Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 03-21-2005, 07:20 PM   #1
ScoobiDo
Member#: 83449
2000 Impreza Outback
2 tone green-grey
Default PO302 Misfire Code - Problem Identified
Just had my car (00 Impreza Outback Sport) scanned for the misfire code. The scan indicated a misfiring on no.2 plug. After some short searching, teh mechanic noticed the plug to have a carbon deposit along the porcelain from the top of the plug to the nut. The carbon is a result of a bad plug wire, causing the spark to arch from the tip at the wire connection to the nut. The carbon deposit, being highly conductive, increases the rate of arching and as a result, increases the misfiring.
With my car, it does not seem to misfire under light acceleration, which it actually might be doing but not noticeable due to the light load. However, when accelerating hard, it misfires noticeably and constantly at almost any rpm. Anyways, since he did not have new wires available at the time, he did clean the carbon from the plug and the car run better. Coincidence?
Interested in any thoughts!
ScoobiDo is offline   Reply With Quote
Old 03-21-2005, 07:51 PM   #2
WRXRgr
Member#: 54942
2004 WRX
It will run better, but only temporarily. The carbon track on the porcelain is matched by a track on the inside of the rubber boot, too...it'll start up again. Replace the wire and either clean the porcelain well, or just replace the plug, at the same time. I'd replace all four plugs & wires, if one was carbon-tracking.
WRXRgr is offline   Reply With Quote
TGV codes and misfire code upon start up eliezerrosario Service & Maintenance 3 07-03-2009 05:27 PM
Local NGK Source, P3023 #2 Misfire Code hillman Mid West Subaru Owners Club Forum -- MWSOC 22 12-22-2007 02:38 PM
Okthe misfire codes wont stop.. cronic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 11-11-2003 05:22 PM
Spark Plug Gap and Misfire Codes, Realtionship? JayGold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-15-2003 05:02 PM
after unchip install i have misfire codes MyFastToys Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-23-2002 12:04 PM
