Old 03-21-2005, 01:03 AM   #1
boscal45
Member#: 79190
1999 Impreza L
Default intakes
i spent the last hour or so looking through the cai for n/a scoobies thread. i was considering getting a weapon r dragon intake, until everything i read about them said that the dragon filter sucks. what i do like about the dragon intake is that it is fairly cheap (135 with shipping) and they make them to fit specific models so i wouldnt have to worry about it fitting in my 99 impreza L. are the filter sizes universal so that if i do not like the dragon filter, i can just get another filter to replace rather then replacing the entire intake? and if that is the case, does the increased performance come from just the filter (meaning, would the $135 weapon r intake with a better filter be better then a $50 intake with a good filter or would it basically be the same thing?) thank you pete
boscal45 is offline   Reply With Quote
Old 03-21-2005, 01:07 AM   #2
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
hey i have a 99 L myself and i spent a lot of time looking this up. your best bet is: ganzflow. plain and simple. i am a cheap bastard so i ended up making my own. its quite easy but i really cant feel the power. so i say spend the $150 for a ganzflow.
svek is offline   Reply With Quote
Old 03-21-2005, 01:15 AM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Search/browse the NA forum....NA and FI..forced induction are 2 different ballgames...
Old 03-23-2005, 06:06 PM   #4
Sober_One
Member#: 83322
2000 Impreza 2.5RS
Sylverthorn
The best intake for a N/A Subaru is made by COBB.
Hands Down, No Questions Asked, The Best There IS!!!!
You can find it at their WebPages... cobbtuning.com
Sober_One is offline   Reply With Quote
Old 03-23-2005, 06:12 PM   #5
svek
Member#: 82259
1999 impreza 2.2L
but we dont exactly know if the cobb fits a 99L. the whole maf thing.
Old 03-23-2005, 08:45 PM   #6
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT Stage2
sure it does!
it fit my 99 forester - get one!
Big_Hitter is offline   Reply With Quote
Old 03-23-2005, 09:22 PM   #7
cabe
Member#: 55864
2002 WRX sedan
HAHAHA, the dragon filter does suck. I had the weapon r with dragon filter when I had a 99 impreza L. It looks so ricey I was embarrassed to pop my hood (except for little kids, LOL). It still sounded cool and I could feel a difference, but don't get one, get something better.
cabe is offline   Reply With Quote
Old 03-24-2005, 01:17 AM   #8
allsubaru83
Member#: 60122
2008 M5
Space Grey
I have the rallitek intake, yeah it is for a 02 impreza with a MAP and i have a MAF, only difference is the intake tube is longer. but fits really snug under the hood
allsubaru83 is offline   Reply With Quote
Old 03-24-2005, 01:29 AM   #9
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
Do you have a MAF in there somewhere?
Originally Posted by Philistine
sure it does!
gtwagon941 is offline   Reply With Quote
Old 03-24-2005, 02:22 AM   #10
mtskibum16
Member#: 83708
2005 FXT
CGM
If you follow the pipe from the throttle body you will see the MAF section....it is the first black portion from the TB.
mtskibum16 is offline   Reply With Quote
Old 03-24-2005, 04:58 AM   #11
Imprezanize
Member#: 45273
2002 Impreza 2.5 RS
I got COBB CAI no regrets
Imprezanize is offline   Reply With Quote
Old 03-24-2005, 08:20 AM   #12
Big_Hitter
Member#: 10831
2009 FXT Stage2
yep, second black thing
Old 03-24-2005, 08:30 AM   #13
InsaneAznKid
Member#: 57037
1998 Audi A4 1.8T
Pearl White
i thought cobb CAI was only for MAP?
InsaneAznKid is offline   Reply With Quote
Old 03-24-2005, 09:31 AM   #14
jeisen
Member#: 27258
who dat be dat was?
i also am running cobb. if ur going to spend the money on an intake and are worried about performance and not sound, u gotta go with the cobb.
http://cobbtuning.com/impreza/powerpackage1.html#cai
jeisen is offline   Reply With Quote
Old 03-24-2005, 10:30 AM   #15
Big_Hitter
Member#: 10831
2009 FXT Stage2
negative
Old 03-24-2005, 08:00 PM   #16
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
So did you do a dyno test?
