Old 03-21-2005, 02:12 AM   #1
wantagc8
Member#: 71373
Default 1998 Legacy GT limited
How would you guys rate this car, i have seen some bad reviews on reliablitiy.
What do you guys think?
My friend is looking at a 1998 with 87k miles for 9 grand.
wantagc8 is offline   Reply With Quote
Old 03-21-2005, 02:13 AM   #2
wantagc8
Member#: 71373
Default 1998 Legacy GT Limited
Old 03-21-2005, 09:30 AM   #3
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Never heard anything bad about them. Should be a good car if it's been taken care of.
Acostafan is offline   Reply With Quote
Old 03-21-2005, 09:45 AM   #4
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
1998 2.5L DOHC Subarus had some head gasket issues. The chances of head gasket failure are higher for the Phase I motors used, but it's not neccessarily imminent. If the car is in good shape otherwise, I wouldn't pass it up.. but $9k seems a little high to me.
KBB rates the LGT Ltd. @ $7,875 for excellent condition (private party).
Old 03-21-2005, 10:27 AM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
if its a 2.5, the only concern is the headgaskets...do a search for complaints on this. other than that, its not a bad car at all.
fibuz
fibuz is offline   Reply With Quote
Old 03-21-2005, 11:02 AM   #6
sha_zapple
Member#: 41012
1998 Legacy L
As fibuz said, headgaskets about the only major problem. That price is a bit high though.
sha_zapple is offline   Reply With Quote
Old 03-21-2005, 11:04 AM   #7
jpapanas
Member#: 65110
2003 LSE Wagon
I purchased a 1998 Legacy GT 5MT Wagon last summer with about 83,000 miles. It's my first Subaru and I'm very happy with it. It's smooth, tight and has been very reliable so far through a Canadian winter.
I have read about the headgasket failures and that would be a major expense if it occurs. I think one of the symptoms is a fluctuating coolant temperature gauge, so watch out for that during the test drive...
Regards,
Jim
jpapanas is offline   Reply With Quote
Old 03-21-2005, 12:03 PM   #8
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Great car except for the headgasket. Make sure it passes a compression test. It might have started to fail and the owner is unloading it before it gets worse.
linsavy is offline   Reply With Quote
Old 03-21-2005, 12:30 PM   #9
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
are you looking at the red one in craigs?
express_wagon is offline   Reply With Quote
Old 03-21-2005, 12:40 PM   #10
MY03ImprezaRS
Member#: 44808
2003 Impreza RS
Platinum Silver
I would agree $9000 is a little high, unless they've replaced the motor already because of head gasket problems they had to fix.
Otherwise it sounds like a solid machine if the $$ is lowered a bit.
MY03ImprezaRS is offline   Reply With Quote
Old 03-21-2005, 03:57 PM   #11
jellybytes
Member#: 77414
1989 '89 XT6 '97 SVX
2004 Outback VDC
I have a 1998 Legacy Gt that I purchased new. It now has about 142k. I've had some work done on front steering/suspension for a total of about $400. This may be the fault of the roads where I live and the speed I drive them. I also had the front cam seal leak fixed at 105k when the timing belts were done. Finally I just replaced the windshield wiper motor with one I pulled from the u-pull it. The gear casing had shattered during one particularly cold morning. So far the headgasket problem has not reared its ugly head.
Overall I have been happy with the car. This is my second car.
My first was a 1989 XT6 that I purchased new and sold with 120k on it to buy the Legacy because it was rustng out and I needed the four door family car.
jellybytes is offline   Reply With Quote
Old 03-21-2005, 08:43 PM   #12
wantagc8
Member#: 71373
Thanks for the info.
We went to check it out this morning, it was nice, fully loaded sun roof leather. It had one spot on the back left corner that looked like a scrape or something that was painted over. The other thing was when you gunned it made a almost turbo sounding woosh-squeal. Any ideas?
Old 03-21-2005, 08:44 PM   #13
wantagc8
Member#: 71373
Old 03-21-2005, 08:51 PM   #14
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
When I first bought my car, the dealer has reassembled the intake incorrectly causing a similar sound. I'd check out all of the intake piping and filter. Also, turn off all accessories(radio, ac, etc) and see if it still does it.
