Old 03-21-2005, 04:52 PM   #1
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Default Diagnosing which head gasket failed?
I have a '98 Outback that has the signs of a failed head gasket. Whats the best way to diagnose which side has the failure? I would think that a compression test would likely read lower on at least one of the two cylinders on the side w/the failure.
Any other suggestions? I don't want to pull both heads if I can help it.
Thanks,
Mark
annointed is offline   Reply With Quote
Old 03-21-2005, 04:59 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Changing both would eliminater the need to define which one it is.
Tim Sanderson is offline   Reply With Quote
Old 03-21-2005, 05:28 PM   #3
dsc
Member#: 15559
A compression test might tell you which cylinder is leaking. A leakdown test would work better. Check out this link and this link.
dsc is offline   Reply With Quote
Old 03-21-2005, 05:48 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
pull the plugs, if one side looks very white, like it was cleaned, thats the side.
When coolant boils in the cylinder it in effect steam cleans the plugs.
Jay
ej205 head gasket fail glvr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-22-2010 01:33 PM
diagnose problem - head gasket? Spackler Normally Aspirated Powertrain 3 11-04-2005 01:00 PM
Which head gaskets? Tattoo Collector Normally Aspirated Powertrain 1 11-15-2002 04:24 PM
Which head gaskets on EJ22T with EJ25 SOHC heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 22 05-11-2002 11:08 AM
EJ22T with 2.5 SOHc heads. which head gasket? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-03-2001 11:40 AM
