Old 03-18-2005, 06:12 PM   #1
line
Member#: 76189
WRX: Parking Lot
Racer in Training
Default VF-34 vs VF-30 vs TD05H 16g
I have been doing a lot of research on the 2 turbos lately and have found a great amount on the VF-3Xs and not so much on the 16g. I have heard lots of different things about the 16g and don’t know what to believe. I’m hoping to get VF-34, VF-30 and 16g owners to help me compare them. If you have one of these turbos or have had multiple of them it would be great if you could tell me......
WHP:
lb/ft:
At what RPM's you spool:
Mods:
General impression:
If you guys have dynos and want to throw them up too i would love to get all the info I can.
Just so you guys know my goal is to get about 260-280whp and have spool come as possible. I am open to other ideas but keep in mind that money is a factor and I’m not looking for an engine swap.
Thanks for the help
line is offline   Reply With Quote
Old 03-18-2005, 06:55 PM   #2
speedemon9
Member#: 72279
2006 2006 STi
Time Attack
Get the VF-34 because it is a ball-bearing turbo. You should be able to get 260whp out of a VF-34 (I Think)
speedemon9 is offline   Reply With Quote
Old 03-18-2005, 06:59 PM   #3
pux888
Member#: 8356
02 STi swap
12 WRX limited
big 16 g, better spool and better top end.
pux888 is offline   Reply With Quote
Old 03-18-2005, 07:02 PM   #4
cronic
Member#: 9749
I agree.. Not to mention upgradable later on, and cheap/easy rebuilds..
cronic is online now   Reply With Quote
Old 03-19-2005, 01:06 AM   #5
veightkiller
Member#: 78967
2011 335i
big 16g..fast spool
veightkiller is online now   Reply With Quote
Old 03-19-2005, 01:12 AM   #6
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
ding...ding...ding....
Old 03-19-2005, 02:37 AM   #7
azn2yunr
Member#: 67229
9295 BC/gm6
winestone/funky blue
i have a 16g currently and had a 39 on before that. the vf39 felt faster. it also felt like it drove better. this could be for many reasons though.
1. when driving with the 39 i was using stock boost control with vac lines that didnt fit snug over the the nipples. and thusly i was always driving around at 14 psi with spikes higher.
2. the leaking boost control lines also caused a part throtle full boost condition that was verry interesting. at 70 mph and 10 inhg vac adding a little throtle it would hit 14psi verry easy and the car would pull nicely to 100 without downshifting. causing the turbo to feel more driveable.
when using the 16g with the stock boost control i was hitting well stock boost at 11 psi. it didnt feel as fast problay because it wasnt the same amount of boost yet some friends i took around said at stock boost the 16g felt faster than teh 39 at 14psi. since getting the turbo i put on a turbosmart 2 stage mbc running 10 psi and 15 psi. i dont verry offten run 15psi because of fear of leaning out as a fellow with i similar setup to mine (i have a larger and front mounted intercooler) was getting pretty lean on the dyno and he has a 255 fp and i do not. i still get ptfb but it doesnt pull the car as well as the 39 did in this condition. infact it doesnt pull much at all. instead i am forced to coax the car into downshifting by punching the gas down (4eat) and then it pulls nicely. another friend of mine who has a 97 prelude took a ride in my car at 15 psi and he says that its incredibly fast even though i dont think that it is. before when i drove his car it was the fastest thing i had driven and i was really impressed with it. at that time i was loosing to his car when racing and was running 17.3xx. i havent taken the car to the track after the new turbo but i can put 4 car lengts on him in before reaching 40 mph from a dig at 10psi.
i was told by deadbolt that the 39 would have more top end than the 16g but that the 16g would have a better midrange. if you look at the compressor maps and stats in the huge thread that has the charting of the flow in cfm of many of the turbos that are popular youll see that at all times the 16g flows more than the vfx series by over 100 cfm and that includes the ever popular vf22.
