Old 03-11-2005, 12:33 AM   #1
H2OSB
Member#: 71310
'06 LGT Sedan
Default Weak, slow right turn signal
I just replaced my headlights on my '97 LOB (with aftermarket, factory style lights). After the replacement, everything seemed to be working fine. Today, however, I find no front right turn signal. The flash is very slow. Dash turn indicatior, and rear light both glow, but VERY faintly (I noticed the problem during the day and thought the dash indicator and rear light were not working, however, at night they are weak but there.). I did a search and found no one with a similar problem. I'm going to replace the bulb with the one I salvaged from the old headlights, however, from what I read, if the bulb was blown, my flash would be too fast.
Any help would be appreciated
H2OSB
H2OSB is offline   Reply With Quote
Old 03-11-2005, 01:21 AM   #2
H2OSB
Member#: 71310
'06 LGT Sedan
Nevermind. Problem solved. Even though the bulb and socket are brand new, it was a contact issue. I simply removed and insert the bulb into the socket several times until there was a bit of scuffing on the contacts. After that, problem was gone.
Thanks any who contemplated helping.
H2OSB
Vibration on slow right turn Robert OB Service & Maintenance 3 05-28-2009 06:45 PM
Front Right Turning Signal Acting Up goldenej20child Electrical & Lighting 1 05-14-2007 12:21 AM
Help: Right turn signal flashing twice as fast... Silver04DE Electrical & Lighting 10 09-09-2004 09:06 AM
impreza front right turn signal lamp White 2.5rs Private 'For Sale' Classifieds 0 07-30-2003 02:28 PM
right front turn signal fuse? soob2k General Forum Archive 1 03-10-2001 02:14 PM
