Old 03-14-2005, 05:14 PM   #1
Drew888
Member#: 6459
2008 LGT Spec-B stg4
Delicious Tuned 336/336
Default Graphic Gurus...quick question
I need to blow up a 800x600 gif to output to this H.P. plotter at 44".
I have acces, here at work, to Photoshop, Autocad, and Soliworks.
Can one of these convert the gif and output to the plotter?
Drew888 is offline   Reply With Quote
Old 03-14-2005, 05:20 PM   #2
boomtonic
Member#: 27231
Just scale the plot up to fit sheet size at plot time. The app doesn't matter that much. Be aware...800x600 on a 44" sheet will only look decent from about 40' away.
boomtonic is offline   Reply With Quote
Old 03-14-2005, 05:25 PM   #3
sorbee711
Member#: 14259
OT, we're a-holes
b/c we are bored at work
Jack up the resolution in PS. Its not going to look perfect, but hella better than tossing the gif straight there.
sorbee711 is offline   Reply With Quote
Old 03-14-2005, 05:31 PM   #4
Drew888
Member#: 6459
That's really the point...keeping resolution. I could simply raise the res. but sacrifice teh "clarity" of the pic.
To do that it needs to be converted to a vector based format (or was that rastor?). I just don't know how and if any of these programs can do it.
Old 03-14-2005, 05:36 PM   #5
Kaiser
Woodpecker
Member#: 7170
Aut Kaiser,
aut nullus.
I can convert bitmap graphics to vector-based ones in one of my Corel apps (CorelTRACE). I'm sure Photoshop can do something similar.
Kaiser is online now   Reply With Quote
Old 03-14-2005, 05:41 PM   #6
boomtonic
Member#: 27231
Misunderstood your original question. Certain flavors of AutoCAD can do it, and depending on the complexity of the original, straight ACAD can do a pretty good job by using the PLINE command.
I used CorelTRACE way back when with excellent results.
Old 03-14-2005, 05:49 PM   #7
Kaiser
Woodpecker
Member#: 7170
Aut Kaiser,
aut nullus.
Yeah, it's a really nifty app. Here's the NASIOC logo converted to Illustrator format, for example: www.kaiser.dreamhost.com/OT_stuff/nasioc_logo.ai
Old 03-14-2005, 05:52 PM   #8
FiveDoorSVT
Member#: 79933
'03 Mazda Protege5
Yah, youre gonna need to get whatever the gif is redrawn in a program like corel or illustrator. Thats what plotters use, and youll get some crappy jagged lines with a gif or any other img tag like tif or jpg.
FiveDoorSVT is offline   Reply With Quote
Old 03-14-2005, 06:01 PM   #9
Hazdaz
Member#: 14611
Depends on what the GIF looks like - what kind of image it is.
You could just trace the image in Photoshop using Paths and then plot it at whatever rez you wanted it to be. But ofcourfse if its a photo, then its not really good source material for tracing. You could also trace it in AutoCAD, but since you have PS, it would be easier there.
Hazdaz is offline   Reply With Quote
Attn: Juniper router gurus, quick question chkltcow Off-Topic 10 02-28-2007 01:20 PM
OT web gurus....quick question about HTML.. GooseMan Off-Topic 5 06-08-2006 11:34 AM
OT Computer Gurus...quick question az ej20 fan Off-Topic 5 12-15-2004 01:29 AM
Math gurus, quick question... Schleppy Off-Topic 16 11-20-2004 01:49 PM
Brake gurus...quick question BlueWRXagon Service & Maintenance 12 09-03-2003 04:05 PM
