Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 03-15-2010, 01:04 PM   #276
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Whoa, OBDII from a standalone? Sign me up. Do want.
BAN SUVS is offline   Reply With Quote
Old 03-31-2010, 01:16 AM   #277
Relax_Tampax
Member#: 161122
Chapter/Region: HIIC
1998 GC8 EJ255 swap
Panda
what is the gm part number for air temp sensor
Relax_Tampax is offline   Reply With Quote
Old 04-06-2010, 03:09 PM   #278
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Sorry I don't know we buy them from Hydra EMS and they don't have part numbers still there.
Element Tuning is offline   Reply With Quote
Old 04-14-2010, 03:59 PM   #279
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
2.7 Estimated Release Date?
RealStreet is offline   Reply With Quote
Old 04-14-2010, 05:07 PM   #280
Element Tuning
Member#: 54918
673 WHP Element
We've already past the ETA.
Don't hold your breath until I get a beta.
Old 04-14-2010, 09:55 PM   #281
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
you can get that sensor from NAPA sensor #ts4015 pigtail #css300
john 1badSTI is offline   Reply With Quote
Old 04-26-2010, 02:26 PM   #282
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
What's the unofficial 2.7 feature list relative to 2.6?
Also, has anyone tried AEM's IAT sensor? I'd like to think it would be fast. While I understand that usage of the OEM IAT in the MAF sensor assembly works fine with the Element maps as they're calibrated for it, I'm too much of a perfectionist to leave well-enough alone. I really would like to get a nice fast IAT sensor that works with the 2.6+ units installed in my FMIC return piping.
jblaine is offline   Reply With Quote
Old 05-03-2010, 04:00 PM   #283
Element Tuning
Member#: 54918
673 WHP Element
If you're a perfectionist leave well enough alone . Let me explain.
When tuning with the Hydra using injector pulse width you are mapping your fuel curve based on boost and RPM for a given setup. As the efficiency of your setup (turbocharger/intercooler) starts to diminish your injector pulse width will not increase proportionally as boost increases. In essence the injector pulse width map is compensating for you change in VE (higher turbocharger outlet air temps). All the IAT does is apply a correction for ambient temperatures so that when it's hotter and oxygen content is less you reduce fuel and when it's cold you increase fuel.
Now you say I get it but why not measure it after the intercooler anyway? Because on a turbocharged engine for every +1 degree in intake temperature you don't get a +1 degree change in intercooler outlet temperature. Also we have found heat soak at the sensor to be a major problem often resulting in a temperature reading that is wrong and slow to react which is the opposite of what you're trying to achieve.
2.7 what's 2.7? The unoffical benefit list is huge but at this point it might as well be vapor wear until I receive a beta. I'll tease with a few options:
Dual DBW Throttle control
Quad closed loop cam control
DBW Cruise control (cable cruise control has always worked)
Si Drive functionality on the newer cars
OBD2 on board diagnostics and therefore emmissions compliance
Gauge kits
On board data logging
User upgradeable flash
New tuning strategies based on what I and other dealers wanted
Just realize you won't get all of that and more for the same amount of money. We'll offer similarly equiped Hydras at similar prices and for all the bells and whistles a higher price. The nice this is that every Hydra will be scaleable so let's say you don't need the OBD2 compatibility option so we won't charge you for it but should you want it in two years you can pay for the upgrade, etc.
This way we can keep affortable options for people who don't need everything. For many people the standard on board data logging will be enough but for racers like me I will be able to pay for a memory upgrade for hours of data logging ability.
Still no release date yet other than this year sometime.
Thanks,
Phil Grabow
Old 05-04-2010, 11:40 AM   #284
DatDude
Member#: 96157
2000 Impreza RS-T
Silverthorn Metalic
I know that the OBDII function is surely going to open doors for the new car owners or fair weathered cars that haven't met that 25+ year mark to not be emissions compliant or maybe thats a Texas thing
DatDude is offline   Reply With Quote
Old 05-04-2010, 12:20 PM   #285
Element Tuning
Member#: 54918
673 WHP Element
Yeah I think moving on into the future of stand-alone engine management it's going to be an option that pushes the Hydra up a notch for the average enthusiast. There have always been work arounds for the creative but now that won't be required.
Also the OEM CAN bus support is also another feature that will advance the system allowing 100% functionality of OEM systems.
Old 05-04-2010, 01:26 PM   #286
DatDude
Member#: 96157
2000 Impreza RS-T
Silverthorn Metalic
The more options the better. I will be glad to hear when the new update posts! I emailed you already today about becoming a Hydra owner
Is the CAN Bus on all the units or is this going to be a modification in the future?
Also is this what connectes to the Digital Dashes that are availble?
Old 05-10-2010, 02:43 PM   #287
Element Tuning
Member#: 54918
673 WHP Element
The CAN chips have been on many of the newer units but I don't know that every model will be equipped in an effort to reduce costs for certain applications in the future.
Currently the AIM Sports dash is via the serial cable.
Old 06-10-2010, 12:40 AM   #288
STIStalker
Member#: 92783
2004 WRX
I'm running a Hydra in a 04 WRX with a STi long block and am attempting to hookup the avcs.
I already have the wiring diagram to do it but I can't find any place that sells the correct terminal connectors that go into the hydra's wiring harness.
Anybody know what they are called?
I went to radio shack and they said they don't sell anything like that.
They are flat on the side that plugs into the ems.
