Old 03-18-2005, 02:18 PM   #1
banta80
Member#: 62083
Default clunking noise from rear diff
I tried to launch my car this morning while going to work. Revved to about 4500, slipped the clutch, the car didn't bog at all and just took off in one smooth but fast pull. However, i did hear a clunk from the rear differential area and noticed a little clutch smell. I'm wondering did i **** up my rear diff? bad launch?
I've never really tried to launch my car. I have ~35k on the car and maybe had about 4-5 tries as far as launching it.
banta80 is offline   Reply With Quote
Old 03-18-2005, 03:45 PM   #2
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
Sounds typical of the rear diff "bucking" as you launched and maybe a bit of clutch slippage when you did so. Doesn't sound like a problem, IMO.
MK19_ is offline   Reply With Quote
Old 03-18-2005, 04:11 PM   #3
banta80
Member#: 62083
*phew*
i was scared ****less in the beginning. So this is a typical sound right? I didn't mess up anything too bad other than burning the clutch a bit?
Old 03-18-2005, 04:17 PM   #4
JayD707
Member#: 51018
2005 Legacy
Prolly not, but dont go doing it over and over again or you will mess somthing up eventually.
JayD707 is offline   Reply With Quote
Old 03-18-2005, 04:18 PM   #5
MK19_
Member#: 49148
Dogs are forever in
Well, obviously you can tear it up- but a 4500 rpm launch is ok- as long as you aren't side-stepping the clutch. I raced (auto-x) my wagon and consistantly launched at 4500-5K RPM's and no worries at all. IMO, the key to the launch- safe for the driveline and a good out-of-the-hole start, is all in slipping the clutch just right. Do a search in this forum on launches- you'll find a lot more info.
Old 03-18-2005, 05:21 PM   #6
banta80
Member#: 62083
mustangkilla,
did u occassionally get the clunk that i am referring to? or when the launch is properly done, the clunk doesn't happen? thanks
Old 03-18-2005, 05:26 PM   #7
MK19_
Member#: 49148
Dogs are forever in
Originally Posted by banta80
mustangkilla,
I got it on occasion- but as I stated- the key is to learn how to slip the clutch just right. Also, ya might want to look into STi or Kartboy mounts- the "loose" OEM ones cause a lot of "slack". Again, just my .02
Old 03-18-2005, 11:11 PM   #8
antimullet
Member#: 44193
2008 WRX STi
I had the clunk on hard lauches Cure = DIff support crossmember bushings, Group N diff mount, and group N Tranny mount. I also have the group N engine mounts and Pitchrod.
Then I still had some wheel hop. Sti Pinks and Group N tophats fixed it all. Group N tophats help ALOT in eliminating hop. The sponginess of the stockers will cause a launch induced oscillation (ie: Wheelhop) that will break axles fast.
antimullet is offline   Reply With Quote
Clunking noise from rear of STi? Optimus Prime General Community 9 07-19-2005 09:49 PM
AGX strut owners: clunking noise from rear? txl146 Brakes, Steering & Suspension 14 07-19-2005 08:08 PM
05 STi popping/clunking noise from rear when rolling slowly? twotacosfor99cents Transmission (AT/MT) & Driveline 6 02-09-2005 02:10 AM
check engine light / funky clunking noise from center diff? JessesTalon North West Impreza Club Forum -- NWIC 3 12-28-2004 12:19 AM
Clunking noise from rear of driveline under torque Cusco Transmission (AT/MT) & Driveline 3 01-02-2004 09:55 PM
