03-12-2005, 10:14 AM | #1 |
Member#: 1274
W. Canada
Vehicle:MY00 BRP 2.5RSTi www.zucru.ca |
what are you swapped RS guys running for a clutch?
I plan on keeping the stock tranny for a bit until i blow it up haha. I am in need of a new clutch soon and will be doing a swap by summer time of this year (hopefully).
I was told i needed a stage 2 clutch of some sort for it to hold the power of a stock or slightly modified usdm 2.0L. what are some of you who have swapped a wrx engine running for a clutch on your stock RS transmissions?
03-12-2005, 11:38 AM | #2 |
Member#: 57809
spec clutch
03-12-2005, 12:36 PM | #3 |
Member#: 48377
Vehicle:1996 Gutted, built XP class Impreza L |
Excedy stage 1 organic. Works great and no problem holding the torque.
03-12-2005, 12:52 PM | #4 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
ACT tranny twister, I think its the street series but not sure, i put down more power than a stock wrx with a 2.2t shortblock and rallispec stage 2 kit.
Jay |
03-12-2005, 01:02 PM | #5 |
Member#: 26067
SWIC
Vehicle:2012 Jetta Grey |
exedy Stage 1...but I'm not getting full power yet. But holds fine so far. there is another company that makes up to a stage 3....forget who...I'll try to look it up.
03-12-2005, 01:11 PM | #6 |
Member#: 2279
South East
Vehicle:2000 Slingshot Pastelito Racing |
ACT Street, barely holding on. They are rated about 310tq.
03-12-2005, 02:57 PM | #7 |
Member#: 17300
NWIC
Vehicle:1993 Widebody Wagon 748whp e98 |
Was running:
Exedy Street (organic) Killed it doing launches with the STi motor in the car. Probably didn't help that I didn't switch the clutch when I went from turbokit to STi motor. Using the Exedy pressure plate with a Clutchnet 6 puck sprung hub metallic disk (it was cheap and seems to be holding fine for now till I can switch to a WRX w/ RA gears or a 6 speed) -Tim |
03-12-2005, 04:46 PM | #8 |
Member#: 1274
W. Canada
awesome! thanks for the input guys!
i am leaning towards the exedy Stage 1, what tq is it rated for? i am more of a solo 2/ hotlap kind of guy. but i wouldn't mind doing a few runs on the drag strip now and then. my understanding is that it would be wise to resurface the flywheel before i throw the clutch in right? I think i will end up throwing a lightened flywheel on the new engine when it comes in =D |
03-12-2005, 04:49 PM | #9 | |
Member#: 1274
W. Canada
anybody else using a spec clutch? |
03-12-2005, 06:37 PM | #10 |
Member#: 57809
well actually its in my friends car. He has a 94 L(RS coonversion) with a jdm ej20g. He has a turbo back exhaust too. Um we estimated that he has around 270hp. Its used for everyday normal driving to school,work, etc.
03-12-2005, 06:50 PM | #11 |
Member#: 54213
Vehicle:2013 Impreza STi Silver |
I have Exedy Stg 1 Organic and it holds no problem. These are my current mods
Complete '03 EJ205 Swap STi RA ver. 4 gearsets w 4.11 FD EcuTek Reflash @ 16psi on 93 Octane - Stock TD04 13T. Delta Dash GTSpec Airsplitter JDM WRX Engine Crossmember STi Ver. 6 Power Steering K&N panel intake filter NGK One Step Colder Iridium SPs. Vishnu IC Hoses Gutted Uppipe B&B 3" Twin Tip Turboback Exhaust Kartboy Exhaust hangers Helix front swaybar endlinks WRX front sway bar Steel braided brake lines Exedy Stage 1 Organic Clutch Exedy lightweight flywheel Autometer 52mm Boost gauge I've burned it a few times, not launching (haven't launched yet with this setup), but trying to back out through thick snow. |
03-12-2005, 07:51 PM | #12 |
Member#: 2604
NESIC
Vehicle:1999 2.5RSt RBP |
ACT street
holds up to 8psi RSt no problem. |
03-12-2005, 11:43 PM | #13 |
Member#: 756
Vehicle:2003 Legacy L wagon 2009 Kawasaki C14 |
I was using a ClutchMasters stage 3 clutch for awhile with my JDM engine. 3 full seasons of auto-x on it, and it just went last oct. Now I'm running the ACT street clutch. I don't like the feel as much, and it seems to overheat easier than the CM3 did. However, it is much more driveable in the cold. The CM3 would shudder quite a bit below about 30 degrees
03-13-2005, 12:04 PM | #14 |
Member#: 1274
W. Canada
seems like the Exedy Stage 1 Organic Clutch and Exedy lightweight flywheel are pretty popular. Anybody have the PN for the combo? how much did you all pay for excedy stage 1 organic??
has anybody dealt with www.clutchcityonline.com before? prices seem pretty cheap compared to some vendors. |
03-13-2005, 02:42 PM | #15 |
Member#: 50193
Vehicle:1999 Rubasu Ziprema Silverthorne |
HorsepowerFreaks.com . They have it for 283.xx!!!!! Shhhh. i didnt tell you either.
03-13-2005, 03:59 PM | #16 |
Member#: 5778
South East
Vehicle:09 135i Jet Black |
for you guys making real power, the Tilton's clutches that people are running on their WRX"s will fit in an RS too.
Brad |
03-13-2005, 04:43 PM | #17 |
Member#: 3362
Vehicle:2001 I've wired a Few cars in my day |
I'm using the Exedy clutch with a Fidanza flywheel. Autocross, track days and hillclimbs have yet to make it slip. I got them from clutchexpress.com. I would steer clear of the SPEC clutch though. A friend of mine had on in his RST and it slipped like mad even though he was only pushing 6psi. The pedal feel of it is very close to stock unlike the ACT or the SPEC.
As far as blowing up your RS transmission goes I wouldn't count on it unless you are pushing insane power though it and doing clutch drops or slamin gears both of which are not good practices with any transmission. Z |
03-13-2005, 05:34 PM | #18 |
Member#: 54213
I got my Exedy clutch from them. I didn't like what they did initially though. They made the regular OEM one look like the Exedy clutch, then when you order that clutch thinking it's the Exedy for $180 they email you saying, we're out of stock of this clutch, but you can upgrade to the Stg 1 for an extra $80. Overall it was still cheaper than most places and I got the product fine, but it was a little deceptive. |
03-13-2005, 05:47 PM | #19 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
A: ACT street
b: yeah super cheep i bought a clutch for a 93 for 144 shipped |
What are you getting the Wife/GF for Christmas | 03WRXSUBI | Off-Topic | 292 | 11-24-2014 01:17 PM |
What clutch are you high HP guys running? | bigmike25rs | Transmission (AT/MT) & Driveline | 9 | 03-13-2010 12:42 PM |
What are you high HP guys running for a clutch? | Patrick Olsen | Legacy Forum | 10 | 03-02-2006 11:09 PM |
What clutch are you FP green guys running? | quickscooby | Transmission (AT/MT) & Driveline | 5 | 03-01-2006 08:06 AM |
What Are You Gonna Get Your Car For Christmas?? | DuoMaxwell | Off-Topic | 67 | 12-25-2003 12:50 AM |
