Old 03-20-2005, 01:51 PM   #1
Skidd
Member#: 1853
GC6 Supercharged
STM
Default My00 4200 RPM Hesitation Solved!
I (like many other MY00rs owners) have suffered with that 4200 RPM hesitaiton for a while now. I'd say for about the last 20k or so miles. I knew it was something to do with the Ignition system, but didn't know what. And countless searches on this site and others didn't produce any answers. Nobody could quite figure out what it was. ECU Resets and and the lot did nothing.
But.. as of yesterday, it's gone. My care no longer does it. Smooth power all the way through the Revs. And the answer was way too obvious and easy.
I did 2 thing to my car on Saturday. One of the two was the fix. And I"m pretty sure I know which it was. I replaced the Spark Plugs and the Plug Wires. Yep.. thats it! Fixed. I don't believe the wires were the fix though. I'm sure it was the plugs. Cuz my old plugs were WAY worn out. I had a set of (here it comes) Bosch Plat+4s. They went in at about 20K miles. And bosch swares they are good for alot longer than a standard plug. But, with my ar now at just over 60K miles, I'm doing a bunch of tuneup stuff to my car. The plugs are due, that I know, but they should still be atleats in fair condition.. right?
Long story short, the +4s were SHOT! 2 of them had the center contact just about level with the white insulator. the other 2 had the center contact burnt down inside the insulator. That isn't good. No wonder the Ignition system was doing strange things. The spark it was making sucked.! It was so bad, that at Idle, if I just blipped the gas, the motor would just hesitate a fraction of a second then rev up.
Now, sure, these plugs have been in for about 40K miles. But a set of Plats should do alright for that long. And since the hesitation has been happening for about 20K miles. That means that the plugs were likely gone or going after only 20K in my car. What the hell was the point of Plats if they last the exact same as a standard plug? Sheesh... what a waste!
So.. in went a set of NGK V-Power plugs, and a new set of Factory Subaru wires, an ECU Reset.. Fire up my car, and I notced the difference RIGHT AWAY! The throtle response at idle was better. Go for a drive around the block, it just feels smoother when I get on the gas. Hit the Highway onramp, 3rd gear, pass the 4200 mark (I can ALWAYS get it to hesitate doing this).. and.... NOTHING!! Smooth. Nice! No momentary lack of power. It just felt smooth and strong!
Moral of my Story.
Bosch Plat+4 SUCK! NGKs RULE!
Shane.
Skidd is offline   Reply With Quote
Old 03-20-2005, 01:54 PM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
or just get the ecu reflash that Subaru had as a recall and that will solve it.
sidewayz is offline   Reply With Quote
Old 03-20-2005, 02:03 PM   #3
Handsdown
Member#: 29355
my bosh plats failed in 4k miles
denso standards in 2k miles
for the EJ25, it's NKG or nothing.
Handsdown is offline   Reply With Quote
Old 03-20-2005, 02:20 PM   #4
mofugga
Member#: 19540
2000 old skool RS
BRP
subaru's dont' like bosch plugs the the ecu reflash is helpful also
mofugga is offline   Reply With Quote
Old 03-20-2005, 02:33 PM   #5
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I call Bosch plat +4 fuel blockers. All the extra electrodes do is block fuel from getting to the spark as quick. Worst invetion ever, i can't belive they still sell them.
RS_to_WRX_swap is offline   Reply With Quote
Old 03-20-2005, 02:38 PM   #6
Skidd
Member#: 1853
GC6 Supercharged
STM
Huh? Reflash? I never found any info about that? Was it a factory recall? What years? Why does Subaru hate letting it's customers know about recalls?
Old 03-20-2005, 03:02 PM   #7
mofugga
Member#: 19540
2000 old skool RS
BRP
it's not really a recall, it's called a "campaign"
next time you go to the dealer ask them about it. takes a couple minutes for them to do
Old 03-20-2005, 03:18 PM   #8
bheinz57
Member#: 37870
2012 ISM WRX
'16 Forester XT
Skidd, let us know if you start having misfire/hesitation again within a couple hundred miles or so. The coil can be bad and made the wires bad/plugs foul. If so, you may see the dame symptoms sometime down the line. Brian
bheinz57 is offline   Reply With Quote
Old 03-24-2005, 03:45 PM   #9
Skidd
Member#: 1853
GC6 Supercharged
STM
Just an update, I have a nice long commute each morning, and it's been almost 500 miles now,and she still runs fine.
Old 03-25-2005, 01:06 AM   #10
DJ 9iron
Member#: 11349
2016 Mustang GT
Before I changed my plugs last fall, my hesitation came and went... Since the change, it hasn't returned. Oh well.
DJ 9iron is offline   Reply With Quote
Old 03-25-2005, 03:05 AM   #11
horrorbiz
Member#: 77290
15 VW GTI / FiST
I had slight hesitation problems. I got new spark plugs with a 90k service on Tuesday and it is completely gone and feels like a new car.
horrorbiz is offline   Reply With Quote
Old 03-25-2005, 10:37 AM   #12
DreddRS25
Member#: 51642
2008 WRX
May I ask what color your car is?
I've seen two blue, one silver, one black, and two green GC8s in SA. Is that one of you? I've got a coupe BRP 01.
DreddRS25 is offline   Reply With Quote
Old 03-25-2005, 11:03 AM   #13
Skidd
Member#: 1853
GC6 Supercharged
STM
There sure are not alot of Subies here are there?
I'm driving a Silver MY00 sedan. It's a dead give away, because although it's a 2000 model, I'm from Canada, so it has the the "L" style fog lights.
I've yet to see a 4-door silver GC in SA yet. But I've seen a handfull of the others. Mostly coupes though. What color is yours?
My Girlfriend loves the fact that we Subie owners wave to each other as we pass.
Power Drop at 4200 rpm thru 5300 rpm???? AScooby4U Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-22-2006 02:22 PM
Free flow exhuast - lost 4k rpm hesitation ChaosThom Normally Aspirated Powertrain 9 06-05-2001 05:50 AM
('93-'01) Hesitation at 4200 RPMs? Layman Impreza Forum 2 04-29-2001 06:23 PM
Noise during 3500k rpm hesitation AaronRS Technical Forum Archive 1 09-03-2000 12:14 PM
Low RPM hesitation problems.. please help! (cont. ) Orbiter Technical Forum Archive 0 08-18-2000 04:47 AM
