Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-13-2011, 04:37 PM   #376
ptuck
Member#: 181778
2004 STI
JBP
Never mind, I won't be having Good speed work on my car. Clark Turner won't tune Hydra 2.5 version, just figured I would let everyone know so they don't bother asking him.
ptuck is offline   Reply With Quote
Old 10-17-2011, 06:33 PM   #377
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
go talk to Travis, you'll have a much better experience than Clark.
if you want to know about my experince, PM me.
Z0rr0 is offline   Reply With Quote
Old 10-18-2011, 04:31 PM   #378
megajoe
Member#: 291313
Originally Posted by LetItSnow View Post
Yep, it's /nemesisforum instead of /forum now.
The old one is still there, but you can't log in and all the information is inaccessible.
Here is a full "old " hydra forum
http://www.hydraems.com/forums/index...c19f17dd61f9fa
megajoe is offline   Reply With Quote
Old 10-19-2011, 12:11 PM   #379
rattlehead666
Member#: 242389
1999 2.5RS
Originally Posted by megajoe View Post
I tried that link. It gets me to the forum's main page but none of the threads in the sub-forums seem to be available for reading. Main page shows there are theads in there, but every link is locked for viewing. I tried registering and got a "username already in use" (?) even though I have not even submitted one.
I wish could read all that info. I've got a 2.5 R15 I want to use to run the EJ257 in my '99 2.5RS.
rattlehead666 is offline   Reply With Quote
Old 10-19-2011, 02:23 PM   #380
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The forum honestly wouldn't go into detail about that type of engine swap. It's fairly simple when a customer orders a Hydra with that intention because we would provide them with the correct Hydra, wiring harness, and wiring diagram.
In your case if you're starting with an RS specific Hydra, which runs specific crank/cam trigger hardware, it could be an issue with a full swap.
I would have to charge you for our technical support package but I could provide you with a correctly setup Hydra map, wiring instructions, and technical support to get this done. Now if you have the wrong Hydra for this application (not an STi specifi Hydra) you may not be able to run the AVCS in closed loop, and you may not be able to run the direct fire ignition system. If you have an STi Hydra good, then you'll just need the correct wiring harness, map, and wiring instructions.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
Old 11-03-2011, 12:00 PM   #381
ahmetgurlek
Member#: 270606
2006 STİ
hi phil,
I'm running blouch dominator 4.0 turbo, 3" air inlet to the turbo, regular pump gas + % 10 toluene, 1000cc injectors, do you have a base map i can start my car on?
I have hydra 2.5 (EUUK000270 does it mean anything?) and a 06 sti
ahmetgurlek is offline   Reply With Quote
Old 11-03-2011, 02:15 PM   #382
Element Tuning
Member#: 54918
673 WHP Element
Originally Posted by ahmetgurlek View Post
hi phil,
What brand of injectors? Do you know if they are low impedance or high impedance? Typically on the older Hydras I only have low impedance maps for 1000cc and larger. On 2.6 and newer Hydras I have high impedance maps for 1000cc and larger.
Old 11-04-2011, 03:12 AM   #383
ahmetgurlek
Member#: 270606
2006 STİ
rc 1000 cc injectors (pl4-1000). resistance: 2.5 ohms @ 68f. i think they are low impedance.
btw, my e-mail address is [email protected]. you can send the map via e-mail. thank u in advance...
Old 11-04-2011, 11:54 AM   #384
Element Tuning
Member#: 54918
673 WHP Element
Ok good we have plenty of maps for the RC1000cc as I run those in my race car.
This is a non Element Tuning Hydra EMS so you're going to have to purchase the technical support ($249) package from us and we'll provide you with a tuned base map and provide assistance as we would if you purchased the unit from Element Tuning or one of our dealers. I have sold many technical support packages to overseas Hydra user and no one has ever felt it wasn't totally work it.
Contact us directly via email if you like to purchase and move forward.
Old 12-05-2011, 05:16 PM   #385
megajoe
Member#: 291313
Have you ever come across an issue that the car will not rev past 6200-6500 rpm in a free rev or under load .
Ive tried everything with this ECU , and no joy . The stock and a borrowed haltech run the car fine .
Ive even soldered resitors , to make a bridge incase of noise , still the same . Ive worked with many ecus over the years and have never come across this issue . We have scoped the unit and the signal seams fine , but since it runs fine on the stock and haltech , i cant see it being a car issue at this stage .
I am asking if you might point me in the right direction as ive gotten to the stage were I am starting to loose my patience with Hydra HQ and throw this nemesis in the bin and get a Syvecs .
Any help welcome
Joe
Old 12-05-2011, 05:48 PM   #386
Element Tuning
Member#: 54918
673 WHP Element
Is this an Element Tuning Hydra EMS and are you running one of our base maps?
Is this a new Hydra 2.7 or is this an upgrade to Hydra 2.7?
What car is this for, year, make, model?
The graph doesn't tell me much I need the actual numbers from the data log but here are a few things it could be:
Did you set the Maximum Boost so that it's not fuel cut? You can log over boost cut flag.
Did you set the hard and soft rev limiters beyond 6k rpm?
Is your anti-lag, launch control, or flat shift maps engaged and or are they even set up in the Auxilliary Inputs? You can log any of these "launch control flag" etc. If you have them setup in the Auxillary inputs, turn those off and test again.
