Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 03-21-2005, 02:10 PM   #1
sjtangb21
Member#: 83433
Default radiator fluid is only going to the radiator holder, not back to the engine
Ok anyone tell me what's going on? everytime I drive the car over heat then i open the hood, all the green radiator fluid is fill all the way to the top in my radiator tank(the white tank have high and low radiator reading on it) is it because of my thermostat is bad or water pump? pics or any help??
cg
sjtangb21 is offline   Reply With Quote
Old 03-21-2005, 02:39 PM   #2
HaPpilyObsessed#44
Member#: 74744
2004 WRX STi
'52 Chevy S-10
Do a search on this forum. Could be many things from the not bad, pretty bad, to the very bad. I had this problem and cured it by replacing the rad cap. Some have had blown head gaskets and so forth. Defenitly get a leak down and compression test!
HaPpilyObsessed#44 is offline   Reply With Quote
Old 03-21-2005, 05:01 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
uh oh! Sounds like a head gasket issue.
Tim Sanderson is offline   Reply With Quote
Old 03-21-2005, 05:03 PM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
change your thermostat..seems to be stuck closed
sidewayz is offline   Reply With Quote
Old 03-21-2005, 05:12 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
you may be right
Old 03-21-2005, 06:00 PM   #6
sjtangb21
Member#: 83433
to me it's more like the thermostat, the reason i am thinking that is because there is no heat when it's over heated. so does that mean the thermostat is closed and not opening? and that's the reason why the fuild is not circulate?
cg
Old 03-21-2005, 08:29 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Can't hurt to try, it's a relatively cheap part and an easy fix.
Old 03-21-2005, 09:06 PM   #8
sjtangb21
Member#: 83433
hope so. other wise i am going to crush that pos and get some insurance money
cg
Old 03-21-2005, 09:34 PM   #9
yergi
Member#: 65303
nope nope
"dooby specialist"
stuck thermostat happens more often than anything else with those symptoms.
yergi is offline   Reply With Quote
Old 03-22-2005, 08:35 PM   #10
ryking69
Member#: 83463
98 Impreza
dirty
If the termostat doesn't fix then the waterpump. their the two things that control circulation, if it was a head gasket the car would barely run and blow white smoke everywhere plus the overflow tank would be empty.
ryking69 is offline   Reply With Quote
Old 03-23-2005, 12:15 PM   #11
HaPpilyObsessed#44
Member#: 74744
2004 WRX STi
'52 Chevy S-10
Its odd though.. cause its still filling the overflow..? Id have to agree with it being a stat. Other then that it doesnt make sence..
Old 03-23-2005, 06:48 PM   #12
sjtangb21
Member#: 83433
yes. the overflow is full to the top. and there is no white smoke coming out of the exhaust. so i am hoping it's just the stat too.
shi jie
My STi is only building .5 bar and then RPM race to red line? SolidSnake Newbies & FAQs 31 06-28-2005 11:35 AM
So I sold the 10D and went back to the D30 mattjk Off-Topic 13 09-10-2004 10:09 PM
Is the turbo xs turbo back exhaust the same as the stelth minus the muffler?? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-17-2003 09:37 PM
('93-'01) Is the parking brake not supposed to work...? aov Impreza Forum 18 06-15-2001 04:39 PM
Just talked to the dealer and they say the WRX will not have a turbo'ed engine.... Die Civic General Forum Archive 30 01-10-2001 12:59 AM
