Old 03-21-2005, 04:09 AM   #1
feelthebreak
Member#: 32411
Default rear differential bushing kit.
does anyone know if this kit is easy to install?
thanks
feelthebreak is offline   Reply With Quote
Old 03-21-2005, 04:37 AM   #2
bluelinescooby
Member#: 48881
2009 1125CR
1996 Neon ACR
That depends largely on what you're talking about. If you're referring to Whiteline's little yellow donuts that sandwich the diff outrigger bushing, then yes, very simple, half an hour, tops. If you're talking about a GrpN bushing set, that may take you quite a while, depending on your level of experience and/or patience.
bluelinescooby is offline   Reply With Quote
Old 03-21-2005, 04:48 PM   #3
feelthebreak
Member#: 32411
sorry about that. yes i`m referring to the whiteline kit.
Old 03-22-2005, 12:22 AM   #4
bluelinescooby
Member#: 48881
2009 1125CR
1996 Neon ACR
Yup, good easy mod. I had them on my 02 WRX and only ever had one complaint about them: NVH wasn't bad except for one particular spot between 3000-3200rpm when the whole car would vibrate ever so briefly during full or almost-full throttle acceleration. It eventually got to where I barely even noticed it... I got another set for my 05 and I'll probably install them again.
Old 03-22-2005, 09:31 AM   #5
Timdog1650
Member#: 45516
MY04 STi
Yeah, those are easy, steering racks bushings are a little bit trickier and need like an extra child's hand to pull the stock one out. Find a 6 year old and get him to put his paw in there to get it out for you...ew that sounds wrong, but you know what I mean.
Timdog1650 is offline   Reply With Quote
Old 03-22-2005, 10:56 AM   #6
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
Does anyone know if there is a write up on this? ScoobyMods is a no go. Also, are there Group N bushings available as well as the Whiteline?
d
Edit- Found it:
http://www.scoobymods.com/forums/showthread.php?t=1653
MK19_ is offline   Reply With Quote
Old 03-23-2005, 03:30 AM   #7
polarpreza
Member#: 71881
i am a newbie . what does that do ?
polarpreza is offline   Reply With Quote
Old 03-23-2005, 11:04 AM   #8
MK19_
Member#: 49148
Dogs are forever in
Old 03-23-2005, 01:33 PM   #9
bobby d
Member#: 77989
2005 Impreza RS
Crystal Grey Metallic
That is the sub frame kit not the differential kit.
bobby d is offline   Reply With Quote
Rear differential bushing kit Lachlan Newbies & FAQs 11 05-08-2006 04:46 PM
Whiteline/Kartboy Rear Differential Bushing Kit Dasani Private 'For Sale' Classifieds 2 04-30-2006 12:31 AM
Whiteline/Kartboy Rear Differential Bushing Kit Dasani TXIC Private Classifieds 0 04-28-2006 12:51 PM
whiteline Rear Differential Bushings & Rear Differential Lock Bolts 15secWRX Brakes, Steering & Suspension 9 05-23-2005 12:05 AM
Rear Differential Bushing Kit edaniele1212 Transmission (AT/MT) & Driveline 7 03-20-2005 08:40 PM
