Old 03-17-2005, 02:34 PM   #1
Mr. Mercado
Member#: 36559
2003 Impreza WRX
Default Will an Ecutek and EBC/MBC work?
Hey guys,
I recently swapped an Ecutek ecu for my stock ecu. The Ecu was program for the same mods as me (TB Exhaust). However the previous owner said his max boost was 17.5 psi. On my setup I am maxing at 15 psi. I have a BOV and HKS DP (non bellmouth) so I'm assuming the other boost is losts because of my flat plate downpipe setup.
So.....just wondering if it is safe to run an EBC, or MBC to accomodate for the loss of boost? The ecu is programmed to handle 17.5 psi, so would it be ok? Also, the ecutek has two switcheable maps programed in it. A the second map is a less agressive one...max 7psi of boost. Will an EBC/MBC affect this map aswell?
Ryan
Mr. Mercado is offline   Reply With Quote
Old 03-17-2005, 04:45 PM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Ryan
If you replace your factory boost controller ECUtek will no longer have 2 boost maps.
mbiker97 is offline   Reply With Quote
Will an 05 STi turbo inlet work on an 02 WRX? zasy99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-31-2007 07:57 PM
Will an ECUtek tune keep me from getting fuel cut? '05STi Commercial ECU Reflashes 1 02-18-2006 11:41 PM
Quick Q&A: Will an 04 rear o2 sensor work on an 02? Blue Rabbit 02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-06-2005 01:20 AM
Will an EcuTek flash pass emissions in NY? Optimus Prime Engine Management & Tuning 7 04-29-2005 01:06 PM
Will an 03 WRX rear diff work on an 02 WRX? zroom tsuchiya Transmission (AT/MT) & Driveline 3 03-17-2004 05:41 PM
