Old 03-21-2005, 01:57 PM   #1
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
Default MRT header satisfaction
all you N/A 2.5's out there that have mrt headers, are you guys happy with them and what are your opinions in general. thanks?
Sharmin7 is offline   Reply With Quote
Old 03-21-2005, 03:59 PM   #2
subi_2.5rs
Member#: 67538
2003 impreza wrx
black/blue/purple
a buddy of mines has it and likes it.....the only thing i dont like is the H part of the header....i would cut it off and wield it shut....weight lose there.....better gain (air flow) too....
subi_2.5rs is offline   Reply With Quote
Old 03-21-2005, 05:34 PM   #3
Siper2
Member#: 1134
2010 Legacy GT Ltd.
Hit up m750 from NESIC. He's got some on his GC RS and seems happy. I was just in his car last week.
=S2=
Siper2 is offline   Reply With Quote
Old 03-21-2005, 08:23 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Very good headers. We've run them for a couple years now and have no complaints. I'm not convinced the H pipe is even part of the flow. I can't feel any openings when feeling around with a coathanger.....
Upsides:
Bulletproof
Make as much power as anything out there
Sound unique but not raspy
Downsides:
Mild steel construction
Weight
Stock cat longevity
Requires non-stock midpipe shape
Jay Storm
Old 03-23-2005, 02:13 PM   #5
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I've been reasonably happy w/ my MRT. Though, I've had an exhaust leak the whole time I've owned it, and a CEL. It depends on the price. I got it back in 2001 for around 450 for the whole thing. It was a steal. What I liked: price, it sounds pretty good, equal length. What are they going for now?
Here are my recomendations:
1. Get it coated, it won't hold up in snowy salty enviorments.
2. Skip the muffler, either get a wrx one for free, or use another premade rs muffler.
3. Have it professionally installed, but, make sure they know that they can lossen a wire tie that holds the o2 sensor wires. They should not need to cut splice any wires.
AO
m750 is offline   Reply With Quote
Old 03-24-2005, 02:59 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I got my MRT system in the same group buy that m750 got his. He and I both had ours coated by www.airborncoatings.com in Hartford, CT (similar stuff to Jet Hot, just a different brand name). I recently discovered two cracks where the cross-over pipe joins each main tube and had those welded up (posted here about it a couple weeks ago). All in all I've been very happy with the system. If you search you'll find some dyno graphs I posted way back when I first got the system - a dyno proven +14hp at peak, and something like +18hp at redline, with no loss of low end.
The muffler itself certainly isn't anything special. I just ordered a Stromung dual tip to replace mine - the MRT muffler is fine, hasn't rusted through or anything like that, I just want to try something different.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 03-24-2005, 09:35 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
I have one that's been decatted with a trackpipe welded in. If anyone is interested, shoot me a PM or email. It's just sitting unused.....
Jay Storm
Old 03-24-2005, 02:59 PM   #8
Sharmin7
Member#: 59929
2002 2.5rs
Platinum Silver
What were you using for a midpipe and axleback with that setup
check your pms?
Old 03-24-2005, 03:55 PM   #9
kickin_81
Member#: 16679
2004 Forester XT
Storm, how much of a gain did you get with the track pipe welded on? Is the MRT's cat that restrictive?
kickin_81 is offline   Reply With Quote
Old 03-24-2005, 04:32 PM   #10
m750
Member#: 2278
8Sti | 07 allez
White | Comp
It's not restrictive at all. you can see light through it, irrc.
AO
Old 03-24-2005, 05:55 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
It was used for testing on a SWC car. Mid pipe was a short section tuned to the engine package. It was eventually replaced with something a little lighter.
Jay Storm
Old 03-25-2005, 02:40 AM   #12
kickin_81
Member#: 16679
2004 Forester XT
Thanks, m750! I needed to know that before I waste money on a test pipe I don't need.
OBX header vs. MRT header dyno results Patrick Olsen Normally Aspirated Powertrain 7 06-26-2006 09:31 AM
Will header wrap rust the MRT header? Any experience? Robmat Normally Aspirated Powertrain 4 08-20-2002 08:29 PM
('93-'01) Went from 15.9 to 15.6 with MRT header back system and.... scootr Impreza Forum 2 06-13-2001 09:53 PM
Just got back from a 50 mile test drive of my MRT header back system. scootr Normally Aspirated Powertrain 1 06-12-2001 10:57 AM
Attn: MRT header buyers slide Legacy Forum 0 03-17-2001 09:10 PM
