Old 03-20-2005, 03:27 PM   #1
sjtangb21
Member#: 83433
Default 96 impreza 2.2L thermostat installation guide
does anyone know?
cg
sjtangb21 is offline   Reply With Quote
Old 03-20-2005, 04:12 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
drain coolant, remove lower hose to water pump, remove two retaining bolts that hold the thermostat housing to the water pump (this is the part you took the lower hose off of), replace the thermostat and gasket. re-assemble, dont over tighten the housing bolts.
refill with coolant, follow the procedure in the owners manual for that.
Jay
Old 03-21-2005, 12:40 AM   #3
Impretzle
Member#: 74900
2008 STI
black
from what I've heard Subarus can be picky about how you refill the coolant, and the block is made of aluminum so if it does overheat it can cause damage more quickly
So like McDade says, you might want to invest in that FSM to find out the exact procedure
Impretzle is offline   Reply With Quote
Old 03-21-2005, 01:25 PM   #4
sjtangb21
Member#: 83433
you have any pics of where the thermostat is?
Old 03-21-2005, 01:51 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
It's on the bottom of the engine inside the housing that the lower radiator hose connects to.
Be careful, even after you drain the coolant, there will be a gush when you yank the t-stat out of there.
Tim Sanderson is offline   Reply With Quote
WA/OR- 96 Impreza 2.2L 2dr- $5000 [Fantastic Shape] Walker Dooley Private Vehicle 'For Sale' Classifieds 6 11-02-2008 05:26 PM
96 Impreza 2.2L 2Dr- FOR SALE! Walker Dooley NWIC Private Classifieds 36 10-27-2008 06:11 AM
[WA/OR] 96 Impreza 2.2L 2dr Walker Dooley Private Vehicle 'For Sale' Classifieds 0 10-10-2008 06:38 PM
96 impreza 2.2L timing belt and water pump installation guide sjtangb21 Normally Aspirated Powertrain 0 03-25-2005 09:36 PM
('93-'01) 96 impreza 2.2L thermostat installation guide sjtangb21 Impreza Forum 1 03-20-2005 04:29 PM
