Old 03-21-2005, 02:23 PM   #1
doghouse
Member#: 83500
Default p0031 --> O2 heater problem
Hello. I have a '97 Outback into which I have transplanted a '02 WRX motor. I've got about 40k miles on the setup and only now have gotten around to hooking up the OBDII and reading the codes. I have several, some which I am aware of, and some which puzzle me. There was no fuel tank pressure, temp, or level sensor or fuel pump controller circuit in the Outback, so all those codes are present (any ideas how to "fake" those?). But the one that really puzzles me is the P0031 --> Front O2 Heater Circuit. I've checked all the wires going back to the ECU, checked for proper voltage and grounding of the circuit, and even tried three different O2 sensors. All to no avail. Any ideas? Thanks.
doghouse is offline   Reply With Quote
Old 03-21-2005, 10:21 PM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Well are you sure your harness and ECU are from the same year? Reason I say this is that (from my research) the ECU pinout for the “Front Oxygen (A/F) Sensor” is different for the 02/03 from the 04/05 ECU’s. For example the sensor signal + (pin-19) and – (pin-29) is reversed on a 04/05 ECU. Possibly this is the source of your problem?
Rather than digging back into the wiring, if you have an extra O2 sensor kicking around, try swapping these signal wires and see if this corrects your issue.
As for the fuel issue. I'm surprised you even got it running without these sensors...
Seriously though, how are you controling the fuel pump, I assume you're using a WRX pump?
xcntrk75 is offline   Reply With Quote
Old 03-22-2005, 07:42 AM   #3
doghouse
Member#: 83500
Hmmm... I don't *think* so, as everything was labled, but I suppose anything is possible. There are also so many wires and different colors for me not to notice something like that. With Subaru's affinity for changing connectors every 6 months, I'd also be surprised everything plugged in.
Anything is possible and perhaps I should check this. Although I did backpin the connector at the ECU and it was within spec.
Oh, it runs like a top. It's got 40k already on the swap and not a single (real) problem. The pump is simply hardwired. Not safe in event of a wicked accident, but...
This is something I've been putting off for awhile (obviously) and finally am trying to wrap my head around. I'm not entirely sure what to do about the fuel tank pressure, level, and temp sensors. Perhaps find someone with an '02 and check to see what the ECU is looking for. I'm going to dig around in the rest of the harness (if I can find the box I saved it in) for the fuel pump controller. It's *possible* I still have that and can hook it up.
Thanks for the suggestions, I'll give that a try.
CEL P0031 front 02 heater a/f ratio sensor low voltage shinsain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 11-09-2011 09:06 PM
CEL P0031 (a/f heater control curcuit) any way to bypass this? password:ej20 Service & Maintenance 2 02-23-2009 01:13 AM
P0031 Front O2 Heater Low doghouse Subaru Conversions 20 10-24-2008 01:07 PM
P0031 front O2 sensor AliBenn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-05-2006 03:41 AM
P0031-->Front O2 Heater Questions doghouse Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-23-2005 02:30 PM