in the end its your choice but the 16g is the better choice because its easily serviced rebuilt and upgradable. unlike ihi's which have been said to be impossible to rebuild and upgrade.
azn2yunr is offline   Reply With Quote
Old 03-19-2005, 03:22 AM   #8
jaypine
Member#: 50398
2003 WRX Wagon
16G>VF34=VF30
jaypine is offline   Reply With Quote
Old 03-19-2005, 06:36 AM   #9
ilivas
Member#: 56056
2004 wrx
T04R Turbo / 8k rpm 257
vf34 is not ball bearing, it's roller bearing.
Go with the 16g.
ilivas is offline   Reply With Quote
Old 03-19-2005, 08:39 AM   #10
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
I have ran VF30, 34, and a frankenstein TD05 16G. Power output was pretty much the same (using same tuner) but 16G edged out. Spool time was faster with my VF30/34 then the 16G. At the time I ran these different turbos, I was running a TXS Stg4 + and only TXS parts.
All 3 turbos will yield you the 260-280awhp range but this will vary on what Dyno is used.
Need4Boost is offline   Reply With Quote
Old 03-19-2005, 02:02 PM   #11
line
Member#: 76189
WRX: Parking Lot
Racer in Training
so Need4Boost would you say that the VF-34 and the 16g are very similar. When did you get full boost and what would suggest for me to get? Im really looking to see which will spool up the fastest and beable to hold the power to near redline. From my research all 3 should beable to do so, but im looking for which can do it best. I have an AP right now so im leaning to the VF-34 but if i got some cold hard facts that the 16g would spool faster and have more top end then i would head down that path.
Thanks guys for all the info but keep it coming
Old 03-19-2005, 02:11 PM   #12
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
The TD05 is rebuildable....and the VFxx is disposable....DONE DEAL.
Old 03-19-2005, 02:21 PM   #13
line
Member#: 76189
WRX: Parking Lot
Racer in Training
You guys claim better spool and better top end but some who has had both tuned by the same person said the VF-34/30 spool faster. Any physical proof to support either claim? If anyone else has had both I would love to see what you though of both and which you would pick.
Old 03-19-2005, 02:25 PM   #14
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
This debate will never be won, here....there are WAY too many variables.
The real issue is do you want a disposable, non-upgradable turbo or not.
Your choice....I made mine and am very pleased.
And the real comparo is the VF22 and the TD05-16G....not the VF30/34.
Old 03-19-2005, 02:32 PM   #15
line
Member#: 76189
WRX: Parking Lot
Racer in Training
Uncle Scotty could you tell about where you get full boost. I would love to have spool close to that VF-34 with the top end of a VF-22. Also could you include your mods or point me in the right direction to find them.
Still looking for new thoughts and ideas so dont be afraid to jump in people!!!
Old 03-19-2005, 03:17 PM   #16
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
No......it is 100% a matter of supporting mods and tune....MY numbers are totally nebulous to you.
Really...forget it.....it won't ever really matter.
Make your choice.....disposable or not......disposable = VF22 P&P Not = TD05
Old 03-19-2005, 03:36 PM   #17
line
Member#: 76189
WRX: Parking Lot
Racer in Training
Based on my goal for 260-280whp, and quick spool (looking for about 3500 RPM's sooner would be better) do you think the 16g would make me happy. I know that supporting mods and a good tune make a huge difference, that why i asked for your mod list. I hear it here all the time to research like crazy before deciding to spend my money and thats what im doing. I have also heard that I should run 650cc injectors, which also makes me want to see your mod list.
To be honest with you a P&P VF-22 isnt an option to me I would rather have a P&P VF-34. I want a very street freindly turbo that will spool quickly and give me some real power improvements.
Again im looking for any advise, what would you do and why????
Old 03-19-2005, 04:17 PM   #18
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
The above tells me that you have not done enough research.
