Old 03-15-2005, 02:58 PM   #1
Beauner
Member#: 82119
Default need help...
ok i have a sound coming from the back of my 2000 2.5rs maybe coming off the rear left wheel when making right hand turns ... it sounds almost as if something metal is sliding across my trunk but there is nothing back there i've tooken everything out trying to figure out this problem... does anyone have any ideas what could be making this sound ... it doesn't sound good i need to figure it out and get it fixed ... i've only knowticed it making the sound when cornering and turning right ....please help
Beauner is offline   Reply With Quote
Old 03-15-2005, 03:22 PM   #2
m750
Member#: 2278
8Sti | 07 allez
White | Comp
wheel bearing. Go see a mechanic.
next.
AO
m750 is offline   Reply With Quote
Old 03-15-2005, 04:09 PM   #3
Aphex28
Member#: 11506
2015 WRX
could be the bearing.. or it could be the less costly brake dust cover rubbing against the rotor. All you need to do there is take the rotor off and give the cover a rap with a mallet onto a crowbar on the lower part a few times.
Aphex28 is offline   Reply With Quote
Old 03-15-2005, 05:11 PM   #4
Beauner
Member#: 82119
Wheel bearings have been checked and the right one replaced... noise still there.... any other possibilities?
Old 03-15-2005, 08:05 PM   #5
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Have you checked under the spare tire for something sliding around?
just a thought
99subi is offline   Reply With Quote
Old 03-15-2005, 08:20 PM   #6
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
what size tires are you running? If they are 225's then yo might be rubbing.
X4 SRT is offline   Reply With Quote
Old 03-15-2005, 08:54 PM   #7
Beauner
Member#: 82119
ya i went through my trunk took everything out so thats not a possibility... ok onto the tires possibility i'm running 17, 215, 45's .... but my car is lowered a inch on kyb agx struts so i don't know there is that possibility but i thought it might be rubbing already and i can't see where its been rubbing ...
Old 03-15-2005, 10:09 PM   #8
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
^^^^^^^^^^ good thought thats prolly it !
Old 03-16-2005, 02:13 AM   #9
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
yeah i had some 225's 17 45's on my car for a day and i have agx's, i heard the same sound and when i put the stock rims on teh next day the sound magically dissapeared! Ill bet it is the rubbing, good luck.
AS
allsubaru83 is offline   Reply With Quote
Old 03-16-2005, 02:43 AM   #10
Beauner
Member#: 82119
hey allsubaru83 ... do you know where the wheels where rubbing at on your car because this sound did show up a day or two after i put the new rims on... rubbing was my first thought but i couldn't find sign of it rubbing... maybe i'll jack it up and put the old rims back on and take it for a quick run around town see what happens... but if you got that same sound i'll concider that possibility again .... thanks ...
Old 03-16-2005, 07:12 AM   #11
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
If you are rubbing, then it's on the very edge of the fender well. There is a little black strip of rubber linning on the lip of the feder well. Try removing that strip and see if the problem goes away. The strip just pulls off. Should only take you a min to do both sides. If you think you are still rubbing go buy some white shoe polish and put some around the the edge of the fender well. Go out driving and take some fast turns. When you get home see if there is any shoe polish on the tire. If not then you should be okay. If you are still rubbing then you will have to roll your fenders to fix the problem.
Need Help Asap! scoobymuff Southern California Impreza Club Forum -- SCIC 25 06-04-2010 05:12 PM
Need Help 06 legacy 2.5i problem BlobeyeSTi Mid Atlantic Impreza Club -- MAIC 9 06-04-2010 08:53 AM
Need help with something truenosan Vancouver Impreza Club Forum -- VIC 7 06-02-2010 09:05 PM
A/C Pressure switch 94 Leggy? Need Help DjKlown Legacy Forum 2 06-02-2010 05:42 PM
EJ25 build, need help! rcarlson87 Built Motor Discussion 0 06-02-2010 10:36 AM
