Old 03-11-2005, 11:19 AM   #1
RodimusPrime
Member#: 82118
2005 GD6 2.5RS
Crystal Gray Metallic
Default new 2005 RS - question on a slight rough idle?
Hi all,
I have a 2005 RS (5spd) with about 400 miles on it. I notice that once the car warms up, when I am at a stop sitting in neutral, I can feel a barely perceptable roughness in the idle. It sits around 500 rpm or so and the needle doesn't move on the tachometer, but I can feel just the slighest little shakiness in my seat, and it's not like a completely regular thing. Seems like every few seconds, but not on a normal repeating patern.
Again, this is REALLY a slight little thing - not a huge shake at all. Am I just being paranoid or should I take this in to get looked at?
Thanks
RodimusPrime is offline   Reply With Quote
Old 03-11-2005, 11:25 AM   #2
Aphex28
Member#: 11506
2015 WRX
Normal.. have you ever had a car with a horizontally imposed engine before?
It moves so much because instead of moving up and down the pistons move back and forth.
Aphex28 is offline   Reply With Quote
Old 03-11-2005, 11:30 AM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
Originally Posted by RodimusPrime
Hi all,
Thanks
I am pretty sure that your car is idling at ~750rpm, the normal value. One "tick" below the 1k mark is 750, two is 500...the tach is kind of confusing this way.
The "shake" that happens every few seconds would seem to be "normal" as mine ('05 RS) does the same thing.
Airboy is offline   Reply With Quote
Old 03-11-2005, 12:02 PM   #4
RodimusPrime
Member#: 82118
2005 GD6 2.5RS
You're probably right about the 750 - i'll check it out next time i'm in the car.
Aphex - this is my first boxer engine, and first subaru! So no, i've never experienced that, but it makes sense.
Thanks for the info guys! My mind is now at ease
Old 03-11-2005, 12:53 PM   #5
Aphex28
Member#: 11506
2015 WRX
Ah well then congratumalations! Because of the different layout of the engine it has some noises you may not be used to, ticking and vibrations
Old 03-11-2005, 08:13 PM   #6
wht052.5
Member#: 79527
2005 2.5RS(I NDTRBO)
Chipped Crystal Gray
Yup, welcome to the boxer club. These idiosyncrasies are what make the Subie's so unique. Off idle, though you won't find a smoother motor.
wht052.5 is offline   Reply With Quote
Old 03-11-2005, 11:25 PM   #7
Caplin 2.5
Member#: 71203
2005 2.5rs
haha everybody has this so called "problem". Its just normal get used to it. the only time you have to worry is when it shuts off.
Caplin 2.5 is offline   Reply With Quote
Old 03-11-2005, 11:40 PM   #8
RodimusPrime
Member#: 82118
2005 GD6 2.5RS
^^ haha ok well that's good to know! Thanks for the welcome guys - I just put up a little post in the newbie section with some pictures of the new ride:
http://forums.nasioc.com/forums/showthread.php?t=732179
Old 03-14-2005, 02:25 PM   #9
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I thought the H4 was supposed to be smoother and more balanced due to its design. Mine is very smooth at idle with the STi EJ20.
garface is offline   Reply With Quote
Old 03-14-2005, 02:43 PM   #10
bobby d
Member#: 77989
2005 Impreza RS
Crystal Grey Metallic
I had a hard time getting used to my 05 RS at first. I went from a quiet little 2001 Civic EX to this growling machine. LOL I like it though, I almost have 3,000 miles on the car and I am used to all the weird noises and the idle problem I had seemed to stop. I think the computer was just getting used to things.
bobby d is offline   Reply With Quote
Old 03-14-2005, 03:55 PM   #11
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Have you been driving a tractor before you got your subi Boxers are nice motors, but smooth? Erm, try V-8 / V-10 / V12... A V6 and many inline 4s are smoother also. The whole point of a boxer is good low end torque and low center of gravity; they are/were never designed to be very smooth, and definitely aren't with only 2 cylinders in each side of the car.
Also, the engine is supposed to idle at 700RPM. Mine stays between 692RPM and 720RPM when warm, usually hovering around 700 - 707 (monitored digitally via S-AFC rpm pickup). If your idle drops below 650 the car will shake. A rough idle is usually a sign of a vacuum leak.
powerlabs is offline   Reply With Quote
Old 03-24-2005, 03:36 PM   #12
wht052.5
Member#: 79527
This is old but, H4's have no balance issues/shafts. other than a rotary there is no other perfectly balanced, and yes, smooth motors that don't have to have some sort of correction.
As for the tractor thing, I have driven old BMW's, Hondas,VW's, Land rovers,
Subies (of course). No john Deere's.
Old 03-24-2005, 04:22 PM   #13
Skidd
Member#: 1853
GC6 Supercharged
STM
Ok.. gotta jump in here...
Boxer engines, along with Inline 6cyls and V12s are naturally balanced motors. Very smooth! I found a great article a long time ago that goes into a fair bit of detail about what motors are balanced and such. I liked it enough, I scraped it from the site, and put it on my server. Her is the link.
http://www.aphkac.com/automotive/tec...ce/smooth1.htm
And specifically, for the Boxer engine.
http://www.aphkac.com/automotive/tec...ce/smooth5.htm
The rough idle issue some (including myself) notice, could be a result of rotational mass. The flywheel holds energy, and if its RPM changes, even just a little bit, you'll feel it in your car. Kinda like when you blip the gas, the car shakes.
Just my .02c worth.
Skidd is offline   Reply With Quote
Old 03-24-2005, 04:51 PM   #14
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
when the ac cycles on and off there is always a bit of a "burble" in the idle.
greg donovan is offline   Reply With Quote
Old 03-24-2005, 04:56 PM   #15
wht052.5
Member#: 79527
[quote=Skidd]Ok.. gotta jump in here...
Thank you.
07 Wrx engine slight rough idle/noise? Myth21 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 10-31-2010 01:00 PM
PRoN Project Car #2: Running on 3 cylinders, rough idle. eurojax Normally Aspirated Powertrain 73 06-11-2008 01:06 AM
New 2005 RS Shifting question tvg Transmission (AT/MT) & Driveline 8 06-05-2005 11:57 PM
New 2005 RS Wagon Help Please dmatthew Newbies & FAQs 12 08-31-2004 09:43 AM
Slightly Rough Idle in New XT XT_Mike Forester Forum 12 04-12-2004 09:57 AM
