Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 03-23-2005, 11:46 AM   #1
Member#: 83650
Default Phase I and Phase II compression differences
Is the compression raised from the pistons or raised from the difference in head design? I'm getting my engine in my 97 outback replaced with a Phase II block and DOHC heads. Will I get phase II compression or Phase I?
I'm having the heads milled too, so that will increase it that much more.
paulpas is offline   Reply With Quote
Old 03-23-2005, 11:11 PM   #2
Member#: 5218
96L Most Over-
Developed Beater
I did this very thing....first with 96DOHC heads and then 98DOHC heads. Both sets were milled slightly and with the addition of a thin Cometic headgasket, I'm up very close to 12:1 CR.
The ratio is changed by both piston shape and combustion chamber shape. The DOHC has slightly smaller chambers while the phaseII pistons are 10:1 vs 9.7:1.
If you wish to run less than 92-93 octane gas, I would either forgo the milling unless needed and/or use stock thickness or custom extra thick gaskets to keep the CR in check.
Jay Storm
Phase I and Phase II questions J.McDonald Knives Newbies & FAQs 3 07-26-2008 08:13 PM
How to tell the difference: Phase I and Phase II? mc2 Normally Aspirated Powertrain 8 02-13-2007 11:19 AM
Phase I DOHC/MAF and Phase II SOHC/MAP pin-out diagrams? Patrick Olsen Normally Aspirated Powertrain 7 02-09-2006 05:23 PM
HELP ASAP phase 1 and phase 2 question. 3BadHabbits Normally Aspirated Powertrain 5 09-08-2004 11:51 PM
HELP ASAP phase 1 and phase 2 question. please 3BadHabbits Tri-State Area Forum 0 09-04-2004 09:16 PM
