Old 03-15-2005, 11:52 AM   #1
robfajita
Member#: 83040
Default 94 legacy overheating
I have a 94 legacy wagon AWD, 2.2L. It has a tendency to overheat, It used to only do it when I drove it over an hour an a half. Now it happens almost at once. I have already changed the thermostat (twice), new radiator, waterpump, and timing belt. Head gaskets have been tested. No coolant in oil. Nothing leaks. I'm bypassing the heatercore today to see if that changes anything. I cant beleive the heatercore is the problem but Im doing it just to rule it out.
Anyone encoutered this before?
robfajita is offline   Reply With Quote
Old 03-15-2005, 12:08 PM   #2
98imp
Member#: 32316
98 2.5RS
Blackish...
How did you test the the head gaskets? A pressure test may not always find it.
98imp is offline   Reply With Quote
Old 03-15-2005, 10:18 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
check for hydracarbons in the coolant
money says you have a headgasket issue...
jamie
www.subiegal.com
Old 03-15-2005, 11:11 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Did you burp it?
If you didnt, this could cause the overheating. To eliminate burping (which is a pain in the arse), I drill a 1/16th hole in the thermostat so that air and water can seep through and I don't have to burp, much less worrry about it.
I bought a 1990 sedan for $450 because the owner didnt burp it and thought he had blown head gasket(s). I burped it accidentally after I towed it home and never overheated in the next two weeks once. Then the clutch went. Another story.
WTB: 92-94 Legacy NA/93-94 Impreza fuel rails wtdash Private 'Wanted' Classifieds 0 12-27-2008 10:52 AM
1990 legacy overheating confused monco123 Legacy Forum 0 11-10-2007 01:29 PM
91-94 legacy EJ22T(91-94 legacy) Turbo only swap to 97 2.2 impreza?? Impreza_chic97 Subaru Conversions 3 10-29-2006 11:25 PM
MY99 Legacy overheating? flat4NA Service & Maintenance 2 05-20-2002 03:07 PM
Legacy overheating??? flat4NA Legacy Forum 1 05-18-2002 01:21 PM
