Old 03-13-2005, 02:29 PM   #1
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Default Cobb Stage 1 93 oct EGT's
ok i did a search last night and couldnt find exactly what i was looking for...
I have a stock 04 wrx running a Cobb Stage 1 93 oct base map, no real-time map is loaded. I got my Accesport about 2 weeks ago and loaded it up around a week and a half ago. I just installed my gauges the other day and finally had a chance last night to do a couple WOT pulls. Max I was hitting was about 14 pounds....no more than that. But my Egt's seemed high..i was right at 1700 F ....i pulled four times up to around 100 mph and hit about 1700 each time. I stopped and looked under my hood, my turbo was glowing pretty good, but what i think was my uppipe was glowing real good, looked like molten steel. I have always run Shell 93 oct ever since i got my car.
So im kinda scared now that im running a little too hot. What are others running with a setup like mine?
slowscooby is offline   Reply With Quote
Old 03-13-2005, 02:40 PM   #2
crazymikie
Member#: 56321
2006 Honda El Camino
Green
I don't think the uppipe cat is rated to withstand those temperatures. I think it's only rated up to about 1650 degrees F.
I'd try reloading the base map to make sure it's okay. I think 1700 is on the high side. You might want to call Cobb on Monday. In the meanwhile, I'd keep a close eye on that gauge.
Just to clarify- this is based on a gauge that is tapped in the header?
Mike
crazymikie is offline   Reply With Quote
Old 03-13-2005, 03:34 PM   #3
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Yeah the probe is right after the 3rd cylinder.
I'll try reloading the map tonight. I figured that the cat was gonna be a problem at those temps. I may call cobb tomorrow and see what they say.
This just makes me want an uppipe and exhaust that much sooner....im never gonna save money this way haha.
cobb stage 2 93 oct help rideWRx2008 Engine Management & Tuning 2 10-17-2008 04:27 PM
AP stage 1 93 oct and the K&N Tyhoon short ram dougkmcse Engine Management & Tuning 0 06-16-2005 06:09 PM
Cobb stage 1 93 oct WrXtaCy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-06-2005 01:30 AM
Cobb Stage 1 and high EGT's pottymouth Engine Management & Tuning 25 01-11-2005 05:10 PM
AccessPort Stage 1 93 Oct - So far so goo root Engine Management & Tuning 0 06-12-2004 07:18 PM
