Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-17-2005, 07:00 PM   #1
slowwrx
Member#: 31482
2003 wrx
black
Default What is the most power anyone has made on a usdm 2.0
What is the most power anyone has made with a usdm 2.0 with and with out nitrous.
What fails when they do fail.
Matt
slowwrx is offline   Reply With Quote
Old 03-17-2005, 07:50 PM   #2
speedemon9
Member#: 72279
2006 2006 STi
Once you get to about 300hp then the tranny will not be your friend
speedemon9 is offline   Reply With Quote
Old 03-17-2005, 08:11 PM   #3
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
around 350 360hp to the wheels does not include stock gear box .
tekfoc is offline   Reply With Quote
Old 03-17-2005, 08:13 PM   #4
cronic
Member#: 9749
Big turkey made 399 stock motor, and pretty sure stock tranny..
cronic is offline   Reply With Quote
Old 03-17-2005, 08:23 PM   #5
slowwrx
Member#: 31482
2003 wrx
black
I know someone has made more than this, and why is it that everyone thinks the stock tranny breaks as soon as you make more than 300hp
Old 03-17-2005, 08:24 PM   #6
slowwrx
Member#: 31482
2003 wrx
black
Thats more like it, I'll search and see if I can find more info on this.
Old 03-17-2005, 09:05 PM   #7
BluprlW05
Member#: 68944
2005 stage 4
countdown...
because it's happened...I heard of a guy with 320+ on stock tranny and went to WOT in second and blew second gear...a lot of people have just seen or had it happen to them...
BluprlW05 is offline   Reply With Quote
Old 03-17-2005, 09:24 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....a bit over 400chp is where the rods start coming through.....usually....
Old 03-17-2005, 09:54 PM   #9
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Rods coming through the block? I've seen a lot of high HP setups and I've never seen one break a rod...
The pistons fail due to excessive cylinder pressures usually. The ring lands break.
The most I've witnessed is Dan Bijalis made ~412whp on a stock engine with a FP Green (or maybe red) turbo some time ago. Stock trans too. Ran a [email protected] on that setup.
Old 03-17-2005, 10:10 PM   #10
slowwrx
Member#: 31482
2003 wrx
black
Default Good info
This is good info
Im not worried about the tranny I'm making 332 and I beat on it.
So far it sounds like the pistons are the weak point. Off to do more research.
Matt
Old 03-18-2005, 07:28 AM   #11
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
The tranny will hold 400 hp if you know how to shift well. Ring lands on the pistons are the first to go, then rods. You can make a reliable 350 whp with the USDM 2.0L.
speedyHAM is offline   Reply With Quote
What is the most expensive impulsive purchase you have made? cyberpirate Off-Topic 82 07-21-2006 11:29 AM
Gt30r on a USDM 2.0? Anyone have it? Token-Negro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 43 02-17-2006 10:28 AM
what is the most whp that can be made on 91 octane? wrxben Engine Management & Tuning 8 06-25-2004 02:44 AM
What is the most resrictive on a 2.2L exhaust system? jsavage Normally Aspirated Powertrain 4 01-19-2004 01:19 PM
What is the most powerful 4 cyl NA production engine? moogooob Off-Topic 23 11-14-2002 04:52 PM
