Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 03-10-2005, 10:18 PM   #1
ranger5oh
Member#: 77752
5Sti 2005 Sti
Default My F$#%ing Accessport Doesnt WORK!
Yep... got my AP and streettuner today and....
1. Tried installing streettuner on laptop #1, and got error trying to connect to device
2. Tried installing streettuner on laptop #2, and got error trying to connect to device
3. Tried installing streettuner on laptop #1 with usb-serial connector,and got error trying to connect
4. Called Cobb, they told me it was my computer (didnt believe them, but whatever), and then they told me to call my computer tech support.
5. Called computer tech support, and they couldnt find any reason why the COM ports wouldnt be working
6. Retried both laptops
7. Tried Desktop computer... same error.
At this point I have now spent like 2.5 hours on this crap. I just want it installed.
8. I go out to my car and try reflashing my ECu, and the AP says.. "Initializing . . . . . ." then tells me to turn off, and back on. Then says "Initializing . . . . . " then turn off and back on. Then says "Initializing . . . . . " Then turn off and back on...
Is anyone noticing a pattern?
So anyway, it is F'ing broken. Now Cobb is closed and I have wasted 3 hours of my night when I could have been installing my new gauges. I AM PISSED.
I guess I am calling Cobb tomorrow, hope they overnight me a new one!
Ciao,
a.
ranger5oh is offline   Reply With Quote
Old 03-10-2005, 10:36 PM   #2
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
hey, i had the same error message when trying to connect my ap to my laptop.. Dell Inspiron 5100 using usb to serial. Ended up having to connect it to a desktop computer.. and now i cant live tune, so i cry myself to sleep.
03WRX83 is offline   Reply With Quote
Old 03-10-2005, 10:39 PM   #3
astrotrain99
Member#: 29384
2005 Forester XT
I don't know about the computer connection problems, but for initialization problems with the car you can try to turn the car into on position (you should hear fans cycling, etc.) before connecting the AP. Some of the 04+ WRXs have to do this, I don't know about the STIs though.
astrotrain99 is offline   Reply With Quote
Old 03-10-2005, 11:41 PM   #4
blackwrecks
Member#: 46311
2004 Impreza WRX
JBP
hmmm . . .
ActiveSync or HotSync running on either of the computers?
They like to monopolize serial ports.
blackwrecks is offline   Reply With Quote
Old 03-11-2005, 12:56 AM   #5
sandiegowrx
Member#: 41743
I don't know what the problem is... but you do have to marry the AP to your ECU and load a pre-programed map before it will initialize with your computer. I've never had any problems with my AP.
sandiegowrx is offline   Reply With Quote
Old 03-11-2005, 01:31 AM   #6
Gixxerjb
Member#: 48393
'04 STi
Black/Gold
Ranger,
I had similar if not identical problems. Here's what I found out.
-I got the Street tuner software loaded by going to Cobb Tuning site and downloading the AP v1.5. I then tried loading the StreetTuner again and it worked.
After I finally got the software loaded, I had to add the XML upgrade (see Cobb Tuning site) in order to use the Advanced Parameters.
Next issue was getting the ECU initialized. This one is still not resolved for me. Spoke with Cobb and they said it was the cable and are sending me a new one tomorrow (fingers crossed). So far, Cobb has been very helpful and responsive, I just hope it fixes the connection problem I have.
Gixxerjb is offline   Reply With Quote
Old 03-11-2005, 09:46 AM   #7
TheMadScientist
Member#: 23717
2005 Big red
This is not true at all. I was able to conect and upload maps to the AP without marring it to my car.