Actually, just goto your local dealer(if the car isn't being sold from there) and get a full inpsection done along with compression test etc. This should tell you a lot about the car. A few extra things, check that there are 4 of the same tires on it with equal tread. Mis-matched tires/treads is bad (with all AWD cars). Other than that, everything should be straightforward.
Good luck.
fibuz
Old 03-21-2005, 09:49 PM   #15
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
I have the exact same car. Blahh the Limited only came in AT, but is otherwise a common GT aside from the leather and color-matched skirts. I’m in the process of swapping my entire drivetrain over to a WRX powerplant. And as a result, may have the only 5MT “Limited” around..
xcntrk75 is offline   Reply With Quote
Old 03-21-2005, 10:14 PM   #16
wantagc8
Member#: 71373
Old 03-21-2005, 10:15 PM   #17
wantagc8
Member#: 71373
Old 03-22-2005, 12:18 AM   #18
masube
Member#: 59226
2005 Sti
wow that a clean white legacy.
masube is offline   Reply With Quote
Old 03-22-2005, 02:55 AM   #19
wantagc8
Member#: 71373
yeah i know, didnt see more than a ding or two, and the scrape on the back. Someone told me it might just be the A/C belt. Any other ideas on the noise.
Old 03-22-2005, 03:41 AM   #20
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Huh ?
My 1999 Legacy 2.5 GT Limited has a five speed manual transmission. While the there were very few 5-speed limiteds available, they did exist.
I believe that all '98 & '99 GT Limiteds came with the moon roof standard, where the regular GT's featured the moon-roof as an extra-cost option (95% of the GTs came from the factory with the moon-roof, but it was still treated as an extra cost "option"). There are SOME regular GT's out there that do not have the moon-roof. (I find that the moon-roof restricts head room and isnt really very comfortable for me).
Also Unlike the plain-jane regular GT's both the 1998 and the 1999 Limiteds featured special Polished GT Limited wheels with gold painted sections that look very stunning on the shiney dark black models (although these wheels just dont look right on a silver Legacy).
Jonathan is offline   Reply With Quote
Old 03-22-2005, 03:54 AM   #21
Jonathan
Member#: 4021
1999 Legacy GT Ltd
While I cant be certain from the photo, it LOOKS like those are just REGULAR GT wheels on that Limited. The regular GT wheels are painted silver, while the LIMITED GT wheels are a shiney polished alloy with GOLD painted sections.
While it probably doesnt matter a whole lot to you, assuming these are just regular GT wheels, act like it does and ask the dealer to lower his price because it doesnt have the special GT LIMITED wheels.
Old 03-22-2005, 07:29 AM   #22
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
I always get confused with the gold vs. silver GT wheels too. My 98 GT Limited came off the show room floor with the silver wheels. So yes both silver and gold were available stock.
Old 03-22-2005, 07:39 AM   #23
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Huh ? My 1999 Legacy 2.5 GT Limited has a five speed manual transmission.
In 1999 it was the 30th anniversary edition of the Limited GT, which coincidentally came with the 5MT standard and the 4EAT optional.
In 1998 the GT Limited was only available with the 4EAT.
Believe me this isn’t just coming out of my a$$, I too had to look it up…
Old 03-22-2005, 07:42 AM   #24
JeffyP86
Member#: 44353
That looks a lot like my car except mine is a year older.. I only paid $6500 for mine though and it had 62k miles on it.. Talk them down on the price.. I bet if someone traded it in they only gave them ~$4500 for it.
JeffyP86 is offline   Reply With Quote
Old 03-22-2005, 03:53 PM   #25
wantagc8
Member#: 71373
ok defintely have him lower the price, and what should we do about the squeal?
1998 Legacy GT Limited 77k miles fangtl Private Vehicle 'For Sale' Classifieds 2 05-09-2006 06:00 PM
FREE 1998 Legacy GT Limited OEM exhaust cyyeo430 Bay Area Impreza Club Forum -- BAIC 1 04-24-2005 10:19 PM
OR FS: 1998 Legacy GT Limited White Kotir North West Impreza Club Forum -- NWIC 3 05-26-2004 05:42 PM
FS 1998 Legacy GT, Limited, 30th Annv. MKIVSupra Legacy Forum 12 05-20-2003 05:52 PM
FS 1998 Legacy GT, Limited, 30th Anniv edition MKIVSupra Mid West Subaru Owners Club Forum -- MWSOC 9 05-20-2003 05:10 PM