Old 12-05-2011, 08:05 PM   #387
megajoe
Member#: 291313
I just thought id pop the question here as you seam knowledgeable regarding the nemesis , which is a pretty basic unit compared to motec m800 , DTA ect ive worked with in the past .
I had an old 2.5 which was updated , but only lasted a week , and died . Andrew sent me a new ecu and wiring harness
Hard and soft are set above 7500rpm , everything is disabled regarding , launch control, flatshift . boost limiter is set at 30 psi . ive tried dwell from 1.5 ms to 5 ms and pretty much every trick like earthing , shielding , even built a "bridge" resistor pack on the cam and crank inputs in case of over voltage or noise
Car is a Type R subaru STI GC8 running ej257 with gt3076r
Old 12-06-2011, 03:21 PM   #388
Element Tuning
Member#: 54918
673 WHP Element
If it's basic you should have this covered, right
Honestly without our base map it can be so many things as the Hydra 2.7 is by no means basic. We've simplified the interface to make it more user friendly but the layers are many deep. With an upgrade not done via Element Tuning you're going to have issues because your old map will not transfer, you need to start over, and manually copy over some parts of your map (if you had a 2.6).
If you set your dwell to 5 ms you could have burned up the coil pack or at the very least it will misfire badly at high RPM.
In any event we only support Element Tuning Hydras and upgrades done via Element Tuning. We sell a tech support package with a base map for those Hydras that are not Element Tuning. Without starting with a known good 2.7 base maps it's going to be tough to track down the issue.
Old 12-19-2011, 12:26 AM   #389
SoloWRXSTi
Member#: 137548
All Hydra gurus, please see my issue in this thread and give me your ideas. Thanks!
http://forums.nasioc.com/forums/show....php?t=2284924
SoloWRXSTi is online now   Reply With Quote
Old 01-09-2012, 01:33 PM   #390
Element Tuning
Member#: 54918
673 WHP Element
Default Hydra 2.7 Updates and Upgrades
Hydra owners, If you have a 2.7 Hydra EMS we often update the software with new releases. These units are user flashable now and the most current software is available here:
http://hydraems.com/software/
If you have a 2.1-2.6 Hydra EMS and want to upgrade to the latest 2.7 software (various hardware upgrades) now is the time to do it. Until February 1st 2012 upgrades are 25% off.
http://hydraems.com/emsupgrade/
Contact Element Tuning and we'll get you set up and an RMA# issued
Thanks,
Philip Grabow
Old 01-12-2012, 10:15 AM   #391
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
It also seems the upgrade price when up to 400 from 300 at least for the 2002-2005 wrx hydra 2.6.
NITROS is offline   Reply With Quote
Old 01-12-2012, 11:15 AM   #392
Element Tuning
Member#: 54918
673 WHP Element
Yes a 1 year warranty is included in the upgrades now.
Old 02-20-2012, 03:14 PM   #393
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
Anybody heard from phil lately? I've been trying to contact him for two weeks..
dirtslayer is offline   Reply With Quote
Old 02-21-2012, 03:16 PM   #394
Element Tuning
Member#: 54918
673 WHP Element
Sorry I went MIA last week preparing for a championship race. Playing catch up this week so please resend emails or call again, leave a VM, etc.
Old 02-21-2012, 03:39 PM   #395
dirtslayer
Member#: 242550
olive drab
No worries. Ill call thanks
Old 02-21-2012, 03:39 PM   #396
dirtslayer
Member#: 242550
olive drab
Old 02-24-2012, 11:19 PM   #397
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
hey phil I have my car running good when I can get it start! my afr is 13.0-13.5 at idle but!!
once it warms up and I turn it off it will not start!
I found out what cams I have they are the kelford big cams!
Advertised Duration @ 0.25 mm 282 278 Duration @ 1.0 mm Valve Lift 240 236
so... you sent me a map called Element STi 04-07 950cc GT65 Cosworth Cams NO AVCS 50psi fp CH.s26
Only thing i can come up with is the timing is off so it will not start? is that possable?
please let me know what you think??
shilohb is offline   Reply With Quote
Old 02-27-2012, 01:01 PM   #398
Element Tuning
Member#: 54918
673 WHP Element
It's a hot start issue due to the porting and cams. It's a simple fix but you should read my tuning guides, this one addresses starting: http://elementtuning.com/techdocs/el...uning-guide-3/
It's for the older software but the terminology is the same. Basically if you can cold start but not hot start you just need to add more "cranking enrichment" to the hot coolant areas of this map. On cars with porting you may have to use 35 % or so in the 70C + coolant areas of the "cranking enrichment map."
Old 02-29-2012, 10:52 PM   #399
Marzocchiwrx
Member#: 117720
i have an hydra 2.6... were do i get software to tune it?
Marzocchiwrx is offline   Reply With Quote
Old 02-29-2012, 11:24 PM   #400
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
You can download it from hydra ems website under software tab
Also recommended downloading the pdf file 200+ pages of helpful tuning guidelines
Element tuning has three pages that are good pointers for common tuning issues
Using the Hydra with the GM AIT Sensor.. sponaugle Other Engine Management 1 11-14-2008 01:24 PM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 07:11 PM
How many people are using the Hydra on the STi? Quick Other Engine Management 10 10-03-2005 01:20 AM
The Second Official Unofficial Hydra Thread bboy Other Engine Management 2 06-06-2005 11:39 AM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 04:12 PM