A properly tuned P&P VF22 would ROCK on the street....better than a 30/34...and quit worrying about spool.....really......with tuning, and the right setup you can work wonders.
A Green or a 1820 would spool late.....a vf22 is, relativly, a small turbo...really.
Old 03-19-2005, 04:25 PM   #19
line
Member#: 76189
WRX: Parking Lot
Racer in Training
Thanks for the advise Uncle Scotty. I seems to be leaning to the 16g more and more. Any other 16g owners out there what to share how they feel about there tubros. I would love to see some more info.
Old 03-19-2005, 04:35 PM   #20
jefersun
Member#: 37716
2002 ej257 Black WRX
Just get a vf22 and some anti-lag software, the aussies are doing it... instant spool. Hell, get a green, and you'll get like full boost in the 2000 rpm range.
jefersun is offline   Reply With Quote
Old 03-19-2005, 04:44 PM   #21
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
there are guys(davenow is one) that get LOTS of boost by 2500 rpm with vf22's....
So don't be a fool or an idiot, here......some of us have experimented with more than one turbo and know what can be done.
Old 03-19-2005, 04:56 PM   #22
sandiegowrx
Member#: 41743
What is frustrating is that most people just repeat what others say. I'm not saying that what is said is right or wrong. But I would like to see some of the info the poster origianlly asked for; some concrete dyno #'s, etc from people who have personal expereince. And yes, I do know dyno #'s are subjective, but not nearly as much as butt-dynos and hearsay. Unfortunatley I havn't seen that many 16g dyno's yet. The ones I have seen are right around vf34/22 territory.
WHP:
lb/ft:
Mods:
General impression:
sandiegowrx is offline   Reply With Quote
Old 03-19-2005, 05:07 PM   #23
jaypine
Member#: 50398
2003 WRX Wagon
I have saved dynos of 16Gs, 18Gs, 20Gs, Greens, VF30s, VF22s,GT25s,GT30s,GT11s, 2L, 2.2L,2.5L,2.8L. It doesn't mean much unless it's the same dyno, tuner, conditions, etc. Even then? What do you want to see?
Old 03-19-2005, 05:13 PM   #24
line
Member#: 76189
WRX: Parking Lot
Racer in Training
sandiegowrx: It says you have a VF-34. Could you give me some info. At what RPM's does it spool? What mods do you have? What do you think about the setup overall?
jaypine: To be honest with you have have only seen one 16g dyno map i was hoping to see some others to see how they compare to each other and the vf34. I dont really care about the final # as much as the area under the cure and where the torque cure starts to flatten out
Old 03-19-2005, 05:21 PM   #25
sandiegowrx
Member#: 41743
Like I said earlier, #'s and graphs can tell me a lot more than hearsay or someone trying to decribe to me how fast/slow their car is in words. I just havn't seen many 16g dynos.
My VF34 is ported and is not working well w/ my AP and needs a custom tune. I am unable to hit target boost and only see 13psi max. In 4th gear, I hit my limited max boost at 3,100rpm.
I would love to see #'s from a few different cars w/ the Super16g. It looks like a very promising turbo.
Gauging Interest: Trade VF-34 for VF-39 NewGwrx NESIC Private Classifieds 14 04-16-2006 09:33 PM
WTB: VF-34 or VF-39 F3nom3ni Private 'Wanted' Classifieds 6 03-26-2006 11:06 PM
If you could do it again, VF-34 or VF-22? BMS Factory 2.0L Turbo Powertrain 31 03-22-2005 08:41 PM
Vf-34 or VF-39:which one do you like better?? RedScooby2004 Factory 2.0L Turbo Powertrain 24 06-11-2004 11:00 AM
VF-34 or Sr-30 StarDogChampion Factory 2.0L Turbo Powertrain 13 05-05-2004 09:32 PM
Message Board Statistics All times are GMT -4. The time now is 02:17 AM.