TMS
TheMadScientist is offline   Reply With Quote
Old 03-11-2005, 09:55 AM   #8
happasaiyan
Member#: 37731
Ciao,
a.
you need to update your AP. go to the cobb site and download the latest update and read about how to reflash the AP.
i had this problem. they originally said it was because i was using a dell...but i dont even have dell software on here (other than drivers).
once i reflashed the AP with the new update, everything worked out fine.
download new map manager
reflash AP
install ST software
connect green connectors on car
plug AP in
marry AP to car (load strettuner update map)
unplug green connectors
plug laptop into obd2
tune away
happasaiyan is online now   Reply With Quote
Old 03-11-2005, 12:26 PM   #9
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
Here is the method I used and I had no problems:
1. Updated AP w/ update off Cobb's website
2. Unmarried AP from car
3. Installed ST on laptop
3b. Married ST to AP
4. Open map manager through ST (do not use the old AP map manager)
5. Removed default map loaded on AP by ST
6. Loaded base map supplied off ST CD (stage 2 in my case) on AP
7. Remarried AP to car
8. Connect laptop directly to car and start live tuning with ST
coolcougar is offline   Reply With Quote
Old 03-11-2005, 01:09 PM   #10
ranger5oh
Member#: 77752
5Sti 2005 Sti
Heres the thing... My AP was never married to my car, it is brand new. I didnt get any map management software, onyl the Street tuner software.
Here is what they told me today.
Go back and try to reconnect the green plugs, apparently there are 2 sets, and the wrong ones are connected on mine. So I will try this after work. If then I can initialize the ECU, it is a problem with all 3 of my computers. Which makes no sense to me... but whatever.
I am downloading the map management software now, and will try this method too.
Ugggghhhh! I just want it to work!
Old 03-11-2005, 01:23 PM   #11
funsti
Member#: 42744
2005 STU STi White
Addicted to AutoX
I had to hold down the up and down arrow buttons while connecing the power to the AP when trying to use it on my computer to update to the latest maps that eliminate that CEL code.
The 05 STi AP instructions say something about choosing a menu option for syncing to computer but it was not showing that option for me. Perhaps that option only shows up after it has been married. Anyway, I found on wrxforum.com about holding the up and down arrows while connecting power and waiting for it to say something like "waiting for PC...". After that it worked fine with the map transport software.
funsti is offline   Reply With Quote
Old 03-11-2005, 01:30 PM   #12
coolcougar
Member#: 19674
It also says that you have to do this in the install instructions... at least mine did...
I didn't see it the first time either.... Funny how first you read the instructions then after something goes wrong you go back and READ the instructions
Old 03-11-2005, 01:50 PM   #13
ranger5oh
Member#: 77752
5Sti 2005 Sti
No.. trust me, i did the whole hold the arrows thing. All it ever says is "waiting for PC".. but my PC never connects to it. I wonder if the cable is bad?
Old 03-11-2005, 02:11 PM   #14
sandiegowrx
Member#: 41743
TMS
this was True in my case. I puchased a used unmarried AP and it would not initialize with my PC. Cobb recommeded marrying it to the ecu first, which I did. Only then would it recognize and initialize w/ my PC. If you go over to Cobb's forum, www.wrxforum.com, you'll see a few posts discussing this issue. Just because it may not have been the case with your car doesn't mean you should make a blanket statement claiming my advice "Is not true at all". We are only trying to help each other here...
EDIT: I just did a quick search and found a few threads... there are many more
http://www.wrxforum.com/cgi-bin/ulti...=000142#000000
http://www.wrxforum.com/cgi-bin/ulti...=001325#000001
http://www.wrxforum.com/cgi-bin/ulti...=001085#000003
http://www.wrxforum.com/cgi-bin/ulti...=000430#000001
Old 03-11-2005, 02:19 PM   #15
happasaiyan
Member#: 37731
read my instructions again. mine was never married to my car either. you DO have to update the firmware in the unit itself, though, first.
Old 03-11-2005, 02:21 PM   #16
WRXsPWN
Member#: 35989
2011 Sti sedan
Same here, i had no options on the menu except base maps until i flashed it to the car and then the rest of the options got unlocked and i could tell it to sync to pc.
