#1 |
Subtly Outspoken
Moderator Member#: 238
Vehicle:99 Ver6 Recreation JDM Speedwagon 3 LSDs..:) |
If so...what did you do with Immobilizer in the ECU....or did you bypass it...if so how??? just curious...I havn't seen a Hydra on a 05 yet..and I am thinking that the immobilzer is why...
Thoughts and comments??? Bill
#2 | |
Member#: 54918
When the factory ecu is removed the immobilizer is disabled. Thanks, Phil www.elementtuning.com |
#3 |
Member#: 44193
South East
Vehicle:2008 WRX STi Silver |
I have it runing on mine works great. A non-issue with Phil's Hydras. I can tell you the immobilizer IS an issue if you get an 05's ECUTECK flashed and they resend you a different ECU. Don't ask how I know this...
#4 |
Subtly Outspoken
Thanks Phil...preciate the feedback....You say the immobilizer is disabled on the 05...hmmmmmmmm....wonder if a 04 ECu will work in place of the 05...with no immobilzer...probably not...because the code is stored in ECU in order to get the car cranked...so no code no crank...and no cruise...
just checkin my options ... Bill |
#5 |
Member#: 54918
Bill,
An 04 ECU will not work in your car not only because of the immobilizer but also because it's a different ecu with many wire harness changes. They are not interchangable. Element Tuning offers an 05 specific Hydra for your STI. Thanks, Phil www.elementtuning.com |
| Thread Tools | |
| Display Modes | |
| WTT: Racinf hart cpf for any 05+ sti wheel any color | toyo764 | NESIC Private Classifieds | 2 | 05-20-2010 12:45 AM |
| WTT: 04-05 STi UTEC For Hydra + $ | noshow907 | Private 'Wanted' Classifieds | 2 | 04-26-2006 06:49 PM |
| need to change the brake for the 05 sti with 18k miles any good suggestion? | fishdotcom | Brakes, Steering & Suspension | 7 | 08-09-2005 09:55 PM |
| Any pics of 04/05 STi with FMIC? | evo9 | Interior & Exterior Modification | 15 | 02-24-2005 09:47 PM |
| Anyone running WI with a Hydra yet? | wgknestrick | Other Engine Management | 4 | 01-26-2005 11:50 PM |
