Old 03-14-2005, 12:41 PM   #1
wickedscooby
Member#: 55963
99rs sti v5 LISC #57
Default dohc 2.5
quick question i have a 98 legacy wagon with a 2.5 dohc motor. and its pretty noisy on start up. i was under the thought that the dphc is just a noisy motor. my dad tells me the valves need to be adjusted, but i dont think so. what do you guys think?
wickedscooby is offline   Reply With Quote
Old 03-14-2005, 05:00 PM   #2
hungiema
Member#: 45682
1998 legacy 2.5 gt
dark green
mine is pretty noisy too...valve adjustment might be the answer...but dont have money to do that, how much is it to adjust the valves?
hungiema is offline   Reply With Quote
Old 03-14-2005, 06:57 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
If it goes away when warmed up, it's more likely piston slap. I dunno about warantee claims this far out, but it's worth a shot.
Valve adjustment is not cheap on this model motor (DOHC). If you find a dealer who stocks a supply of shims, lemme know.
Jay Storm
Old 03-14-2005, 08:15 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
piston slap...
Old 03-14-2005, 08:22 PM   #5
simpreza2
Member#: 20381
04 Forester X
93 240sx
How much does the dealership usually charge(ballpark figure)?
simpreza2 is offline   Reply With Quote
Old 03-14-2005, 08:22 PM   #6
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Yeah, my 2.5 is noisy in the morning. Especially when it is cold out...
Tkacik is offline   Reply With Quote
Old 03-14-2005, 08:26 PM   #7
Handsdown
Member#: 29355
Originally Posted by Matt Monson
piston slap...
i've heard this in a 01 legacy motor and it sure is noisy sounds like a cattail whip with ball bearings at the end is hitting your hood... take it to subaru, they'll figure out what's wrong.
Handsdown is offline   Reply With Quote
Old 03-14-2005, 08:35 PM   #8
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
If it has oil RUN IT. Most likely it has over 100k? And if you havent done head gaskets you will need to soon. You can decide then if you want to buy a new short block to quiet your engine.
Scoobie Steve is offline   Reply With Quote
Old 03-15-2005, 02:42 AM   #9
wickedscooby
Member#: 55963
yes of course there is oil in it ( just did an oil change) and it actually has 50k on it. awesome shape for $7500. my take on it, is that its just a noisey motor on start up and when it warms up its not as bad. im leaving it. thanx for your info guys. -dave-
95' 2.2 w/ 98' DOHC 2.5 heads? downshift1 Normally Aspirated Powertrain 6 04-20-2007 12:54 PM
1997 Dohc 2.5 with 1997 2.2 Heads? narib2001 Normally Aspirated Powertrain 3 01-23-2007 02:01 AM
Legacy DOHC ? 2.5? MichiganRS Legacy Forum 7 08-22-2001 04:38 PM
('93-'01) DOHC 2.5 owners w/ oil consumption probs, pls reply cakagan Impreza Forum 7 06-28-2001 03:14 PM
SOHC or DOHC 2.5 power difference? MK1ofMnM Normally Aspirated Powertrain 6 05-31-2001 12:17 PM
