Old 03-13-2005, 09:19 PM   #1
STIdreamer17
Member#: 68853
'02 WRX
Default Talon Turbo
hey im looking for a TD-05H 16g and my friend has a turbo talon. he said that the turbo on his car is a TD-05h and he will sell it to me, will it fit my car?
STIdreamer17 is offline   Reply With Quote
Old 03-14-2005, 02:28 AM   #2
jake15
Member#: 36662
1990 legacy dohc 2.2
6speed w/ brembos bishes!
it wouldnt be a straight bolt-on affair, and it would cost alot to modify it to work. if you want a *almost* straight bolt-on td05 ( for a ej22t), your going to need one from a 93-96 JDM/AUS WRX/ or STI
jake15 is offline   Reply With Quote
Old 04-04-2005, 12:36 AM   #3
Brandon Clifton
Member#: 68965
1994 Touring Wagon
1995 Legacy L
The only thing about his turbo that is the same as the turbo you're looking for is the compressor wheel and center section. The turbine flanges are different, as well as the compressor inlet and outlet. See below for the differences:
DSM 16G
Subaru 16G
Stock VF11
As far as installation- the turbine side will bolt onto both the uppipe and downpipe. Either the compressor inlet will fit correctly or the outlet will fit correctly- that part is up to you. On the VF11 (stock for the EJ22T), the inlet/outlet are at a 45 degree angle to each other. The 16G's inlet/outlet are at 90 degress to each other. Your options here are: clock the compressor so the inlet fits up with the stock inlet plumbing, then make a custom outlet-to-throttlebody pipe. This is going to be hard because of space considerations. However, if you already have a FMIC, changing the plumbing isn't that big of a deal.
You can also clock the compressor so the outlet lines up with the turbo-to-throttlebody elbow and have a custom airfilter-to-inlet pipe made (which is be the better choice anyway since that will allow you to have a less restrictive intake tract and you can relocate your filter to inside the wheelwell, making it a cold air intake).
I plan on doing this soon. I have a WRX intercooler and will be upgrading to the 16G turbo.
Brandon Clifton is offline   Reply With Quote
Old 04-05-2005, 09:15 AM   #4
burnin4
Member#: 59764
10 sec STi
10 sec Z06
well, I guess that was nipped in the butt. Nice overwhelming info to clarify the difference.
burnin4 is offline   Reply With Quote
Old 04-06-2005, 05:04 PM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
what kind of 16G is it?
i might be intrested in buying it...
snowman4us is offline   Reply With Quote
Old 04-07-2005, 09:18 PM   #6
STIdreamer17
Member#: 68853
'02 WRX
thanks Brandon, that helped me out alot. i didnt think it would work, but i just wanted to make sure so that i wouldnt kick myself later. i looked at the deadbolt td-05h 16g's and they have them modified to fit usdm engines. so i will probably just go iwth that.
snowman4us - its a turbo off his talon, its td-05 14b or something like that.
Old 04-07-2005, 10:38 PM   #7
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
*cough, cough* stock EJ22T= IHI VF11 *cough*
You can buy the TD05H-16G set up for Subaru (straight or 90 degree inlet) brand new from Deadbolt. I got my 90 degree, Monster ported, 16G from Deadbolt and it's sweet. Xtreme black ceramic coating on the exhaust turbine housing and normal grey ceramic coating on the compressor housing.
They also have the TD05H-17C, super 16, 18G, 19C and 20G as well as the TD06H-18G, 19C and 20G too.
http://www.boostplanet.com/product.htm
legacy92ej22t is offline   Reply With Quote
Old 04-09-2005, 12:14 AM   #8
Brandon Clifton
Member#: 68965
1994 Touring Wagon
1995 Legacy L
Ok ok- Vee EFFFF eleven....
Old 04-10-2005, 03:24 PM   #9
STIdreamer17
Member#: 68853
'02 WRX
well hey i have an off subject question, i just put a td-04 on my car and was wondering how a td-05 will compare to that? will there be a size/performance difference between them?
Joe
Old 04-15-2005, 10:45 AM   #10
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
Joe
Yes, the TD05H-16G is much larger and will flow significantly more then the TD04L-13G. The TD04-05-06 ect.. is the exhaust turbine size. The L-H ect.. at the end is the version of the turbine housing (bolt pattern for up-pipe and DP), IIRC. The # then G is the compressor wheel size. Mitsu turbos use G and C designations AFAIK. So the TD05H-16G is one exhaust turbine size up from the TD04L-13G and the compressor wheel is at least 3 sizes bigger.
Old 04-16-2005, 08:21 AM   #11
ncarn8
Member#: 71419
i hope you mean nipped in the bud there
ncarn8 is offline   Reply With Quote
1991 Eagle Talon Turbo AWD eersfanpilot Private Vehicle 'For Sale' Classifieds 0 04-17-2006 05:22 PM
92 eagle talon turbo FWD granteeton Private Vehicle 'For Sale' Classifieds 0 06-18-2005 04:50 PM
97 Eagle Talon TSi - Turbo/AWD marcus12 Private Vehicle 'For Sale' Classifieds 3 07-20-2004 06:46 AM
FS: 1997 Eagle Talon TSi - Turbo & AWD marcus12 Private 'For Sale' Classifieds 0 06-29-2004 04:57 PM
Talon/Eclipse AWD turbo vs. WRX everbruin Motorsports 10 04-11-2002 09:44 AM
