Welcome to the North American Subaru Impreza Owners Club Wednesday April 16, 2014
Old 03-16-2005, 03:02 AM   #1
aGoGo
Member#: 83124
Lightbulb newbie need advise, 93 1.8 AWD, engine noise at certain RPMs
Hi all,
I just pick up a 93 1.8L AWD last week. It is a very interesting car and totally different from what I was used to, 85 Rx7. The engine is a very different beast from rotary, lot of torque and 'not as smooth' but runs great. It had K&N filter Nology wire and 'Beru'(spell?) plugs, has been using Castro synthetic all around and I just changed oil last week along with some MMO in the oil and gas (87).
The problem I am having is that, when I have a very easy acceleration about 1500 rpm or coasting down from around 3000 in gear I hear a metal tapping or rattle noise from the engine bay, this noise can also be heard in neutural about 3000 rpm as well, oh during shift (around 3000) if I let off the acc padel a bit fast I can hear a chirp of this noise too. But if I rev a little ways past 3000, this noise is gone and the engine roars louder as it should. Most of the time, if I accelerate normally to 4000, this noise might not present. The noise sends like the valve. I am new too those cars and could some one give me some advise on what this might be? A fix? Thanks!
With regards
aGoGo is offline   Reply With Quote
Old 03-16-2005, 03:11 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Sounding off at that RPM only makes me think it might just be a heat shield around the exhaust. Given the age, it's likely they need to be removed.
Jay Storm
Old 03-16-2005, 03:14 AM   #3
aGoGo
Member#: 83124
Any reasoning here that can assure me it is not the valve? Thanks!
Old 03-16-2005, 03:26 AM   #4
aGoGo
Member#: 83124
I did have a very brief check around the car, and I felt a bit on the heat shields under the car as well, they was pretty solid, this car was maintained well.
Old 03-16-2005, 12:48 PM   #5
aGoGo
Member#: 83124
had a another run this morning, this metal rattle sound basically happens about 3000 rpm and when coasting down or during shift, during acceleration is ok. It is obvious from inside of the car, however when I tried to work the throttle under the hood, I can not dig this sound out since the engine is loud. I 'believe' I can feel this sound on the shifter too (or I am just too paranoid). I checked the heat shield too, they are solid and even no rust. I am not very knowladge on those engines, and just want to make sure the engine will be fine. Any input would be appriciated.
Old 03-16-2005, 10:24 PM   #6
RS-Flyboy
Member#: 70331
04 Silver Baja
1999 Impreza 2.5RS
Alright:
I had a squeeling noise, from idle, to about what you're saying, between 2.5k to 3k RPMs. Turns out, that sound was my tensioner pulley for my timing belt about to give up on me. Needless to say, it crapped out, and cause the belt to snap. A few new valves later...
You get the idea. Get your pulley checked out.
RS-Flyboy is offline   Reply With Quote
Old 03-16-2005, 11:03 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
But all 1.8s are non-interference.
Originally Posted by RS-Flyboy
Alright:
Good luck finding the source.
Jay Storm
Old 03-17-2005, 02:23 AM   #8
aGoGo
Member#: 83124
Thanks guys, I will get a more detailed check this weekend
Old 03-17-2005, 02:50 AM   #9
aGoGo
Member#: 83124
I just did a search about this "interference" and "non-interference" but still don't get the essence yet, can some one elaborate it abit? Thanks!
Old 03-17-2005, 03:07 AM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
Interference means that if timing between the valves and piston is lost, they will collide and bend or break the valves. The pistons usually take a beating in that regard as well. Another type of interference is when the timing is lost between the cams on a DOHC head allowing the intake and exhaust valves to hit each other if they both open at the same time.
Non-interference means that there is clearance between all of these parts at all times.
Jay Storm
Old 03-17-2005, 03:27 AM   #11
aGoGo
Member#: 83124
Thanks man! The explaination was very clear. That means an 1.8 won't bent a valve due to timing belt or the tensioner failure, right? or even this engine should have reliable valves?
Actually, the previous owner told me, the timming belt was replaced in 2002, I would assume it is still in good shape.
Drop in power/torque at certain rpm?? whitewolf2 Open Source Reflashes 9 02-08-2009 01:08 AM
Help me figure out why my car is bucking/bogging at certain RPMS! vipernj Factory 2.0L Turbo Powertrain 11 01-30-2006 08:29 PM
rattle at certain rpms with cusco heatshield mpower22 Factory 2.5L Turbo Powertrain 3 11-12-2004 04:29 PM
rattle noise at 2800 rpm golfs2good Transmission (AT/MT) & Driveline 3 10-30-2002 01:26 PM
WRX Vibration noise at 2000 rpm and WOT? Cosworth Factory 2.0L Turbo Powertrain 4 06-21-2001 02:39 AM
