Old 03-11-2005, 05:36 PM   #1
hockeygm
Member#: 80681
2003 Impreza WRX
Platinum Silver
Default cams
im thinking of doing cams. should i buy delta cams. or should i save up the money to get a good pair such as TWE?
hockeygm is offline   Reply With Quote
Old 03-11-2005, 06:34 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
hmmm. Delta cams are made by Comp. If you don't think Comp is a good company, definitely buy TWE's...
Old 03-11-2005, 08:00 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
It's as if they are all the same with just a different brand name. I know that they are not all the same. Do some research and find out what your goals are. Different lifts/durations/overlaps are available from each company and all will give different gains at different rpm ranges.
Tim Sanderson is offline   Reply With Quote
Old 03-11-2005, 08:02 PM   #4
hockeygm
Member#: 80681
2003 Impreza WRX
Platinum Silver
o i didint know that. i think ill just save up for TWE
Old 03-12-2005, 11:07 AM   #5
hockeygm
Member#: 80681
2003 Impreza WRX
Platinum Silver
ok i will. im looking for something to give me more gains down low or mid range than up high. i think up high is useless unless you drag and i dont. why are delta so much cheaper than TWE or cobb. i heard they are comparable in performance. does anyone out there have the delta cams? i would love to hear your opinions on them. same with TWE, anyone with them let me know.
Limits of stock JDM v8 cams/valvetrain? frayz Built Motor Discussion 4 10-12-2010 12:50 PM
Scorpion cam. Cow cam. Coyote Cam. Frog cam. Jessie James Off-Topic 3 08-31-2009 01:50 PM
Cams, Cams, and More Cams impr25rs Normally Aspirated Powertrain 35 03-25-2008 08:31 PM
turbo cams or n/a cams flent Normally Aspirated Powertrain 19 04-02-2001 09:00 AM
