Old 03-23-2005, 12:01 AM   #1
cinemaster
Member#: 76127
2005 WRX wgn 5spd
Obsidian Black Pearl
Default Rubbing issue on wagon w/ 225/45/17 tires.
Finally I made my mind to replace my stock rims and tires with 17" x 7.5 rims and 225/45/17 tires or 215/45/17. Many people recommend me going with 215 not 225 because of rubbing issue. But still I want 225. Are those really going to rub on my wagon?
cinemaster is offline   Reply With Quote
Old 03-23-2005, 01:35 AM   #2
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
try reading this:
http://www.subydude.com/mods/detailsdoc.php?3055
i'd say go 215, its guaranteed to fit (this is w/ 17 x 7.5 48 offset wheels)
good luck
sd
suby_dude is offline   Reply With Quote
Old 03-23-2005, 01:41 AM   #3
YinUCSD
Member#: 44945
05 Fxt
black
depends on offset of wheels. general rule:
rims with 48 offset or lower, use 215. a 48 offset with 225 tires... some rub some dont.
rims with 49 offset or higher, use 225.
YinUCSD is offline   Reply With Quote
Old 03-23-2005, 02:00 AM   #4
cinemaster
Member#: 76127
2005 WRX wgn 5spd
Originally Posted by suby_dude
try reading this:
good luck
sd
According to that article, I should find a 'skinny' 225 tire if I wanna run 225... Which brand's 225 is thinner? Any idea?
Old 03-23-2005, 02:01 AM   #5
cinemaster
Member#: 76127
2005 WRX wgn 5spd
Oh my.... I'm planning to get some rotas. Every rotas are 48.
Old 03-23-2005, 02:07 AM   #6
YinUCSD
Member#: 44945
05 Fxt
black
which brands are 'thinner' is where your search skills come in handy. seriously though, it would take you less time to search for something like 'wagon rubbing' or 'wagons rubbing', than to have people answer your question cuz thatll take days.
Old 03-23-2005, 02:08 AM   #7
YinUCSD
Member#: 44945
05 Fxt
black
which is why subydude included that link to his tech article. its pretty good.
i would just get your fenders rolled if you dont want to be restricted to certain tires in 225. IMO its worth it because tires are the most important when it comes to handling, so you wouldnt want to be forced to use a personally sub-par tire.
Old 03-23-2005, 05:21 AM   #8
ripvw
Member#: 27790
I once tried to cover all the issues related to this topic in this post:
http://forums.nasioc.com/forums/show...on#post6235079
basics are these:
what springs are you running - i.e. what drop?
if you are at stock height the issue is moot - 225/45x17 will fit on Rota wheels - in fact you could run that size tire with 17x8 Rotas with a good alignment like the one spec'd below
If you are at moderate drop, i.e. Prodrive, STI/SPT, Whiteline Control, Tein-H, Eibach Pro-kit, etc. then you can make it work by getting rear camber bolts and a good "sporting alignment" with max negative camber up front - about -1.5 and -1 in the rear. Combine with "narrow" or "standard" width tires, i.e. anything but Bridgestone S03 and Falken Azenis ST-215. Most 225/45x17 tires have a section width of 8.8 inches or less with a 17x7.5 wheel, while the two above are 9+. You can check section width info @ Tire Rack or the manufacturer's websites for a specific tire - remember to check and see what width wheel the spec is for - wider wheels increase section width, i.e. for every .5" change in width the section width will change .2"
If you're running Tein-S or some other "slammed" type of spring you will need to roll your fenders to make 225/45x17 fit with an ET48 17x7.5 wheel like the Rotas. If you get the fenders rolled, I would recommend 17x8 wheels running 235/40x17 tires - more grip, under-driven gearing advantage makes up for heavier wheels, tires are actually lighter
FWIW, I'm running Prodrive springs with 17x7.5 Rota Attacks and Falken FK451's - no rubbing with -2 F/-1.5 R camber settings. Others having similar success can be found in a link near the top of my post linked above
Since you're in SF along with SubyDude and you want Rotas, I would guess that he knows of some spring/wheel/tire combos that have worked with previous wagon owner clients of his - and he also sells Rota/tire combos...
ripvw is offline   Reply With Quote
Old 03-23-2005, 07:29 AM   #9
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
Just get your rear fenders rolled and you'll never have to worry about it. You could even run 235's.
Old 03-23-2005, 07:49 AM   #10
cinemaster
Member#: 76127
2005 WRX wgn 5spd
How to get fenders rolled?
