Old 07-20-2001, 12:09 AM   #1
crrii
Member#: 6413
01 Impreza 2.5RS
Silverthorn
Default alternator question
Can anyone tell me if there is a nut that goes on the bolt that mounts at the top right (looking into engine bay) of the alternator? i took off the metal cover that is over the belts to paint it. There is one small bolt that hold it on the left side. On the right side it is forked and that section slides around a large bolt that holds the alternator in place at the top. When i went to put it back on I couldn't get that bolt to tighten up and I then noticed that there is no nut on the end which is at the back of the alternator. Curiously, there is a small bolt on the left side that also has no nut. I circled the bolt in blue....
crrii is offline   Reply With Quote
Old 07-20-2001, 01:35 AM   #2
crrii
Member#: 6413
01 Impreza 2.5RS
Silverthorn
Here is a close up pic of the bolt in question.
Old 07-20-2001, 01:38 AM   #3
Avenger
Member#: 1234
Yes, there is a nut.. The nut is fixed onto a little bracket that help you hold the nut inplace so it won't spin when you tighten the bolt. This bracket have a little tab that sits on the alternator. If I remember correctly the bracket is goldish/brass colour (when new). It probably just fell off when you took off that bolt so it might still be sitting under all the wires.. Hope it help..
Edit: Oh be carefull. The wire with the red cap is live, so try not to damage it..
Avenger is offline   Reply With Quote
Old 07-20-2001, 02:36 AM   #4
crrii
Member#: 6413
01 Impreza 2.5RS
Silverthorn
Thanks Avenger! I found it!!!!
Trunk & Alternator question wrxtreme227 Newbies & FAQs 5 10-22-2004 02:22 PM
Alternator Question urabus97 Legacy Forum 4 04-29-2004 04:39 PM
Alternator Question pkirby11 Electrical & Lighting 1 02-15-2004 02:37 AM
Power/Alternator Questions!!! WhyGog Car Audio, Video & Security 12 02-03-2004 01:00 AM
