Old 03-20-2005, 03:31 PM   #51
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Scotty.......
unkadave is offline   Reply With Quote
Old 03-20-2005, 03:37 PM   #52
BigClunke
Member#: 52488
2003 WRX MT
Originally Posted by Uncle Scotty
the TD05-16G was the stock turbo on at least one of the JDM STi's...v4, IIRC....and the TD05 is widely used in other countries and according to John Banks, there are more than one or 2 running 11's with them, no giggle gas, in the UK and the DSM world if FULL of 16G's.......
......so what's your point????
my point was that in this "community" we don't have alot of members with experience using that turbo. there might be lots of info over in the JDM market but, as far as this messageboard is conserned there is significantly less info avaliable than that of the vf series.
as you said, its the supporting mods that account for the difference. surely, different supporting mods will be better suited for the 16g than the vf's depending on flow characteristics.
truthfully, i am still in the research phase on these turbos. it's not as easy as you think to find helpful info directly related to the wrx. not everyone has seen a whole lot of posts and heard the info over and over. there was a time when you knew nothing about these turbos and everything seemed a bit overwhelming. i don't see why you would make it a point to specifically not help someone with some links that you have see in the past.
BigClunke is offline   Reply With Quote
Old 03-20-2005, 03:43 PM   #53
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....see Above...
Old 03-20-2005, 03:49 PM   #54
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Everybody is also different in what they think is a good turbo for them. ie. different driveng styles.
To me the vf34 was a waste of money,.. it was so close to stock. So I got the 22 and liked it. What else is there to say. I don't mind discussing the differences but realize,.. it is my world view or,... this guy claiming the 34 is the best thing since tits. I thought the 34 was a dissapointment. I already posted my vf22 278whp dyno. That car was plenty fast.
Am putting in a 2.5 Axis sb with an fpgreen right now. PS I would rather auto-X my $200, 94 Escort than my suby. The Suby is built for real life Oregon country roads not 12mph pylons.
Engine
catless
Ported & Polished VF22, by Eurosport, Eugene, OR
sti 565 injectors,
Perrin fuel rails,
XS-Hyperflo top mount I.C.
walbro Fuelpump,
B & B (div. w g) Down Pipe
Perrin uppipe,
Injen, cold air intake
Samco hoses,
Circle earth grounding kit
Tanaube Hyper Medallian Exhaust
large scoop w/sti splitter, radiator shroud.
Cusco heat shield
Helix oil catch can
heat wrap on downpipe
Electronics
AVC-R electronic boost control
UTEC on top of EcuTek, 4 out of 8 map selections, done PDX
Uniden GPS Radar detector
A pillar Defi EGT and boost gauges
Apexi Turbo Timer w /A/F readout
Suspension / Brakes / Wheels / Tires :
Tein coilovers (love em)*
Cusco rear sway bar / camber kit
Helix end links
sti engine / tranny mounts
sti pitch stop
Perrin pos. steering response system
Goodridge Stainless Lines - Front+Rear
Axxis Ultimate Pads
Racing Brake Slotted Rotors - Front
18 X 8" SSR 14.6 lb Competitions
225/40/18 Goodyear F-1 GS D-3's..... VerySticky
Trans.
RA hardened gears, synchros, bearings
ACT StreetLite Flywheel - 13.9 lbs
Clutch net clutch
Cusco Shifter Bushings
Being installed
Turboxs FM
2.5 stage 2 Axis motor
FPGreen
PE 800 cc inj
Alumn Radiator
P & P heads
Butterfly delete
P & P ex manifold
Perrin Turbo inlet hose
Big MAF intake
Stats
Mustang dyno / (Doc) Bailey pdx tuning / Eurosport
[email protected] (19.5psi?) boost 237# [email protected]
13.02 @105. / 0 - 60 4.6 / 147mph on GPS
ModsModshttp://www.clubwrx.net/forums/showthread.php?postid=577702#post577702
Old 03-20-2005, 03:58 PM   #55
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Go to club wrx and look thru the different mods.
Also - I work at a shop putting packages together. We sold a friend with a stock 04 wrx, a FP20G.
We bought all the supporting mods, and they will be going on in about two weeks. A one day install 166whp to about 260whp (includes an EcuTeK) Then just a drive to pdx for a dynotune, and 280 depending on how much more,........ he if any he wants.
