Old 07-20-2001, 02:57 PM   #1
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
Question Need motor build help.
I have a 1990 non turbo 2.2l legacy motor. I am going to be running turbo with 10Lbs day to day and up to 20lbs when having fun. I will be using my 98 2.5RS heads, 64mm throttle body, intake extrude honed, heads ported and polished, new valve springs and retainers, knifed crank, and syms light weight fly wheel and clutch.
My question is what piston's and rod's should I use and for what estimated compression ratio should I be looking for. Also what spark plugs, and head gasket do I use (2.2 or 2.5)? And how can I raise the rev limit without a TEC II for the timse being? Thanks.
CUNNINGHAM is offline   Reply With Quote
Old 07-20-2001, 03:21 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I know you're pretty new to the board so I'll make this a warning. Please don't post so many !!!!!!!!!!!!!!!! marks in your topics, nor any other non-text stuff. Typically posts with stuff like that get locked.
Old 07-20-2001, 03:37 PM   #3
wrxnate
Member#: 5187
2002 STI Wagon
I did'nt know that Legacies came with electic powerplants.......
engine=internal combustion
Motor=electricity
don't belive me? look it up......
I had to be an A$$....don't take it personal
wrxnate is offline   Reply With Quote
Old 07-20-2001, 04:44 PM   #4
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
CUNNINGHAM - If you want to know PM me... with a more descriptive goal etc.... you're not going to be able to boost 20lbs w/o using forged parts in that EJ22 from the Legacy.
GTBGUY is offline   Reply With Quote
Old 07-20-2001, 05:02 PM   #5
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
If you use as many !!! ever again, hehe, you will need serious injury/medical advice.
Please don't do it again.
Imprezer is offline   Reply With Quote
New to building a motor, need a lil advise morbid818 Built Motor Discussion 1 10-12-2009 10:32 PM
need motor built advise davidsti1 Built Motor Discussion 6 06-03-2009 12:58 AM
what do i need to build my motor for 500whp amiller Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 05-18-2005 01:21 PM
Blown turbo and motor, need some build up suggestions.. scooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-12-2004 07:11 PM
Need Help with motor build!! CUNNINGHAM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-14-2001 09:29 PM