RS_to_WRX_swap is offline   Reply With Quote
Old 03-25-2005, 04:01 AM   #17
keirnna
Member#: 50167
1996 Subaru STI RA
Cobb makes two CAI. One for MAF which should work on '99 RS's and all other subies with the same intake set-up, ie Impreza L's, and Foresters. What I want to know is why I can't use the intake on my 1998 RS. I don't see what the difference is. Both use MAF, but I am sure it will work.
keirnna is offline   Reply With Quote
Old 03-28-2005, 10:15 PM   #18
Sober_One
Member#: 83322
2000 Impreza 2.5RS
Sylverthorn
[quote] Quote:
So did you do a dyno test?QUOTE]
No I haven't...
However, I've been researching intakes for MY00RS for years. I've read many and cliped many articles on the various intakes, with their pros and cons. Forums and review type webpages as well as other sources have been used for information gathering. Cost was in there at the end.
By the documentation available, by both owners and the manufactures and by customer satisfaction I believe COBB is the best intake for a N/A Subaru.
A close second would be the Larry Ganz GanzFlow Cold Air Intake with a K&N or other type drop in filter.
Why?... Because both systems keep "user-friendly" maintenance in mind, reduced turbulence, better airflow, and exacting fit. No other companies offer a solid CAI and the other features mentioned.
BTW, according to some the stock air box and intake system aren't as bad as others may lead you to believe.
Old 03-29-2005, 07:35 AM   #19
Sober_One
Member#: 83322
2000 Impreza 2.5RS
Sylverthorn
Here is a link to a good description and other information on the GANZFLOW
http://www.imprezars.com/ganzflowintake.htm
Old 03-29-2005, 07:39 PM   #20
RallySuby
Member#: 64600
'01 2.5RS
black
jeisen,
i'm also stuck between larry's and cobbs. any sound difference??? i know larry's uses the stock airbox, would this make it quieter??
RallySuby is offline   Reply With Quote
Old 03-29-2005, 07:46 PM   #21
Siper2
Member#: 1134
2007 BMW 328xi wagon
Popular opinion leans towards Cobb for sure, but if money's tight you can pick up a PDM CAI from www.pdm-racing.com . (Click on "Subaru Corner" on the site to see it.)
They're $50 brand new and are an easy alternative to making your own. They're very similar to the first-generation GanzFlow (by Larry Ganz) CAIs, though the new Ganz CAIs are of a different shape.
I have a PDM. I like that it retains the OE airbox, but then again I'm one of the skeptical sorts, so the "water suck" thing, even if unrealistic, does keep me on my toes a bit.
=S2=
Siper2 is offline   Reply With Quote
Old 03-29-2005, 07:46 PM   #22
goNads
Member#: 61888
2003 Outback Sport
Midnight Black Pearl
it (Ganz) will be MUCH quiter than the COBB...
goNads is offline   Reply With Quote
Old 03-29-2005, 08:42 PM   #23
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
=S2=
The stock intake is just as likly to ingest water as the ganz style, if not more.
Unless you do this you will be ok:
Old 03-29-2005, 09:00 PM   #24
svek
Member#: 82259
1999 impreza 2.2L
howcome? isnt the snorkus supposed to keep water out/?
Old 03-29-2005, 10:37 PM   #25
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
True, but I was talking about the location of the beginning of the intake. Brands like Injen place the filter to low, so that in areas like where I live and it rains all the time; the filter is too near the ground. It’s kind of pointless on an AWD car to be scared of puddles.
FS : Grimmspeed Intake Manifold w/ extras, ID 1000cc bigboy Engine/Power/Exhaust 17 07-17-2010 02:39 PM
Stock 07 STI intake manifold Built07 Engine/Power/Exhaust 6 06-30-2010 01:09 PM
FS: APS Pod Intake, APS 3" Turbo Inlet, OEM 04-05 Fog Lights with Bezels lancelucas NWIC Private Classifieds 17 06-09-2010 02:05 PM
FS : Coming to Jacksonville, FL. STi intake manifold, Springs, Misc. 48mpg South East Region Private Classifieds 6 06-04-2010 08:52 AM
Intake worth it?(ProTune) Needles Factory 2.5L Turbo Powertrain 4 06-02-2010 02:46 PM
Message Board Statistics All times are GMT -4. The time now is 07:02 AM.
