Old 03-22-2005, 01:58 AM   #1
atmosphere
Member#: 37641
98 Impreza 2.5 RS
Question 120,000 Scheduled Maintenance
I just got the mailed reminder from my local dealer that I need to be getting my 120,000 mile maintenance. What I was wondering was what said maintenance includes. Seeing as how if its minor things like an oil change and what not then I wouldn't mind doing the work myself. The car is a 98 2.5RS. Thanks.
atmosphere is offline   Reply With Quote
Old 03-22-2005, 07:10 AM   #2
GQ
Member#: 4830
12 DucatiSF/Abarth
Red/Nero
Vehicle: IMPREZA RS COUPE
Interval: 120000 miles / 120 month service
Action Description
Perform Replace fuel filter and inspect fuel system, hoses and connections
Inspect Steering and suspension
Inspect Clutch operation
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Brake linings and drums
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Replace Brake fluid
Inspect Automatic transmission fluid
Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil)
Replace Spark plugs
Replace Air cleaner element
Perform Replace engine coolant and inspect cooling system, hoses and connections
Replace Engine oil filter
Replace Engine oil
This info was taken from my.subaru.com
Great site for this info.
http://my.subaru.com/login/login.jsp
GQ is offline   Reply With Quote
Old 03-22-2005, 09:56 AM   #3
sjtangb21
Member#: 83433
where is the fuel filter located? do you have a picture? and the detail of how to change it?
sjtangb21 is offline   Reply With Quote
Old 03-22-2005, 10:57 AM   #4
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
I believe your car is the same as most other subies, so when you are looking in the engine bay it should be mounted to the drivers side strut tower. A little can with two tubes coming out the top. Changing it is simple. Open your gas door and unscrew your gas cap (people say this helps, I don't really know but do it anyways). Then you loosen the little clamps on the hoses and twist and pull and remove the hoses from the filter. There will be some fuel in the lines, so have a rag handy. Then undo the clamp holding the filter in place. Reverse the steps with the new filter (avail. either at the dealer or someplace like Napa) and you're done.
Be a pit patient on the restart.
Jared
gtwagon941 is offline   Reply With Quote
Old 03-22-2005, 12:49 PM   #5
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Old 03-22-2005, 01:09 PM   #6
DreddRS25
Member#: 51642
2008 WRX
Jared
Recommend doing it to a cooled engine. There is a detailed guide on
http://www.northursalia.com/m...r/ffilter.html
DreddRS25 is offline   Reply With Quote
Old 03-22-2005, 02:45 PM   #7
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Yeah, forgot the part about cooled engine. Good to know my explanation was basically the same as the one you posted, but not quite as thorough.
Jared
Old 03-23-2005, 10:41 AM   #8
paulpas
Member#: 83650
It means you need to bore out your block, stroke it, and port n polish your heads.
paulpas is offline   Reply With Quote
Old 03-23-2005, 12:35 PM   #9
DreddRS25
Member#: 51642
2008 WRX
Jared
Meant to give ya credit, I was just making a suggestion.
Old 03-23-2005, 12:47 PM   #10
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
No credit needed. But thanks.
jared
45,000 Mile Scheduled Maintenance invisiblecity Service & Maintenance 8 09-29-2009 09:44 AM
scheduled maintenance at 80,000 Miles nick robinson Service & Maintenance 5 01-29-2007 10:12 PM
30,000 Schedule Maintenance, How important? XROLLER General Forum Archive 5 12-06-2000 08:21 PM
Scheduled Maintenance sbsnyder General Forum Archive 2 10-05-2000 06:41 AM
dumb question about scheduled maintenance bryanw Technical Forum Archive 3 05-15-2000 07:28 AM
