Old 03-10-2005, 08:47 PM   #1
Hazdaz
Member#: 14611
Default We have "glass" trannies.. but do we also have...
"glass" axles too? I just replaced my left front axle on my 02 WRX cuz on Saturday I started hearing the dreaded clicking sound when I took a tight left turn. I took the wheel off - boots were intact and looked fine.
Dealer replaced the whole 1/2 axle, not just the CV joint - he said that it can be caused by hard acceleration (which doesn't make a ton of sense really, since if your accelerating at a light your going straight, not turning). My car has "only" 65k miles on it. Now the fear is that I will have to drop another $500+ to do the right-side soon. Now I definitly don't drive it super hard, but I do enjoy taking it around curvy roads, and its only lightly modded - so not a lot of extra HP above stock.
Is this a common issue? Or just a fluke? I feel like I am now driving with a ticking time bomb that is ready to cost me lots more $$ or even possibly strand me someplace if the right fails completely.
Posted it here cuz teh OT has lots more traffic than anywhere else.
Hazdaz is offline   Reply With Quote
Old 03-10-2005, 08:49 PM   #2
Brad Pittiful
Member#: 34931
IB2seriousreplies-vs-100bull****replies
Brad Pittiful is offline   Reply With Quote
Old 03-10-2005, 08:49 PM   #3
ErikAnderson
Member#: 26739
i have glass eyes.
ErikAnderson is offline   Reply With Quote
Old 03-10-2005, 08:52 PM   #4
dr_wheel
Member#: 60106
I eat pieces of
** like you for breakfast
dr_wheel is offline   Reply With Quote
Old 03-10-2005, 08:57 PM   #5
Hazdaz
Member#: 14611
^^ I'm axing a question.
Is this like a "known" problem that I should be concerned about... if it was a fluke, then it was an expensive fluke, but a fluke none the less. I was just espesially concerned cuz the left failed at 65K, but the right has the same number of miles... is ~65k the life of a CV joint?
Old 03-10-2005, 08:58 PM   #6
skrib09
Member#: 39077
2004 wrx
no but seriously the technical forum does get a lot of traffic.
skrib09 is offline   Reply With Quote
Old 03-10-2005, 08:59 PM   #7
dr_wheel
Member#: 60106
I eat pieces of
definately not. i've seen them go around the 80-100k mark though.
Old 03-10-2005, 09:02 PM   #8
SailRacer
Member#: 70211
2008 Legacy Limited
Some kind of silver.
Why do I keep reading magazine articles about Subie WRX and STi buildups where they add all kinds of horse power and do nothing to the tranny because they don't see the need?
Is the whole Subie "weak tranny" story an internet myth?
SailRacer is offline   Reply With Quote
Old 03-10-2005, 09:04 PM   #9
quentinberg007
Member#: 7887
Its weakness is best exposed by a bad driver.
Haz, that is really expensive for an axle replacement, IIRC. I thought they were around $200/side maximum.
~~Quentin
quentinberg007 is offline   Reply With Quote
Old 03-10-2005, 09:05 PM   #10
ErikAnderson
Member#: 26739
there are rumors on the internets about weak wrx transmissions, indeed.
Old 03-10-2005, 09:13 PM   #11
Hazdaz
Member#: 14611
~~Quentin
See, this one guy at work - that works on cars on the side figured about $300 for a CV joint at a regular garage. Now I don't know enough about these parts to know if replacing just the CV joint would have been cheaper or if it is just easier to replace the know darn axle. Ofcourse this being a dealership, I just knew it was going to be alteast $500.
Old 03-10-2005, 09:34 PM   #12
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
A new WRX axle (half-shaft) costs $275 from subaruparts.com. 20 minutes might be a long time estimate for it. $500? Hosed. You can replace parts of the axle, but given the time it takes to do it, it's cheaper usually to just replace the whole axle. I'd call it a fluke.
There is a TSB about rear STI axles, because guys who like to launch them off the rev limiter started breaking them.
Old 03-10-2005, 10:07 PM   #13
aod
Member#: 7121
Have you ever actually replaced a half-shaft before? It's definitely NOT a 20 minute job. It's a PITA, but not anywhere near as bad as replacing just a CV joint itself.
