Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-15-2007, 10:27 PM   #201
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
why is it that my upload screen says "failed" but i can just go to maps and it's connected? i can data log but i haven't tried to do anything else yet.
kharris4 is offline   Reply With Quote
Old 08-11-2007, 01:24 PM   #202
hellrazrSTI
Member#: 137461
06' Sti
Default losing power at mid gear high rpm
I am running a gt35r with a bigger hotside, 1000cc inj. walboro 250 fp., fuel rail, 2 degree colder spark plugs, and i am dropping on my face with what seems like crazy lag from 4th to 5th gear maxed out at 6500 rpm shifts.
any ideas, please help.
thanks,
rob
hellrazrSTI is offline   Reply With Quote
Old 10-20-2007, 02:42 PM   #203
kharris4
Member#: 46018
2003 wrx
how can i fix problems with hot starts? if i drive somewhere, stay for a few minutes and try to start my car and leave, it takes a number of tries to start.
Old 10-22-2007, 08:51 AM   #204
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
thanks,
rob
That's the downside to such as large hot side. Get the Element Accy Wiring Harness which will allow you to flat-foot shift so you won't loose boost between shifts.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 10-22-2007, 08:52 AM   #205
Element Tuning
Member#: 54918
673 WHP Element
This is a common problem with port work and or cams. You need to increase your "cranking enrichment" in the higher coolant areas. It's not uncommon for me to have to go all the way to 25 on this type of setup.
Thanks,
Phil
Old 11-11-2007, 05:18 AM   #206
SplatZ400
Member#: 84377
2011 335d
phil i need to order my 07 wiring harness, and send you the hydra to get converted from 06 to 07 sti. will it just be best to call on monday and get this sorted out?
SplatZ400 is offline   Reply With Quote
Old 01-04-2008, 06:15 AM   #207
xristosxt
Member#: 106656
2005 FORESTER 2.35XT
BLUE PEARL
hi to everyone
have following problem and i would apreciate some tips
my ISC when car is warm can be stable for 30 seconds at 1200 (target) and -500mmHg with 14.6 afr but after that it start droping up to -360mmHg and 17 or 18 Afr and 1000rpm and then comes back again to the desired values
i have tried to fix it with main fuel map by addding fuel ,also by changing settings, and by increasing ISC integrator with no success
i run the car in closed loop and auto tune with target Afr map above 2400rpm
i have Isc settings at P=35 I=55 D=22 min PWM=20 max PWM=88
its is an EU (ex )-forester xt with MD turbo with a 2.35L engine and
Forester heads with 264 cams
i have an NTK on board wideband for Hydra and an additional Zeitronix (Bosh sensor) with screen
Oscilation on Zeitronix is bigger but by listening to the engine it also more precise
Both sensors are placed on down pipe 25 cm from turbo
tks
chris
xristosxt is offline   Reply With Quote
Old 01-08-2008, 10:39 AM   #208
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I'd start by figuring out what is causing your vacuum to temporarily change 140mmHg. That's not normal.
Regardless, 17-18 AFR is... 17-18 AFR. When you tune 1000RPM @ 360mmHg for 14.5:1 instead of 17-18, the problem does not get any better?
jblaine is offline   Reply With Quote
Old 01-08-2008, 12:15 PM   #209
xristosxt
Member#: 106656
BLUE PEARL
Tks your response
I noticed that my voltage reading in Nemesis durring ride is quite low 10,3 - 10,7 V
Battery is 11,5V but after 10 minutes ride produced Voltage is comming down
i have partly resolved my ISC problems by increasing my injector responce values (i have PE 800cc)
This way my Isc is stable but about 100 rpm higher than target
does anyone knows how this can affect safety of the engine in long term or high loads?
Old 01-08-2008, 12:37 PM   #210
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
If I had to guess, I would say your alternator is dying. Your car is never going to run properly, especially at high RPMs, with a Nemesis and voltages less than 13.0 at idle.
Old 01-08-2008, 06:42 PM   #211
Chino1
Member#: 128985
2002 bugeye STi-ish
MBP
quick question on reading datalogs. i understand what everything is except for the two that say "cell X (n)" & "cell Y (n)" im reading logs with office 07.
