Old 03-20-2005, 09:55 PM   #1
Hzracing
Member#: 77294
2005 WRX Wagon
Default napa 1357 / wix 51357 oil filter
Found a differnet oil filter by accident today
Napa 1357
Wix 51357
Attributes: Oil Filter (Gold)
Style: Spin-On Lube
Height (Inches): 3.402''
Height (mm): 86.41mm
O.D. (Inches): 2.685''
O.D. (mm): 68.2mm
Thread Size (mm): 20 x 1.50mm
Gasket O.D. (Inches): 2.475''
Gasket I.D. (Inches): 2.173''
Type of Packaging: Box
Subaru 15208AA080
Napa FIL1365
Wix 51365
Style: Spin-On Lube
Height (Inches): 2.577''
Height (mm): 65.46mm
O.D. (mm): 68.2mm
They seem to be the same internally, just that the 1357 is taller
May be an answer to people wanting a larger filter
David
Hzracing is offline   Reply With Quote
Old 03-21-2005, 09:53 PM   #2
outbckspt96
Member#: 82717
the subaru oil filter # has changed...it was 15208AA080 but it's now 15208AA100....and u can still use the old 15208AA060 if u want to stick with the larger filter...
outbckspt96 is offline   Reply With Quote
Old 03-23-2005, 07:04 PM   #3
outbckspt96
Member#: 82717
News
i found out more today about the oil filters...when u first got ur turbo subaru...it came with the oil filter 15208AA060 and then was replaced by a 15208AA080 which is smaller and made in Japan....this smaller filter helps...the larger filter collects more heat from the exhaust and in extreme conditions can cause a blocked filter.....the part number 15208AA080 changes to 15208AA100....this new filter (AA100) is exactly the same as the AA080 except fot the emblem on the side and the outline around the word engine on top....and it's also produced in the US now....that's the reason for the change...so on all turbo models the AA080 and the AA100 should be used...and on the non-turbo models stick with the AA060 until they don't make them anymore...
Old 03-23-2005, 09:02 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
To add to this....
Purolator changed their Pure One filter to a smaller version as well. I found this out 3-4 weeks ago with my last oil change. A side by side comparo reveiled that the new filter is MUCH smaller than their old filter. The part number changed too.
Old 03-23-2005, 09:49 PM   #5
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Originally Posted by Unabomber
To add to this....
Yes, I noticed this quite a while ago, but the change was made only for the 2004 & 2005 WRX. The 2003 & 2002 WRX are still listed as the bigger PL14460. This is according to www.pureoil.com.
jac04 is offline   Reply With Quote
Old 03-23-2005, 10:54 PM   #6
outbckspt96
Member#: 82717
subaru recommends that all turbo models use the smaller filter...due to heat...it's a very rare case but a few filters have been clogged do to extreme temperature of the oil....
Old 03-23-2005, 11:57 PM   #7
AWDSpec
Member#: 82758
o5 WRC
Pinkish
Good info.
AWDSpec is offline   Reply With Quote
Old 04-01-2005, 08:20 PM   #8
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
This is what they list for 02 WRX now
Item#: FIL1334
Price: $ 6.79
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Usually ships in 24 hours.
Attributes:
Style: Spin-On Lube
Height (Inches): 3.194''
Height (mm): 81.13mm
O.D. (Inches): 3.252''
O.D. (mm): 82.6mm
Gasket O.D. (Inches): 2.49''
Gasket I.D. (Inches): 2.01''
Gasket I.D. (mm): 51.054mm
thats very confusing - and I don't like it one bit
infantsam is offline   Reply With Quote
Old 04-01-2005, 08:47 PM   #9
BillJC
Member#: 31002
Item#: FIL1334
This is the filter that I have been using for 3 years now. NAPA 1334. I walk in and tell them I need an oil filter for a Toyota, Honda, Nissan, Mazda, Subaru....
BillJC is offline   Reply With Quote
Old 04-01-2005, 08:57 PM   #10
infantsam
Member#: 51280
2015 WRB WRX
KNSBrakes
The diameter change was what confused me - it's a new car to me and i always do my own oil and haven't seen this before -
It was a rather comedy of errors change -
confusing filter application so I ran to NASIOC - (east coast all store closed etc - wife pissed that I'm still at work and she may have to come get me)
thought I was on the 4th quart not the fifth so put 5 quarts in (vs 4.8)
missed drain plug gasket......(in a hurry to get done)
so removed plug and stuck finger in real quick to save 30 bucks worth of Mobil one....
Got gasket on w/ one hand while finger in oil pan.....
Got plug back in without spilling much.....ABOUT .2 quart!!!
SO I"M ALL SQUARE!!! guess you had to be there!!
I better go back to engineering where I can't hurt anyone!
Longer oil filters anyone? - Wix 51365 vs. 51356 Drivinwest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-06-2009 05:24 PM
Best Oil filter is a WIX? ludecrous Service & Maintenance 27 06-23-2009 04:40 PM
Oil filter question. how to open a wix oil filter... Keith Off-Topic 33 12-18-2007 05:39 PM
Question - Oil filter part # for Wix OEM sized filter digitalmethods Service & Maintenance 6 04-22-2006 08:27 PM
New STI replica strut bar and WIX oil filter wes Private 'For Sale' Classifieds 4 02-14-2004 04:18 PM
