Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 07-21-2001, 07:40 PM   #1
boostaholic
Member#: 7224
2002 WR Blue WRX
13's with just a MBC
Question TD04-18T-6cm2 / TD04-17G-6cm2
Does anyone know if a TD04-18T-6cm2 or TD04-17G-6cm2 will bolt up to a 2002 WRX? They are much cheaper than IHI turbos, and I don't care about turbo lag...
boostaholic is offline   Reply With Quote
Old 07-21-2001, 07:46 PM   #2
tspec1
Vendor
Member#: 8544
Default Mitsubishi Turbos
Boostaholic,
If you can get some factory mitsubishi part numbers off of those turbos we will be able to tell you if they will bolt right up or if modifications would be needed.
Hunter
tspec1 is offline   Reply With Quote
Old 07-21-2001, 11:54 PM   #3
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
I know you say you don't care about the lag...
but 6cm2 is just HUGE... you probobly won't be at full boost till about 5000 RPM.
I guess your going for a pure strip car using spray for boost assist... cause that is completely unstreetable off a low comp 2 litre motor. Supra... yeah.... DSM/WRX? Noper...
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-22-2001, 01:30 AM   #4
phast
Member#: 7957
That is a highly uninformed opinion. 6cm2 happens to be the STOCK turbine housing on the DSM cars. And the 1st gen DSM's spool that with a little less compression even.
Expect spool in the 3krpm range with the 6cm2 housing. ALL of the upgrade turbos for the DSM's are at least 7cm2 and some of the larger TD06 based turbos have an 8cm2 housing.
-jay
phast is offline   Reply With Quote
Old 07-22-2001, 08:07 AM   #5
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Let's figure out which turbos fit without modification before we start arguing about which ones are good
rao is offline   Reply With Quote
Old 07-22-2001, 11:27 AM   #6
shabby
Member#: 2682
93 Eagle Talon AWD
Those turbo's you mentioned are tiny, spool up will barely be affected.
I have a td05h 16g 7cm2 turbo on my dsm and i get 15 pounds by 3300
rpm in 3rd gear. If you think this is laggy then you should switch to a v8 with instant torque, power isnt free you just have to wait for it a bit
shabby is offline   Reply With Quote
Old 07-22-2001, 03:57 PM   #7
boostaholic
Member#: 7224
2002 WR Blue WRX
Turbo lag is so overrated... Even with an enormous 60mm T4 turbo I'm sure we would still have full boost by 3500-3800 RPM. I do not know the part numbers on these turbos. Some Mitsubishi 3000GT guys use two of them. They have two TD04L-9B turbo's stock... and they upgrade to 13G's and 15G's. I'm going to assume that we can bolt up any turbo they can bolt up. If someone could confirm this we would be making a huge step.
Old 07-23-2001, 12:51 AM   #8
phast
Member#: 7957
I think the Stealth/#KGT turbos do indeed have matching IHI flanges. I remember hearing something to the effect of needing to order the front turbo from a 3KGT upgrade since the rear turbo compressor housing is clocked 180 degrees. Another interesting turbo would be the GT386. The folks at GTPro make some fairly large 3KGT upgrade turbos. I *think* the work with the stock 3KGT headers/manifolds so they *should* work on the Subaru setup as well. All this is heresay and I haven't done any checking to confirm.
I personally will be seeing what the stock turbo is capable of. So much funner with a challenge IMHO.
-jay
Old 07-23-2001, 10:21 AM   #9
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Your right... my bad... I was thinking TD06 housing
Not 6cm2 housing
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 07-24-2001, 05:28 PM   #10
boostaholic
Member#: 7224
2002 WR Blue WRX
So can anyone find out about this...? I'm itching to buy a 18T!
Old 07-24-2001, 06:05 PM   #11
Obscure411
Member#: 5719
2008 Impreza 5-Door
Good luck
I've asked about this a few times already ... I'm still waiting to see some results.
Obscure411 is offline   Reply With Quote
Old 08-15-2001, 07:29 PM   #12
boostaholic
Member#: 7224
2002 WR Blue WRX
Anyone else have any information on bigger TD04 turbos? These are much more affordable than IHI and especially PE turbos...
Old 08-15-2001, 08:55 PM   #13
shabby
Member#: 2682
93 Eagle Talon AWD
http://www.vfaq.com/mods/10faq.html has info on tdo4 5 and 6 turbos.
FS: td04 oil line, td04 actuator, silicone y pipe DaiMaVuong Engine/Power/Exhaust 4 08-20-2008 11:53 PM
Swapping Out My TD04 With Another TD04 Question MaddSubieLove New England Impreza Club Forum -- NESIC 25 05-08-2008 02:20 AM
stock td04 vs. p&p td04 WrexFactor36 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 07-04-2007 10:26 PM
Td04 18T, JDM sti Alternator, Din Pocket make offers! elsanto Private 'For Sale' Classifieds 12 12-20-2004 02:13 PM
What is the difference between TD04-L and TD04-HL dandbest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-21-2002 10:35 PM