WRXsPWN is offline   Reply With Quote
Old 03-11-2005, 03:19 PM   #17
TheMadScientist
Member#: 23717
2005 Big red
I have conected to 2 different AP that were not married to a car. They were brand new units though. I did not want to use the maps shipped with the AP, I wanted to use the updated maps.
Both time I did the hold arrows while powering on and the AP conected without problem both times.
TMS
Old 03-13-2005, 03:06 PM   #18
ranger5oh
Member#: 77752
5Sti 2005 Sti
Ok, figured it out. After all this, They sent me a bad Serial Cable!?!?!!? Wow, of all things to not work. Anyway, with a new serial cable it is working fine.
Old 03-13-2005, 03:12 PM   #19
ranger5oh
Member#: 77752
5Sti 2005 Sti
Is the stage 2 version 1.04 map on there for 91 or 93 octane? If it is just for 91 can we use 1.03 for 93 octane?
Old 03-04-2006, 01:49 PM   #20
DaRealGMan
Member#: 59296
2004 WRX
Ciao,
a.
I'm having the same issues right now. I even did the same thing trying different PCs. The strange this is, I can talk to the AccessPort with the standard Map Manager software (pre-StreetTUNER). But when I run the StreetTUNER CD-ROM, it won't connect. Is this still a possible cable issue? Does the StreetTUNER software require a different style Serial Null Cable?
DaRealGMan is offline   Reply With Quote
Old 03-04-2006, 05:28 PM   #21
-Kevlar-
Member#: 82378
both sets have to be plugged. the passenger side plugs are always connected (or should be atleast).
-Kevlar- is offline   Reply With Quote
Old 03-05-2006, 02:04 AM   #22
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
DarealGman,
You havent yet installed street tuner on your Accessport.
Uninstall map manger (st has one inside).
Go from there.
parker/slc/gc8fan is offline   Reply With Quote
Old 03-05-2006, 08:37 PM   #23
DaRealGMan
Member#: 59296
2004 WRX
Originally Posted by parker/slc/gc8fan
DarealGman,
Go from there.
Thanks! I'll give it a try. It's just a pain that I've already married my Accessport back with my car. Now, I have to un-marry it again to try another attempt at StreetTuner.
Old 03-06-2006, 01:02 AM   #24
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Map manager can monopolize an AccessPort just like other programs can. I'm not sure that would improve your complicted situation but it is a start.
Old 05-30-2006, 08:13 PM   #25
subaruwrx420
Member#: 80939
Ok...same issue here. My accessport is stuck on "Waiting for PC." I have done the following:
- verified the accessport has been unmarried because the menu reads "Please choose a new map to FLASH to ECU"
- the accessport can connect to the map manager software
- went to Cobb and downloaded the following update of the map manager software: http://www.cobbtuning.com/wrx/accessport/20index.html
- I install the update and the map manager connects to the accessport
- puzzle...accessport says v1.5 but the update says v1.65...how do flash the accessport with the latest version?
- I tried installing this on two other laptops and get the same problem
- I completely unstalled the map manager software and still have the same problem
- it cannot be the cable because the accessport connects with the map manager software
- the com port is correct because the accessport connects to the map manager
- the accessport itself works as well
HELP!!!
Thanks.
subaruwrx420 is offline   Reply With Quote
AHHHH my parking light doesnt work... Un0RiGiNaL Interior & Exterior Modification 1 11-20-2008 09:39 PM
after my swap... TACOMETER doesnt work azn0boi04 Subaru Conversions 5 09-25-2008 12:19 PM
My OBDII scanner doesnt work... Mk3Design Engine Management & Tuning 12 04-01-2007 12:33 PM
My Cd Player Doesnt Work jchin829 Car Audio, Video & Security 1 07-28-2006 11:13 PM
my trunk release doesnt work ChungerSuby Interior & Exterior Modification 18 05-18-2005 07:25 PM