Sweating over is vf34 is really pretty small stuff. You wont feel much difference. Really.
Old 03-20-2005, 05:34 PM   #56
sandiegowrx
Member#: 41743
I have the VF34, and yes I have been thinking about getting another turbo. The problem is that I can't hit target boost with the Cobb off-the-shlef map, so I havn't been very pleased with it. There is nothing wrong w/ my vf34, it just needs a custom tune. I went w/ the vf34 so I didn't have to get a custom tune (save $). But of course you always want more... I figure if I have to get a custom tune, why not just throw on a bigger turbo? I'm not sure If I'll go w/ a 16g because I'm not sure if it will be that much better than my vf34. The Super16g looks appealing... but I may just go for the 18g.
sandiegowrx is offline   Reply With Quote
Old 03-20-2005, 08:46 PM   #57
line
Member#: 76189
WRX: Parking Lot
Racer in Training
Seems like more and more poeple are starting to run and love the 16g. I have to admit thats that easy rebuild and being upgradeable is a huge plus. I wish I could spend a month swapping turbos to see which I like the best but that is just wishful thinking. Still would love to hear more of the 16g owners out there impressions(if there is anymore of you).
line is offline   Reply With Quote
Old 03-21-2005, 03:47 AM   #58
nfx
Member#: 42960
GC8 wrx
blck
Originally Posted by Diode663
There ARE stock turbo cars running 12's.....so a 12.4/115 on a 34 is news
I belive you, but can you provide a link to this car and its mods?
hope it works:http://www.rexnet.com.au/forum/viewt...=9785&start=75
check under user name CR
stock 2.0ltr,box,clutch
it ll do high 11s in time as is....car is tuned 2morrow ....running Very rich!!
and if u look on 1st page there is another 1 doing [email protected] mph and not the only 1s
nfx is offline   Reply With Quote
Old 03-21-2005, 11:06 AM   #59
line
Member#: 76189
WRX: Parking Lot
Racer in Training
Anyone runnign a super 16g on a EJ205 engine? still looking for more 16g owner feed back!!! STill looking for feedback from anyone putting down 260-280whp and has a very street freindly setup.
Old 03-21-2005, 11:51 AM   #60
Diode663
Member#: 70325
03 Wrx Sedan
WTB Rear Lateral Links
Thank you very much nfx. I take it its ur car?
Diode663 is offline   Reply With Quote
Old 03-21-2005, 07:45 PM   #61
nfx
Member#: 42960
GC8 wrx
blck
it is my car for the last 5 yrs
Old 01-04-2009, 03:15 AM   #62
mogunz
Member#: 143488
Originally Posted by ilivas View Post
vf34 is not ball bearing, it's roller bearing.
Go with the 16g.
vf34 in fact is ball-bearing, while vf30 is not.
mogunz is offline   Reply With Quote
Old 01-04-2009, 03:29 AM   #63
JSarv
Member#: 163445
l33t *******
[email protected]
Little late bud
JSarv is offline   Reply With Quote
Old 01-04-2009, 07:44 AM   #64
JoePokah
Member#: 154734
2005 Legacy GT LTD
only a few years. Like Bush!
Good Stuff.
Jeff
JoePokah is offline   Reply With Quote
Old 01-04-2009, 12:54 PM   #65
ayobreezie
Member#: 117855
2003 O.O
AWP
Hahaha.
ayobreezie is offline   Reply With Quote
Old 01-04-2009, 01:24 PM   #66
ch04awd
Member#: 199140
05 wrx
Originally Posted by JSarv View Post
Little late bud
haha 2 year old thread
ch04awd is offline   Reply With Quote
Gauging Interest: Trade VF-34 for VF-39 NewGwrx NESIC Private Classifieds 14 04-16-2006 09:33 PM
WTB: VF-34 or VF-39 F3nom3ni Private 'Wanted' Classifieds 6 03-26-2006 11:06 PM
If you could do it again, VF-34 or VF-22? BMS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 03-22-2005 08:41 PM
Vf-34 or VF-39:which one do you like better?? RedScooby2004 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 06-11-2004 11:00 AM
VF-34 or Sr-30 StarDogChampion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-05-2004 09:32 PM
