Old 03-16-2005, 11:59 AM   #1
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Default should my car sound like this when starting?
I've owned my car for about 3 years now... This is the first time I really heard this sound..
When I start the car when it's somewhat cold out, Like 40F The car starts at the normal speed, Then it goes fast for like 1 Revolution, then it goes back to the normal starting speed...
The timimg belt can't skip a tooth on starting can it?
SubaruImpreza_power is offline   Reply With Quote
Old 03-17-2005, 08:54 AM   #2
skunkfifty
Member#: 73102
1998 legacy outback
white
in theory, it could skip anytime its turning. what does it do when its really cold out? (below freezing)
skunkfifty is offline   Reply With Quote
Old 03-17-2005, 11:01 AM   #3
DreddRS25
Member#: 51642
2008 WRX
For Me. When its cold outside my RS will do something similar to what you describe. Normal conditions my cars starts up and sits at 1400rpm and slowly winds down to 700ish. On cold starts it will jump to 1400 then rise up a little almost to 2k, may drop under 1400, then settle back to normal.
I think the ecu is compensating for the colder air.
DreddRS25 is offline   Reply With Quote
Old 03-18-2005, 07:39 PM   #4
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
No i'm not talking about the car running, I'm talking about when the starter is starting the engine.
Old 03-18-2005, 07:46 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
does the car run ok?
what you are describing does sound like an engine starting that is out of time, or has low compression.
It could also be something in the starting system, exccessive current draw by the starter perhaps.
Jay
Old 03-18-2005, 08:18 PM   #6
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Car runs fine.. could be the current draw.
Old 03-19-2005, 06:54 PM   #7
Sober_One
Member#: 83322
2000 Impreza 2.5RS
Sylverthorn
A few weeks ago it was -9F (-23C) here in Ottawa Canada and you should have heard my car trying to start in that!!!
I believe it is the way the compression start cycle works to tick the engine over when it is cold.
As long as it starts, doesn't back fire, doesn't stall, and runs fine once warmed up then, I wouldn't worry about it.
Sober_One is offline   Reply With Quote
Old 03-19-2005, 07:37 PM   #8
STi Guy 69er
Member#: 82648
2005 Impreza 2.5 RS
cold oil maybe.... tryin to get some lubrication goin in the engine..maybe the engine is reving up to get things moving? jus a thought..
STi Guy 69er is offline   Reply With Quote
Old 04-09-2005, 12:05 PM   #9
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Update the starter went out, I got a new one.. Not subaru branded it's not as loud as the Stock Mitsu starter.
My car looks like this... It needs to look like this... SuperRallyRoo North West Impreza Club Forum -- NWIC 26 08-11-2006 10:06 AM
why does my car sound like a tractor when it's below freezing doubledribble Normally Aspirated Powertrain 22 01-29-2005 02:21 AM
My car sounds like in reverse gear but when moving forward sonicowrx03 Transmission (AT/MT) & Driveline 4 06-20-2004 12:22 AM
Why does my car sound like my mom's car? wlchan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 11-27-2003 01:14 AM
"Attn all passengers, does your car sound like this???" Subie Gal North West Impreza Club Forum -- NWIC 1 04-08-2002 09:34 AM
