Old 03-22-2005, 10:34 PM   #1
95legacykid
Member#: 68073
1995 legacy lsi
white
Legacy turbo legacy
is it possible to put an older legacy turbo in a 95' legacy 2.2l without having to change alot of stuff like fuel pump and injectors. or is it better to do a turbo motor swap.thanks
95legacykid is offline   Reply With Quote
Old 03-22-2005, 11:34 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Dont even try. Just find yourself a 91 to 94 Legacy Turbo and fix it up. Motor swaps are for the devil. Once you pull that ej22T you are giong to have to change about every sectoin of wiring because it will be so brittle and old.
But if you do want to try it, I have an ecu harness that lets you run an ej22T off of a 95 Legacy ECU harness. I had it custom made, but I had problems with the IAC and a few other things.
subiekid is offline   Reply With Quote
Old 03-23-2005, 12:35 PM   #3
95legacykid
Member#: 68073
1995 legacy lsi
white
is it possible to turbo the 95 ej22 at all with in a reasonable price
Old 03-23-2005, 01:08 PM   #4
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
well what do you consider a reasonable price?
biggreen96 is offline   Reply With Quote
Old 03-23-2005, 01:22 PM   #5
95legacykid
Member#: 68073
1995 legacy lsi
white
well im not trying to get a turbo kit to smoke cars at the track. i just want to run a turbo for alittle more power. reasonable to me is like less than a grand
Old 03-23-2005, 01:43 PM   #6
biggreen96
Member#: 12535
vf39 06 5MT XT
unless you scored awesome deals on everything that you would need( which is a bunch of stuff) I'm gona say no.
Old 03-23-2005, 01:45 PM   #7
biggreen96
Member#: 12535
vf39 06 5MT XT
I'm with subiekid- if you want turbo without the turbo headache then sell your BD for a BC or a BF. Thats what I did/am doing.
Old 03-23-2005, 07:36 PM   #8
subiekid
Member#: 25516
To use OEM parts from an ej22T you are going to need a turbo cross member, headers, up-pipe, turbo, oilpan, injectors/fuel rails, parts of an intake...
On top of that you still need some sort of ecu to retard timing and deal with fuel. You will only be able to run about 6 psi since you will be running a high CR and a block not made for boost.
Old 03-24-2005, 04:59 PM   #9
greg donovan
Member#: 60743
'95 Impreza L
dirty and on jack stands
i think for what you want a ej25 would be a better replacement.
but as this is the other turbo forum.
yes it can be done you will need a turbo cross member all the exhaust plumbing and alot of other goodies. but i would keep it under 6 pounds of boost. that is why i say go for the ej25.
greg donovan is offline   Reply With Quote
Old 03-25-2005, 04:44 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
If you decide you want to do this I have the following for sale from a '93 Legacy Turbo:
crossmember
headers
up-pipe
Turbo
downpipe
What you would need to sort out is intake plumbing and coolant lines and oil lines...
Old 04-03-2005, 05:10 PM   #11
Brandon Clifton
Member#: 68965
1994 Touring Wagon
1995 Legacy L
95legacykid- I turbo'd my '95 legacy and the only problem I ran into was a broken ring on #4 piston (which came from too little fuel and a 15psi boost spike).
Other than that, I used the following:
Custom uppipe that ran from the factory manifold, behind the pass. side axle, and to the turbo.
Custom downpipe that went from the turbo down into the exhaust
(I just took out the front cat and replaced it with an uppipe/downpipe)
Factory EJ22T turbo-to-throttlebody elbow and airfilter-to-turbo elblow (which can both be custom plumbed at your local exhaust or fab shop, and will need to be custom if you want to run a FMIC)
EJ22T pink-top 340cc injectors
S-AFC II
Stock BOV
No intercooler
I street tuned the whole setup and it ran pretty well. Like I said- it would still be together if not for the wastegate line coming off and the turbo hitting 15 psi.
Turboing the stock EJ22EZ is totally do-able.
As for you haters that say "Ohh- but the EJ22E is an open deck.. blah blah blah," well, so is the EJ257, the EJ20, and every other block except the Type-RA, EJ22T, and the other specialty pieces that are sold JDM/AUDM/EUDM.
Everything cost me less than $1,000.
$320 for S-AFCII
$120 for injectors/intake pieces
$100 for up/down pipes (built them myself from mandrel bends from JC Whitney)
$150 odds and ends (braided oil line, extra valve cover for oil return, gaskets, hoses, trial-and-error pieces, etc)
Here for pictures: http://www.geocities.com/brandon_cli...baru/Legacy_L/
E-mail with questions.
Brandon
Brandon Clifton is offline   Reply With Quote
Old 04-12-2005, 09:17 PM   #12
95legacykid
Member#: 68073
1995 legacy lsi
white
thanks everyone, and thanks brandon thats what i wanted to hear..haha..this is alittle side project so ill so what i can come up with and post stuff along the way
Wtt: wrx turbo and intercooler for stock Turbo legacy turbo and intake 91turbosedaan Private 'Wanted' Classifieds 1 12-06-2008 05:17 AM
flywheel intercompatibility. Wrx ,legacy turbo, legacy non-turbo psyber_0ptix Transmission (AT/MT) & Driveline 1 11-23-2005 11:25 AM
exhaust differences b/w turbo legacy and NA legacy 2.5GT Legacy Forum 2 11-12-2002 12:40 PM
91 Legacy Turbo+Legacy L For Sale ejicon Southern California Impreza Club Forum -- SCIC 2 07-27-2002 11:18 PM
1992 Turbo Legacy Vs. Legacy L Narcisse91 Legacy Forum 12 03-23-2001 07:11 PM