Chino1 is offline   Reply With Quote
Old 01-08-2008, 06:47 PM   #212
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
That's the X,Y position in the map that the current data is being read from.
For example, 18psi at 5000RPM might be cell 23,23. That's 23 cells in the map to the right and 23 down.
Old 01-09-2008, 05:16 AM   #213
Chino1
Member#: 128985
2002 bugeye STi-ish
MBP
gotcha. thats what i figured but wanted to verify before i assumed. thanx man.
Old 01-15-2008, 04:33 PM   #214
SplatZ400
Member#: 84377
2011 335d
phil or anyone that has solid proof. will a wideband from an 02 wrx hydra work with a 07 sti hydra? they are both ver2.5 i have one laying around and dont want to have to get a different one if i dont have to.
Old 01-18-2008, 08:29 AM   #215
SplatZ400
Member#: 84377
2011 335d
anyone have an answer?
Old 01-30-2008, 02:17 PM   #216
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
Hey Phil, I have a 2005 Wagon that Tim Bailey and I have been working on. I have a built STI long block, GT35R, Hydra 2.5, Hydramist, and other goodies. We just got the car running last night, and Tim flew out this morning. I didn't get an installation CD for the Nemesis software with the Hydra that we purchased from you, so I need to download it. I checked the hydraems.com site, and there are files listed for download, but are all in an "XLS" format. Can you point me the right direction so that I can begin autotuning the car? Thanks in advance.
BiggSean is offline   Reply With Quote
Old 01-30-2008, 02:21 PM   #217
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
There are quite a few other files there.
Scroll down, dude.
Old 01-30-2008, 02:57 PM   #218
BiggSean
Member#: 97352
2005 6MT 35R Wagon
Full STI drivetrain
Yep, I was just going to edit my original post to say that I had found it.
Thanks anyway.
Old 04-25-2008, 10:28 AM   #219
Chino1
Member#: 128985
2002 bugeye STi-ish
MBP
just a quick question!
where is everyones fuel cut limit?
Old 10-07-2008, 06:31 AM   #220
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
6 months later ...
I don't think 95% of Hydra users got along well with "Decel Fuel Cut", so Fuel Cut Limit (map) is irrelevant to most.
Old 10-15-2008, 01:15 AM   #221
Chino1
Member#: 128985
2002 bugeye STi-ish
MBP
lol. yea i dont get along too well with mine...
Old 10-24-2008, 11:20 PM   #222
xerox445@yahoo.com
Member#: 111556
2006 STI
does anyone have a stock 2.5 hydra map for a 06 sti? I bought a used hydra and want to check some values for injectors and dwell on a map on got from my tuner, as my setup now is built block but stock everything else and the map was originally for a 35r with 1000cc injectors. The injectors are scaled down but I don't know if everything else is, as the car wont start with the hydra, but will start with the stock ecu.
xerox445@yahoo.com is offline   Reply With Quote
Old 10-30-2008, 01:08 AM   #223
darbley17
Member#: 187367
05 wrx
white
i just wanna have my car tuned so it has a pump gas and race fuel setup but after that i dont wanna mess w/ it is the hydra right for me or is there a cheaper alternitive?
darbley17 is offline   Reply With Quote
Old 02-16-2009, 05:56 AM   #224
hanzo918
Member#: 82148
1992 Daihatsu
Charade
In case anybody is interested, I have one for sale.
http://forums.nasioc.com/forums/show...php?p=25604317
hanzo918 is offline   Reply With Quote
Old 03-28-2009, 09:07 PM   #225
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
For some reason it took me a 15 minutes to dig up a copy of the 2.6 manual. Here's a link in case anybody else is looking for it:
http://www.intertrick.org/nasioc/fil...sersManual.pdf
dexterous is offline   Reply With Quote
Using the Hydra with the GM AIT Sensor.. sponaugle Other Engine Management 1 11-14-2008 02:24 PM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 08:11 PM
How many people are using the Hydra on the STi? Quick Other Engine Management 10 10-03-2005 02:20 AM
The Second Official Unofficial Hydra Thread bboy Other Engine Management 2 06-06-2005 12:39 PM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 05:12 PM
