Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-18-2005, 12:30 PM   #1
static_rst
Member#: 50155
Default help with my oil ASAP
is it ok to switch brands of oil if you get it completely drained? right now i hvae torco gsr-1 synthetic and the only place that has that is rallitek and i dn't want to drive to portalnd to get it changed. (i am not doing it myself). so the local place carries mobile 1 synthetic, is it ok to chnage oil brands or will it mess stuff up?
any info, or better brands that the local guy might carry?
static_rst is offline   Reply With Quote
Old 03-18-2005, 12:41 PM   #2
russd32
Member#: 63961
It's oil yo. Don't worry about it.
russd32 is offline   Reply With Quote
Old 03-18-2005, 01:42 PM   #3
static_rst
Member#: 50155
well i got it changed to mobile 1 synthetic, my car hasn't blow up so all is well for now.
Old 03-18-2005, 03:33 PM   #4
jamesonc
Member#: 49629
'87 Dodge Ram 50
I always heard it's bad to switch brands, so I don't. Mobil1 for life.
jamesonc is offline   Reply With Quote
Old 03-18-2005, 07:27 PM   #5
96GreenLX
Member#: 60073
1996 Impreza LX
Green
Lol I've heard of people mixing oil while changing their oil like a little Lucas synthetic and a little Castrol 10w 40 and a little of some other kind. Well this was my friend that mixed these, it actually seem to make his ride run better lol with no problems later on.
96GreenLX is offline   Reply With Quote
Old 03-19-2005, 12:06 AM   #6
lov'em
Member#: 83279
Default help wth my oil
for years i have followed the lead of a Castrol factory rep - use Castrol Syntec Blend and alternate every other oil change with the next best Q-State. Why? dont know but at 3k-5k oil change oil the oil still looks good.
lov'em is offline   Reply With Quote
Old 03-19-2005, 12:41 AM   #7
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
Yeah you can mix oils to you heart's content, no problems. The only one I can think of is if you have a LOT of miles and you're contenplating switching to synthetic.
Merdock777 is offline   Reply With Quote
Old 03-19-2005, 10:26 AM   #8
OneOBS
Member#: 63076
2004 Outback Sport
Red!
The only issue is with mixing the additives that are in the oil. Its OK to switch, just don't do it all the time.
OneOBS is offline   Reply With Quote
Old 03-19-2005, 11:55 AM   #9
Nicklbrso
Member#: 44887
00 GC6
as long as the weights are the same there is no problem.
Nicklbrso is offline   Reply With Quote
Old 03-19-2005, 05:57 PM   #10
Sober_One
Member#: 83322
2000 Impreza 2.5RS
Sylverthorn
My personal experienc from years in the field of "Fluid Power" (Hydraulics) is... No Never Mix Two Different Oils! Specially gear oil!!! Nothing may ever happen but you are rolling the dice each time you do mix oils.
If I have a need to use a different oil, all the old or other stuff is drained!
Different manufactures use different detergents, anti-foaming chemicals as well as other physical/chemical make-ups (properties) and they are not always as compatible as you may think.
The weight of the oil dosen't matter, some people mix different weights depending on the time of year. What matters is keeping the brand/manufacture and the type (synthentic or blend) of oil the same.
My advice, Don't!
Sober_One is offline   Reply With Quote
Old 03-19-2005, 07:49 PM   #11
STi Guy 69er
Member#: 82648
2005 Impreza 2.5 RS
It is ok to mix engine oils as long as it is the same weight. This is not true for gear oil and tranny fluid. Mixing these oils can lead to damage to the clutch and slipping.
STi Guy 69er is offline   Reply With Quote
help me with my brakes! asap! oogiesfaded Rocky Mountains Impreza Club Forum -- RMIC 9 10-13-2008 08:45 PM
brake help with my 05' RS (Raybestos brakes) ASAP Justin911 Brakes, Steering & Suspension 1 01-10-2008 02:11 PM
any local wiring gurus who can come out and help with my swap asap? issues inside... legacy2003 New England Impreza Club Forum -- NESIC 3 07-19-2005 01:45 AM
Help with Autometer Oil Press and Oil Temp Install - Bad Ground? MattSTi Electrical & Lighting 3 07-06-2005 11:25 AM
I need help with indiglo gauges ASAP! Pete Holt Interior & Exterior Modification 1 10-15-2002 09:47 PM