Old 03-23-2005, 07:56 AM   #11
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Most body shops can do it, and some "performance" shops. Just ask around. Make sure whoever does it has experience and knows what they're doing. There's a specific tool, and a heat gun should be used to soften the paint so it won't crack. I had mine done about 3 months after I bought the car for the same reasons. I didn't want to worry about what size tires I could run. I run 235/40-17 tires at the track and they don't rub. I've also run 225/45-17 Falken Azenis, which are known to run very wide, and they didn't rub. I could probably get away with 245/40-17, but I haven't tried yet. Expect to pay +/- $150. To me, it was money well spent.
Old 03-23-2005, 08:05 AM   #12
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Just make sure you get someone good to do it. A guy here locally got his rolled and they chipped and cracked the paint. He had to have his rear fenders repainted.
Go for the 04 STi wheels, you won't regret it.
dbrier is offline   Reply With Quote
Old 03-23-2005, 08:29 AM   #13
cinemaster
Member#: 76127
2005 WRX wgn 5spd
I'll forget about getting rolled my fenders.. I don't want to spoil my car.
I wish to get the used STi wheels.. Should I go ebay now?
Old 03-23-2005, 08:35 AM   #14
cinemaster
Member#: 76127
2005 WRX wgn 5spd
basics are these:
I'm running stock springs.
Thank you for earnest posting. It really helped me.
Old 03-23-2005, 09:25 AM   #15
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Mistake. Just get it done right. I've had mine for almost 3 years and I've never had a crack or any rust.
Old 03-23-2005, 10:32 AM   #16
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
I didn't want to imply that you shouldn't get it done, just make sure it gets done right.
Old 03-23-2005, 12:13 PM   #17
YinUCSD
Member#: 44945
05 Fxt
black
you should do it. seriously. and dbrier wasnt trying to scare you away from it. its easy, just need to watch out for a couple things. like with all mods.
if you want some sti wheels lemme know.
Old 03-23-2005, 01:06 PM   #18
ripvw
Member#: 27790
possible fender rolling solution:
http://www.rollyourfender.com/
Old 03-23-2005, 02:17 PM   #19
Bagelw
Member#: 41874
2011 WRX
I regularly track my car with 225/45/17 Azenis on SSR Competitions with a 50mm offset(I believe). My suspension is stock right now and I've never had rubbing issues. Autocross may be a different story since it can be more herky jerky but I haven't autocrossed with the WRX yet. For everyday driving you should be fine with 225s.
Bagelw is offline   Reply With Quote
Old 03-23-2005, 04:17 PM   #20
YinUCSD
Member#: 44945
05 Fxt
black
very cool. for $50 its pretty good.
Old 03-23-2005, 04:20 PM   #21
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
The 50 offset is probably what saves you. It is so close on the wagons with 225s that 2mm can make the difference. You may not even rub with the Rotas, but it is hard to tell.
Old 03-23-2005, 04:55 PM   #22
WimpWgn
Member#: 66580
I've had 225 45 17 on 7.5 et48 wheels and no rubbing. It's lowered too.
WimpWgn is offline   Reply With Quote
Old 03-23-2005, 07:24 PM   #23
YinUCSD
Member#: 44945
05 Fxt
black
depends on tires. some are wider than others even though theyre all 225-45-17.
Old 03-23-2005, 09:21 PM   #24
cinemaster
Member#: 76127
2005 WRX wgn 5spd
After reading all, I came to the conclusion that I should get BBS rims.
Old 03-23-2005, 09:35 PM   #25
HomerJay
Member#: 1135
2005 WRX WAGON
I'm running a set of '04 STI BBS rims on my wagon w/ 225/45/17. No problems rubbing. I'll be replacing the tires soon and I'm going to replace them w/ 225's.
HomerJay is offline   Reply With Quote
FS : 225/45/17 Tires like new Vicious LSD Tri-State Area Private Classifieds 6 11-21-2010 12:56 AM
Will 225/45-17 tires rub on a My00 west_minist Tire & Wheel 2 07-12-2004 08:36 AM
Will "Eibach Pro" springs make my 225/45/17 tires rub? magillaTheGorilla Brakes, Steering & Suspension 4 03-14-2004 05:58 PM
17/7.5 Gram lights+ 225/45/17 tires on Wagon garie Brakes, Steering & Suspension 16 11-11-2002 04:24 PM
Will 225/45-17 tires rub Petrie Vancouver Impreza Club Forum -- VIC 0 04-18-2000 08:26 AM
Message Board Statistics All times are GMT -4. The time now is 10:14 AM.
