-06-2005, 10:15 AM   #91
DoggoD
Member#: 84239
2005 2.5 RS
Regal Blue
I stuck the sensor right to the underside of the front emblem. It is very accurate,.. when I drive by the temp displays at like banks and stuff, it is always within a couple degrees.
I just wish there was a way to get all of the heat out from under the dash, because the temp under there often gets in excess of 110F, and sometimes the tape adhesive gets week and causes the unit to sag.
DoggoD is offline   Reply With Quote
Old 04-07-2005, 08:45 PM   #92
npreston
Member#: 82873
2004 WRX Wagon
That is my ONLY beef with this mod. I'm trying to figure out a way to block the heat with something lightweight, and heat absorbent. Something to shield the interior temp sensor. I'm open to suggestions.
Old 04-08-2005, 08:50 PM   #93
Teufelhund
Member#: 24792
02 WRXwag, Evo IX
Both Vishnu Tuned
When I did the installation I followed the instructions that were listed to put the black w/ white stripe into the #4 accessory spot and the ground to the #2 ground spot. Problem was, the unit stayed on with the key out of the ignition. I saw that this could possibly drain my battery so I switched the black w/ white stripe wire to the #1 batt spot and everything seems to work as it should... the thing is off when the key is out or off.
I also noticed a problem with setting the clock. I used JB Kwick to put the thing in place... damn. So I got to thinking and I remembered an old indian trick...that I could reset the clock by pulling my neg of the battery and putting it back on at either 12:00 AM or 12:00 PM. Heh! I also would be resetting my Ecutek in the process.
Teufelhund is offline   Reply With Quote
Old 04-10-2005, 12:12 AM   #94
Teufelhund
Member#: 24792
02 WRXwag, Evo IX
Both Vishnu Tuned
PROBLEM!! I didn't thoroughly test this mod long enough. My car almost didn't start after 12 hours of sitting today using the set up I suggested before! I'm in a rut guys...
If I used the #4 "accessory" port for my hot (black/white) wire and #2 for "ground" (black), the display stayed lit constantly with the key out thus putting a constant small drain on the battery and...
If I used the #1 "battery" port for my hot wire, the display would light up when the headlights were OFF, and it would not light up with the headlights ON, and it drained the battery. Kinda counter productive. ***!
Any suggestions?
I know- look at the plug from the right perspective and the original instructions will work! Derr. Black/White - #4 ACC and Black - #2 GND. Works like a charm.
Old 04-11-2005, 09:12 AM   #95
PA_02RS
Member#: 82225
2006 VW Jetta GLI
Reflex Silver
Hey Guys.
I just did this mod last night. If you take apart the stock clock harness, you will see four wires - battery (always on), ground (black), light (pink with a blue stripe I think) and accessory.
You want to put a battery in your clock, then hook the clock/thermometer to the ground and the pink wire with the blue stripe labeled (LIGHT) in the factory clock harness. Just tape up the others, they aren't needed. If you wire this correctly, the clock/thermometer will light up only when the headlights are on (just like OEM). It won't drain your battery because there is no power to the unit when the headlights are off. The clock and thermometer will still work however, because it uses the internal battery. Don't use accessory or battery wires.
I tested all the wires in the clock harness using a voltmeter to deduce this, but if you look at the back of your factory clock, you will see labels for each wire.
I still need to run the temp sensor to somewhere outside the cabin - didn't quite get there yet. And I will probably need to get some real double sided tape or velcro to mount the thing better (I just taped it in).
Oh yeah, FYI - make sure you disconnect teh battery before messing with the wiring (don't want to blow a fuse like I did -- duh).
I'll try to get some pics up when I'm done. It's a great mod for ten bucks...
PA_02RS is offline   Reply With Quote
Old 04-12-2005, 07:04 PM   #96
pmartell12
Member#: 23718
2002 wrx
World Rally Blue Pearl
here's the one that I ordered.... http://www.radioshack.ca/estore/Prod...roduct=6311500
I hope that it lights up green!!
pmartell12 is offline   Reply With Quote
Old 04-12-2005, 07:06 PM   #97
CletusTheDwarf
Member#: 27620
2009 Subaru WRX
I am having a hard time getting the display to stay put. I taped it a lot using electrical tape, but i keep getting into the car and finding that the guage has falled down into the dash, anyone find some good solution?
CletusTheDwarf is offline   Reply With Quote
Old 04-13-2005, 02:17 AM   #98
Ben Crowson
Member#: 71574
Try a strip of duct tape and some hot glue......worked great for me and not totally permanent like super glue or something!
Ben Crowson is offline   Reply With Quote
Old 04-13-2005, 09:46 AM   #99
npreston
Member#: 82873
2004 WRX Wagon
I used 2, two inch "L" brackets, which holds the unit in place, firmly against the pod. I did have to bend the brackets slightly, to get the right angle. Then, i used outdoor, extra strength double sided 3M tape (got at home depot, designed to mount exterior items on your house, building, etc.)
Secured the "L" brackets using the double sided tape. Did this last week, and the unit has not moved a centimeter. All in all i spent 8 bucks at home depot, and problem solved.
I was having the EXACT same problem as you, when i would get in the car after a couple hours of sitting, and the unit was completely disconnected from the pod. Sinse i beefed it up a little, i havent a had a single problem.
I can send you pics if you still are having problems.
Hope this helps!
peace.
Old 04-13-2005, 09:54 AM   #100
CletusTheDwarf
Member#: 27620
2009 Subaru WRX
yeah, if you could take a few pics of your setup, that'd be helpful. thanks!
Would replacing my helper spring with a stiffer tender spring make my car ride better vision.dynamix Brakes, Steering & Suspension 1 02-07-2010 03:44 PM
what did you replace your stock speakers with. gindobuck Car Audio, Video & Security 42 03-29-2009 10:06 PM
WTB '04 STI Trunk With Wing or Swap 4 My Stock Trunk With Stock Spolier jester5 Tri-State Area Forum 26 12-23-2004 10:57 PM
Finally replaced my stock hu skyhawk Car Audio, Video & Security 15 02-13-2004 03:37 PM
Should I replace my broken tranny with another stocker or upgrade to Sti Gears? agent007kimball Transmission (AT/MT) & Driveline 0 06-15-2003 04:44 PM