Normally what kills CV joints early is by making full lock turns often. Maybe every day you leave your driveway you always turn full lock for a bit of a distance, or something of that nature? If so, stop it.
aod is offline   Reply With Quote
Old 03-10-2005, 10:33 PM   #14
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Replace a WRX axle? Many times. You can replace a rear one in less than 5 minutes, the fronts don't take much longer.
Old 03-11-2005, 12:18 AM   #15
aod
Member#: 7121
I've never replaced one on a WRX, but I've replaced one on a VW Scirocco and it sucked. I dunno why, but I just kind of figured all front axles are a bitch to replace.
Old 03-11-2005, 12:47 AM   #16
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Are you lowered?
crash is offline   Reply With Quote
Old 03-11-2005, 01:04 AM   #17
captaintaco
Member#: 72290
glass transexuals?
captaintaco knows nothing about cars
captaintaco is offline   Reply With Quote
Old 03-11-2005, 06:22 AM   #18
Hazdaz
Member#: 14611
Originally Posted by crash
Are you lowered?
Yes, my car is lowered. This guy at work mentioned that a lowered car actually puts a little less stress on the CV joints - but more on the suspension bits. Not sure if that was accurate or not.
Old 03-11-2005, 06:31 AM   #19
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
I've got 3 very low mileage WRX front axels sitting in my basement.
Name your price plus shipping and their yours....
mr2guru is offline   Reply With Quote
Old 03-11-2005, 06:51 AM   #20
MilesFox
Member#: 64965
87 87 RX 95 Legacy
duplicolor, aluminum
well if you beat the piss out of your car things will need services. wait till you have to do the timing belt. after all its a subaru. if you drive a subaru you should try getting you rhands dirty! its expected at leas with older subarus
axle preak all day, i can change one off the side of the road in 10 minuttes with a handfull of tools. aty least with your model they fit on a splined spindle instead of being pressed thru the wheel bearings like the older ones.
i say go get a new axle for what, 150 bucks? order for a 90's model impreza it may be cheaper that way
go get a 19 mm wrench, a 17mm, a ball joint fork, a 3/16 punch ans a 34 mm socket, now you can do axles all day! and now you have almost all the tools you need to work on the whole car. (8,10, 12, 14mm) subarus are easy
MilesFox is offline   Reply With Quote
Old 03-11-2005, 08:20 AM   #21
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
It could be when your turbo spooled up at 12 mph.
blaster88 is offline   Reply With Quote
Old 03-11-2005, 08:21 AM   #22
Grap
Dicky Nipperist
Member#: 6590
Originally Posted by dr_wheel
Incorporeal, Bioch!!
Grap is offline   Reply With Quote
Old 03-11-2005, 09:33 AM   #23
Matt K
Member#: 45204
16 you don't
respond to danger
yeah, $500=hosed. Learn to do it yourself, it's not particularly hard.
Matt K is offline   Reply With Quote
Old 03-11-2005, 09:57 AM   #24
happasaiyan
Member#: 37731
i launched at 4500rpms + on crappy track + didnt check [low] tire pressure = wheelhop = broken rear half shaft.
not at redline, but user error, definately. i didnt even ask about warranty replacement, i paid for my playing.
what does the TSB say?
happasaiyan is offline   Reply With Quote
Old 03-11-2005, 09:59 AM   #25
happasaiyan
Member#: 37731
i have done everything on my car except that rear half shaft...
...i was reading the service manual on how to do it and saw that it had some special tool in there to do it, and didnt know if i would get myself into a bigger mess if i tried to do it without the tool. now i know...if it happens again, ill just do it myself.
btw-i paid 700 for parts + labor for the rear halfshaft. i also have a distinct whining at 35 and 65 mph since they did the work. ah well.
When do we get to have a thread where we can talk about WBM 2007? KD7000 New England Impreza Club Forum -- NESIC 300 06-17-2007 07:48 AM
"I do wish we could chat longer, but I'm having an old friend for dinner." Ripper Off-Topic 10 01-13-2006 10:40 PM
We have great news - but she ruinied it AGAIN! sonicblue Off-Topic 32 09-12-2003 02:19 PM
What do we have to do?? EvasionOfTruth Mid Atlantic Impreza Club -- MAIC 6 10-02-2002 08:00 PM
If you have the gauge pack, do you still have a clock??? loanshark Newbies & FAQs 7 07-25-2001 09:57 PM
