Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 03-22-2005, 07:28 PM   #1
turbocolin
Member#: 43539
95L 97L 03hedgehog
02 wag 180mph monster
Angry Cel codes p0122 and p0442
OK someone please help. p0122=tps/pedal position sensor A circuit low input and p0442=evap emission control system leak (small). I have searched so many threads with no resolution. Its a 2002 wrx...I have blitz nurspec catback and a helix uppipe. Does anyone know exactly what these are. Any input would be great. Thanks
turbocolin is offline   Reply With Quote
Old 03-22-2005, 07:43 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Well the P0122, indicates a problem with the throttle position sensor or tps circuit.
The P0422, indicates there is a small leak somewhere in the evaporitive emmissions system.
First place to look for that is the gas cap, look at the seal and see if it is distorted or if the gas cap tether is stuck under the cap or has been in the passed.
Jay
Old 03-22-2005, 07:47 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The TPS code indicates a problem with the throttle position sensor, either the sensor itself or the wiring. Make sure it's plugged in properly. If you have access to a scanner that can read live data look at the TPS values as the gas pedal is moved through its range. The indicated throttle % should go from 0 to 100 smoothly with no jumps or dead spots. If you don't have a scanner the TPS can be disconnected and checked with an ohmeter (only do this with the key off).
The evap code could be anything from the gas cap to a leaking hose or connection in the evaporative system either in the engine compartment or back under the right rear of the car where the charcoal canister and associated plumbing is located.
edit- posted at the same time as Jay.
Old 03-22-2005, 08:00 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
I type like an srt-4....fAstAr! haaaaaaaar!
CEL code P0113 and P0102 together kingtut12 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 02-01-2016 09:45 AM
Need help with CEL codes 170 and 141 Rich L Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-02-2008 07:16 PM
V7 STi CEL Codes - P0350 and P1306 moss Subaru Conversions 3 10-13-2006 02:35 AM
CEL codes P0102 and P0103 both NITROS Service & Maintenance 6 11-15-2005 06:13 PM
Causes of CEL codes P0122 and P1133 nytoy Normally Aspirated Powertrain 5 12-27-2004 01:12 PM