How has anybody else done this? Just tape the wire in there or something?
I'd like to do it the best possible way.
Thanks.
STIStalker is offline   Reply With Quote
Old 06-10-2010, 12:53 AM   #289
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
You may need to rob them from an AVCS engine wiring harness.
Old 06-10-2010, 01:12 AM   #290
STIStalker
Member#: 92783
2004 WRX
Ok well I was talking about the terminal's that plug into the hydra's location, but yea I'm trying to figure out what to do for that end as well but I don't think it will be as hard.
I wonder if I could order the plug from the sti's harness that plugs into the avcs solenoid from somewhere?
Thanks though.
Old 06-10-2010, 08:06 AM   #291
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Originally Posted by STIStalker View Post
...the correct terminal connectors that go into the hydra's wiring harness.
They're GM ECU/ECM pins. Call your local NAPA stores and bring one with you to size it against their stock. I found them available after the 3rd NAPA store...
Uh, no
Old 06-10-2010, 05:39 PM   #292
john 1badSTI
Member#: 77470
here is the part# from napa--725159 in their belden line.
Old 06-10-2010, 06:45 PM   #293
STIStalker
Member#: 92783
2004 WRX
That is it!
Thanks VERY MUCH!!
Here is a link to order online if your Napa Store doesn't have them. None of my napa's had them in stock and I would have to buy 25 at a time at $1.07 each. http://www.clipsandfasteners.com/GM_...e_p/a14883.htm
Old 06-11-2010, 03:29 PM   #294
tenchu
Member#: 64147
1993 STi RA V LTD
Green
tenchu is offline   Reply With Quote
Old 06-11-2010, 07:13 PM   #295
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Old 06-14-2010, 03:56 PM   #296
Element Tuning
Member#: 54918
673 WHP Element
Originally Posted by tenchu View Post
Phil @ Element Tuning is a shady, all-for-self business man, do NOT purchase from him. He has cost me $475 in labor so far, only to find out that the harness I ordered from him was NOT what I requested, and he is trying to get the shop to charge me to rebuild the harness ($285). He will not answer his phone, or return my voice mails, I am extremely unhappy about this transaction. Never again will I make another purchase from Element Tuning.
Thanks for screwing me out of almost $2000 for your ****ty ass Hydra, and not even giving me the correct product, and then not fixing your errors!
Edit: Keeping RS25 updated step by step as I attempt to deal with Phil at Element Tuning, if you care to follow, heres a link:
http://www.rs25.com/forums/f121/t136...-no-no-no.html
Wow, I've been working directly with Jorge at P&L to figure out your problem which by the way only took two emails and then I contact you after dealing with them and asked you to give time so I could look through my emails to see what had happened (on my end). I am human and can make mistakes but let's face it I sell thousands of Hydras and there was no way for me to remember your situation without looking it up.
I didn't respond to your emails immediately (I day after you sent it) since I was already working with your shop and I was helping a team get ready to race this past weekend which consumed all my time.
Now onto the problem you claim we're at fault for. We often add two additional wires to the harnesses used on RS models etc when they want to upgrade to direct fire coils. We do this all the time and it's nothing new to me. Now I seem to remember asking if your car was running on these coils with the OEM ecu and if it was then we supplied you with the correct harness. This would mean someone had wired the direct fire coils to fire bank to bank like the OEM.
Jorge at P&L has confirmed the OEM ecu fires the coil so this is where the confusion is. Typically when a customer wants to run direct fire when direct fire is not OEM then we add two wires into the harness so the customer can add the two addition coil wires and run those to the Hydra (since OEM has only two). To run direct fire coils properly the customer is responsible for wiring not Hydra EMS, they just provide two flying leads in the harness.
Honestly I was going to work with you a little to smooth things over even though I'm not convinced this is the actual problem. You haven't given me even a business day to check things out before going on a smear campaign as I asked and therefore I'm not compelled do anything but offer to add those two wires for you in your harness now.
Old 06-14-2010, 04:06 PM   #297
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Old 06-14-2010, 04:27 PM   #298
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Rule: Let customers know you're working on a problem. "Working on it with Jorge @ P&L" isn't hard to send.
Rule: Let customers know your schedule.
Rule: Never expect your build to fit a timeframe. Ever. You and you alone will screw yourself if you do this.
Rule: Unbox and examine everything ordered, weeks before you intend to install.
Correction: Phil is not a "shady all-for-self business man". You may be rightfully pissed about your situation, but that statement is completely inaccurate.
2 cents deposited as usual
Old 06-14-2010, 04:29 PM   #299
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Old 06-14-2010, 04:30 PM   #300
Element Tuning
Member#: 54918
673 WHP Element
Ok so I've moved forward a little with P&L and it looks like I didn't make a mistake and the correct wiring harness was sent. Off the top of my head I thought the 95 JDM car was a dual coil setup but it's actually individual so the harness would be totally plug and play in this situation.
I've given Paul at P&L the correct wiring diagram and he's going to check the coil pins to see if Hydra EMS made a mistake with the wiring.
Using the Hydra with the GM AIT Sensor.. sponaugle Other Engine Management 1 11-14-2008 01:24 PM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 07:11 PM
How many people are using the Hydra on the STi? Quick Other Engine Management 10 10-03-2005 01:20 AM
The Second Official Unofficial Hydra Thread bboy Other Engine Management 2 06-06-2005 11:39 AM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 04:12 PM
