Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-22-2005, 12:08 AM   #1
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
Default stereo/gage install
this is what ive got so far... greg's baja pics
tell me what y'all think... the stereo is in, ive got the boost gage hooked up, going to figure out the egt and a/f gages on wednesday or thursday, then maybe i can paint the gage panel (i made it myself) flat black or something...damn thing took me all day but i think it will turn out ok
cliffhanger is offline   Reply With Quote
Old 03-22-2005, 07:25 PM   #2
Pursuit
Member#: 38370
Hmm... sheet metal is not easy to work with. I admire the effort you put into it.
IF it were me, I'd be tempted to go buy some sheet ABS or polyethylene. Get some nice thick stuff so you can actually sand in the contours to match the curve of the panel above it, get some nice radiuses going around the edges. Or you could heat it up and bend it, but you'd have to drill your holes for the guages before you bent it. Get some cutting bits for the drill in the same size as your guages and you'll get nice clean cut outs.
Then you can plastic primer it, sand it down with like a 1200 or 1600 wet/dry sandpaper and spray it with a color to match the climate control panel as well. Take your time to figure out the shape you want etc. and it could turn out real nice.
Pursuit is offline   Reply With Quote
Old 03-22-2005, 07:26 PM   #3
2003Baja
Member#: 52985
looks different. WHat exhaust you got on there?
2003Baja is offline   Reply With Quote
Old 03-22-2005, 10:09 PM   #4
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
That looks like the 2nd generation muffler from Xcceleration.com
ajabobrut is offline   Reply With Quote
Old 03-23-2005, 05:46 PM   #5
cliffhanger
Member#: 80446
2005 5spd Baja-T
this was just my first try, im sure there will be others with different materials but i think it looks pretty sweet... yeah, i do have the xcceleration/ random tech exhaust, and it is sweet!
Old 03-28-2005, 09:25 PM   #6
cliffhanger
Member#: 80446
2005 5spd Baja-T
i used polyethylene (plastic) this time, and i think it turned out a lot better...
Old 03-28-2005, 09:26 PM   #7
cliffhanger
Member#: 80446
2005 5spd Baja-T
why can't i post pics? anyway, those urls will take you to the pics...
Old 03-28-2005, 10:45 PM   #8
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
links not working, but I saw the pics looks better now with the plastic.
BajaT05 is offline   Reply With Quote
Old 03-28-2005, 10:52 PM   #9
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
There ya go... I dont think you can host them from Yahooo. Try to find a different host and then try it.
[img]url here[/img]
Old 03-29-2005, 11:34 AM   #10
BAR83NJ
Member#: 83918
The head unit looks cool, but I would probably have gone the route of an aftermarket 3 pod A-Pillar replacement rather then in the center there on the gauges.. but thats just my personal preference. Great idea none the less! ~ Brett
BAR83NJ is offline   Reply With Quote
Old 03-29-2005, 05:44 PM   #11
cliffhanger
Member#: 80446
2005 5spd Baja-T
i didnt know if any of the wrx a-pillars would fit the baja, and i havent seen any specifically for the baja... plus i get a little personal pride knowing that i have something no one else does thx and correct me if anyone finds a-pillars...
Old 03-30-2005, 10:43 AM   #12
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
That guage setup doesn't look bad, the texture on the plastic available in a smooth surface?
I may attempt to install the boost guage in the right center vent. I found a 42mm Omari gauge that should fit. After I sort out the seats a boost guage is next.
too bad we don't have enough room overhead to do something like these Delfi gauges:
02_Forester is offline   Reply With Quote
Old 03-31-2005, 10:46 AM   #13
Member#: 84229
2005 Baja
Light Blue
Default how'd you get the center console off?
It's a little bit basic considering all that you've done but i just need to get the pannel off so i can install a deck with a aux line in in the front (for my ipod) i can't seem to find any way to pop the console off.
b@j@ is offline   Reply With Quote
Old 03-31-2005, 10:51 AM   #14
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
Take out the ash tray. There are two screws under there.
braveit1 is offline   Reply With Quote
Old 03-31-2005, 06:10 PM   #15
cliffhanger
Member#: 80446
2005 5spd Baja-T
here are some good directions...scoobytruck.com!!
these instructions are for the install of the factory subwoofer, but they give pics and stuff as to where the screws are... check the rest of this site out!
Oil Pressure Gage Installation Scrappydiggs Newbies & FAQs 4 05-18-2004 03:46 PM
Need how to on boost gage install DANACoOp Electrical & Lighting 2 01-23-2004 01:03 AM
Boost gage installation tranjo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-01-2001 08:39 PM
Boost gage installed [email protected] Interior & Exterior Modification 9 03-12-2001 11:07 AM
