Old 03-12-2005, 04:14 AM   #1
dorifto88
Member#: 17684
1989 pathfinder
rusted red
Default grease for steering rack bushings?
i have a set of whiteline steering rack bushings, and recently when i went to a local suby shop they told me i might want to add some grease to the bushings.
anyways, will any kind of grease work? likem will your run of the mill kragen stuff be ok?
sorry if this is a retarded question.
thanks.
dorifto88 is offline   Reply With Quote
Old 03-12-2005, 09:28 AM   #2
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
marine grease? better water resistance..
honestly, i didnt grease mine :\
it doesnt observe the same forces as suspension bushings, but then again an unlubed surface may wear from friction.
psyber_0ptix is offline   Reply With Quote
Old 03-12-2005, 11:38 AM   #3
OneOBS
Member#: 63076
2004 Outback Sport
Red!
If the parts aren't meant to move, don't lube them.
OneOBS is offline   Reply With Quote
Old 03-12-2005, 11:43 AM   #4
Monsito
Member#: 40581
04 STi
Your bushings didn't come with grease? There should have been a packet of grease inside of the bag your bushings came in.
Monsito is offline   Reply With Quote
Old 03-12-2005, 12:19 PM   #5
boxered
Member#: 61884
A yep. If you've still got the original packaging it should be in there. It's a small flat mini-package and I missed it, initially.
boxered is offline   Reply With Quote
Old 03-12-2005, 12:34 PM   #6
stu
Member#: 25768
35R bugeye
Slowbaru
The bushings come with white lithium grease and I would recomend using it, not only does it make the job alot easier but will also keep any squeaks and other noises away. I believe they came with this grease because they are not rubber and are pretty hard poly.
Later Jeff
stu is offline   Reply With Quote
Old 03-12-2005, 12:56 PM   #7
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
I dont like white lithium on poly, I prefer Phil Woods Grease.....
(sold in many bicycle shops around the country.)
LyveWRX is offline   Reply With Quote
Old 03-12-2005, 01:25 PM   #8
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Marine grease or Phil Wood for me as well. Some say they don't need to lube them, Whiteline includes grease with the kit. What do you think its there for? I always lube them when installing them. Poly needs to be lubed to prevent noises.
Arnie is offline   Reply With Quote
Old 03-12-2005, 05:11 PM   #9
dorifto88
Member#: 17684
1989 pathfinder
rusted red
yah i actuallly lost the white lube stuff... i literally have no idea how either.
thanks for the input ill be on the lookout for phil wood or marine grease.
much thanks !
Old 03-12-2005, 10:34 PM   #10
igalwrx
Member#: 13643
'02 WRX Sdn WRB
'05 Leg GT Ltd Wgn Black
much thanks !
You can email whiteline and they'll send you replacement grease right away for free. My alk kit's grease got punctured. I emailed whiteline and they sent me some replacements for free.
igalwrx is offline   Reply With Quote
Old 03-12-2005, 11:06 PM   #11
dorifto88
Member#: 17684
1989 pathfinder
rusted red
Wow, thanks for the info hopefully i will get the same treatment !
Michael.
Old 03-13-2005, 12:44 AM   #12
ashumo
Member#: 51318
89 SVX Syncro
white lithium is my drug of choice
ashumo is offline   Reply With Quote
Old 03-13-2005, 01:13 AM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Michael.
Whiteline's customer service is second to none.
No doubt.
....and if you don't grease poly bushes, they will wear through if there is any realtive motion beteen components.
FS: [WA] 2004 STi steering rack w/bnib whiteline steering rack bushings fraktal Suspension/Brakes/Handling 17 01-21-2010 06:19 PM
Which Steering Rack Bushings for Legacy? whtlegacy Brakes, Steering & Suspension 8 03-06-2005 02:10 AM
Help if you lowered your rack for steering rack bushing installation maxler3 Brakes, Steering & Suspension 19 09-13-2004 02:11 PM
need help with steering rack bushings--can't get drivers side bushing off Mike Wevrick Brakes, Steering & Suspension 10 06-07-2004 12:14 AM
Whiteline Subframe Bushing Kit And Steering Rack Bushing Install North Ursalia Brakes, Steering & Suspension 94 11-04-2003 01:09 AM
