Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 02-29-2012, 11:31 PM   #401
Marzocchiwrx
Member#: 117720
i have download it!! but it dosen't work... software seem broken..
Marzocchiwrx is offline   Reply With Quote
Old 02-29-2012, 11:43 PM   #402
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Might be on your end I just downloaded it yesterday and it is working fine
shilohb is offline   Reply With Quote
Old 02-29-2012, 11:45 PM   #403
Marzocchiwrx
Member#: 117720
can you send me the link.... i just trie at the moment......
or the file by mail...
Old 02-29-2012, 11:54 PM   #404
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
yah pm me your e-mail
Old 03-01-2012, 09:48 AM   #405
Marzocchiwrx
Member#: 117720
i'ts not working.... it dosen't seem to install file on my laptop...
Old 03-02-2012, 06:32 PM   #406
fastrs2.5
Member#: 197617
1997 viper gts
red
can anyone provide me info on my hydra fhz1229b10145
fastrs2.5 is offline   Reply With Quote
Old 03-02-2012, 09:39 PM   #407
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
hydra 2.6 not connecting to windows xp laptop with a expresscard serial adapter.. oh its a 02 wrx.
ive made sure to align the com ports to com1 and have had the key to ON. still says cannot connect..
hellpp
thanks
dirtslayer is offline   Reply With Quote
Old 03-02-2012, 09:41 PM   #408
Marzocchiwrx
Member#: 117720
witch software are you using?
Old 03-02-2012, 10:30 PM   #409
dirtslayer
Member#: 242550
olive drab
logger? havnt heard anything abut that yet..
and ive found that the software does not match my ecu firmware. i have a 2.6 for sure, and 2.64 software.
Old 03-02-2012, 10:32 PM   #410
dirtslayer
Member#: 242550
olive drab
v2.64 revisin 9 nemisis from phil
Old 03-30-2012, 01:53 PM   #411
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
You may have an AIM Sports Dash version of the Hydra 2.6 which means you need R15. Try R12 or R15.
Element Tuning is offline   Reply With Quote
Old 05-19-2012, 06:04 PM   #412
dirtslayer
Member#: 242550
olive drab
Got tuned today by church. Multiple problems found
Wastegate solenoid activating on off at idle even tho the hydra software says its off at the time.
Wideband isn't sending signal to go into closed loop fueling I guess..
Jumpy power curve above 4500ish
And slipping clutch...
Old 05-19-2012, 06:05 PM   #413
dirtslayer
Member#: 242550
olive drab
And cel turned on , on the way back home..
Old 05-21-2012, 02:46 PM   #414
Element Tuning
Member#: 54918
673 WHP Element
Sorry you probably don't have the map setup correctly. What output is the boost control setup on? What is the value in the 0% load cell for the boost map PWM Map 4, what is the start RPM?
How about the WB/Autotune, is it setup, was it paid for? Maps are encrypted on older Hydras and these features are not active unless the map is encrypted to the Hydra. Go to select/settings/setup and click "check status" to see what features "match" and what "fails".
If your CEL is on then you are likely detonating on your tune. Consult your tuner about this. When the knock counts or threshold exceed the "limits" the Hydra goes into the "Limp" map which is why the CEL is on.
It could also be false knock but your tuner is responsible for setting the "knock threshold" map for your engine.
Good luck.
Phil
Old 05-25-2012, 07:44 PM   #415
dirtslayer
Member#: 242550
olive drab
ok thanks.
finally got back to working on this
i just enabled the closed loop fueling in settings and i guess it should work.
can i send you my map and have you look it over?
im doubting my tuners attention to detail atm
Old 05-25-2012, 07:49 PM   #416
dirtslayer
Member#: 242550
olive drab
and for the pwm map 4 its in pentcentages.
at 0% its at 8.2 and at 7% its at 10.5
Old 05-25-2012, 07:50 PM   #417
dirtslayer
Member#: 242550
olive drab
oh and how do i get the tgvs to stop powering up?
Old 05-25-2012, 10:09 PM   #418
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Unplug them.
BAN SUVS is offline   Reply With Quote
Old 05-25-2012, 10:21 PM   #419
dirtslayer
Member#: 242550
olive drab
Haha that's it? It would be nice to have it look stock and not ish unplugged.
I guess ill cut the wire leading in (after I talk to phil)
Old 06-07-2012, 04:20 PM   #420
acssa
Member#: 184023
does anyone use antilag on street driven car to help spool? Not agressive stuff just to mild stuff to compensate for laggy turbo... say 2800-3800rpm
acssa is offline   Reply With Quote
Old 06-07-2012, 05:29 PM   #421
dirtslayer
Member#: 242550
olive drab
Not yet but it is planned for next tune
Old 06-20-2012, 02:27 PM   #422
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
question on MAP sensors and Hydra EMS:
2002 wrx with 2.6 nemesis, looking to upgrade MAP sensors from OEM sensor so i can run more than 21-22psi what are my options?, is the OEM unit going to be an issue?
thanks gabe
Alaskan EJ20 is offline   Reply With Quote
Old 06-20-2012, 02:47 PM   #423
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
The Hydra comes with its own 3-bar MAP sensor that is used.
jblaine is offline   Reply With Quote
Old 06-22-2012, 03:47 PM   #424
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
I have been working on my car for years, and I am finally not going to stop until the thing is running. I've even gone so far as to decide not to shave my face until it runs. (my GF loves this, btw...)
What I'm looking for is someone to tune my car in the Indianapolis area, but not sure which shops are keen to the Hydra. I think at one point I was leaning towards Pure Tuning, in Ohio. Anyone dealt with them tuning a decent build? I'm running a 2.6 box. I want to get in touch with a tuner before I am ready to fire it up so I can work with them on getting any issues sorted out, and get a decent start up map together. And then ultimately have them get me a proper tune on it.
It's an 02 WRX. It will be ran on E85 and have a built and sleeved EJ257 with Ross Racing 10.1:1 E85 pistons, Manley rods, JDM v8 heads with Ferrea valvetrain, AVCS enabled, Precision 6262, FIC 2150 injectors, etc.
What say you?
Rizzo314 is offline   Reply With Quote
Old 06-22-2012, 10:19 PM   #425
Element Tuning
Member#: 54918
673 WHP Element
If you can't ship the car to me or convince me to fly out there give the guys at Slow Motion in Ohio a call. I have a lot of experience with your type of compression and setup so its pretty straight forward for me. Others not so sure but give them a call.
Using the Hydra with the GM AIT Sensor.. sponaugle Other Engine Management 1 11-14-2008 01:24 PM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 07:11 PM
How many people are using the Hydra on the STi? Quick Other Engine Management 10 10-03-2005 01:20 AM
The Second Official Unofficial Hydra Thread bboy Other Engine Management 2 06-06-2005 11:39 AM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 04:12 PM
